MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
Search Forum |
10-07-2009, 06:41 AM | #1 |
Rep Power: 0 Thanks: 24
(Thread Starter) | Not Ranked : 0 score Anyone fine tune there shifter and tune out a second gear grind? So for like the 5th time yesterday since buying my car a little over a year ago I did a hard 1-2 shift and ground second gear. And as usual it freaked me out, so I finally got off my ass and did the fine tuning of the cable linkage as shown here: *VIDEO* Fine Tuning your Shifter! Has doing this,...and only this......done anything for the 1-2 grind? And how worried should I be about fucking up my tranny because of the grind? |
10-07-2009, 07:12 AM | #2 |
Rep Power: 0 Thanks: 12
Groaned at 20 Times in 5 Posts
| Not Ranked : 0 score I haven't done anything with my shifter but it will grind on occassions going into 2nd.. ussual only does it when the car hasn't ran for a while, over night, when I get off work type thing. Call me crazy but I've just been ignoring it, didn't think it was a real issue.
__________________ Boooosh! ][ 2007 MS3 GT ][MAZDASPEED cai ][ MAZDASPEED cat-back ][ CP-e dp ][ Turbosmart Dual Port ][ SU rear motor mount ][ ITV-22 ][ RallyArmor mud flaps ][ MS6 wheels ][ |
10-07-2009, 07:18 AM | #3 |
10-07-2009, 11:26 AM | #4 |
| Not Ranked : 0 score Idk I guess grind is the only way I know how to describe it in words anyways. when cold its will seem a lil stift and give me a short lil "RRR" and fall into gear.
10-07-2009, 01:03 PM | #5 |
Rep Power: 0 Thanks: 3
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Changing the trans fluid to ford synthetic or redline solves most of these issues. The redline will make the LSD howl in tight turns though. |
10-07-2009, 02:53 PM | #6 |
Rep Power: 0 Thanks: 286
| Not Ranked : 0 score is it a grind or just a notchy feeling? as long as its a notchy feeling an not an audible noise/feeling i would just say ignor it. its the dog teeth in the tranny engaging |
10-07-2009, 03:30 PM | #7 |
(Thread Starter) | Not Ranked : 0 score For me it's a definate grind for a split second. |
10-07-2009, 03:38 PM | #8 |
Rep Power: 0 Thanks: 54
| Not Ranked : 0 score i fine tuned my shifter also. (delrin) Mazda3Online :: ProtegeGarage :: MazdaRX8Online - Your Source for Mazda Performance
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
10-07-2009, 06:46 PM | #9 |
| Not Ranked : 0 score IDK the more I think about it the more I think it is a split second grind on mine too.
10-07-2009, 07:31 PM | #10 |
Rep Power: 0 Thanks: 47
| Not Ranked : 0 score I put redline fluid in my trans which helped. Something that has worked wonders though is leaving it second gear when I park. In the winter it still is a little rough but much better! |
The Following 2 Users Say Thank You to RichB For This Useful Post: | labikesrcool (10-08-2009), ungrave (10-21-2009) |
10-07-2009, 07:34 PM | #11 |
| Not Ranked : 0 score Im reaching 50K and and already tranny intent on changing my tranny fluid in the next few thousand miles
10-07-2009, 07:46 PM | #12 |
| Not Ranked : 0 score I changed mine twice at 30K intervals |
10-07-2009, 07:50 PM | #13 |
| Not Ranked : 0 score Is it pretty easy? I know theres a how-to out there, been looking for it for a few minutes now.
10-07-2009, 07:58 PM | #14 |
| Not Ranked : 0 score It is pretty easy. I consider it easier than the oil change because you don't have to mess with the damn filter cartridge. The hardest part is getting access to the drain plug. You need like a 24mm bit and mine barely fits with my socket wrench. A ratcheting wrench would be golden! Why haven't I thought of that until now! |
10-08-2009, 11:31 AM | #15 |
Team Überfrazn Join Date: Apr 2008 Location: Plymouth, MN
Rep Power: 324 Thanks: 661
| Not Ranked : 0 score i can't remember where i saw it but i remember that it was suggested to buy a cheap socket and grind it down just for the change.
__________________ "My car won't start!" "Well, maybe there's a killer after you."-Mitch Hedberg I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming. - Mitch Hedberg |
10-21-2009, 12:06 AM | #16 |
Rep Power: 0 Thanks: 129
| Not Ranked : 0 score i dont get that no more, i did the Rear SU engine mount which helped alot, then to finish it off Stage 2 2 short shifter by i forgot the company lol AWM? i forgot and their base bushings. I bought it off SU for like 150? Together for everything i forgot, 200? its a night and day change
__________________ 06 MS6 Black Mica AWD BROTHERS SHALL UNITE! Boys love straight lines.— Men love curves.— =)— Canyon/Circuit FTW!— |
*VIDEO* Fine Tuning your Shifter! | bioevolve | MazdaSpeed 3 - How-To's | 63 | 06-03-2013 03:03 PM |
MS3 tune | Asse | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 05-04-2009 08:45 AM |
2nd gear grind in cold weather | 08_ms3_gt | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 04-01-2009 11:25 AM |
Tune for 91 or 93? | GongShow | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 02-12-2009 09:22 AM |
Why does 3rd gear grind. help? | parapdrapa | MazdaSpeed 3 - Engine, Transmission & Driveline | 30 | 08-31-2008 10:26 AM |
