MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
Search Forum |
12-29-2011, 06:16 AM | #1 |
Rep Power: 3058 Thanks: 4,683
| Not Ranked : 0 score reference point- stock rmm duro is about -10 (yes, minus ten) used bubble gum would work better. based on your selections and criteria, get the 70. -however- if you drive like an animal (LC & FFS, drag or autocross), and you can raise your idle a bit (if you haven't already), get the 88.
The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Rainmens (12-15-2012) |
12-29-2011, 06:59 AM | #2 |
v8 convert Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 Thanks: 2,634
Groans: 220
Yeah my idle is raised a fuck-ton to try and combat smoking.... doesn't really help but i like the idle anyways. | |
01-09-2012, 06:30 AM | #3 |
Groans: 220
Also, i bought the AWR RMM. You HAVE to cut off those stupid prongs. I tried bending them away and that resulted in a ton of fail. (one of the ends of the prongs are welded on.) Pulled out my multi-tool and cut the metal away in less time than it took to debate whether or not to keep bending/prying vs cutting. That metal is relatively soft. Once that was put in, put everything back up and drove it down the road. LOVED it. soooo smooth. and NVH was NOTHING. I mean, the tiny ass amount of vibes was so little. I am really disappointed that people were telling me to go softer. too soft. Seriously, pussy. Now that i put 60 miles on it, i barely feel it anymore and i kinda wish i went with a higher durometer count than that... As far as the mount itself, if you really feel that you dont care (and have the means) about cutting the prong-things at the frame and would like to save a few bucks, go the AWR mount route. get a higher durometer count. 88 is really just minimum you should go at all. i would love to jump up to 95 DM Other than that, go the sure/cpe/SU RMM route... it's brain-dead easy. | |
The Following User Says Thank You to p057 For This Useful Post: | Elvinf25 (12-19-2014) |
05-09-2012, 02:30 PM | #4 |
Rep Power: 0 Thanks: 110
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/motor-mount-thread-100696/ | ||||
Posted By | For | Type | Date | |
Mazda3 Forums : The #1 Mazda 3 Forum - View Single Post - Rmm | This thread | Refback | 12-18-2015 12:05 PM | |
Rmm - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 10-06-2015 06:35 AM | |
Motor mount discussion - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum | This thread | Refback | 04-06-2015 07:23 PM | |
How to: Left Side Trans Mount | This thread | Refback | 06-05-2014 09:30 AM |
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
another blowing motor thread | campbell | MazdaSpeed 3 - Engine, Transmission & Driveline | 40 | 04-16-2010 08:19 PM |
is transmission mount the same as motor mount? | spoonher | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 08-26-2009 02:21 PM |
weakest motor mount..? what mount takes a dump first? | Lvis | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 03-02-2009 11:39 PM |
