Search Forum |
05-11-2011, 09:04 AM | #1 |
Rep Power: 0 Thanks: 5,256
(Thread Starter) | Not Ranked : 0 score Best DD Motor Mount Combination MS6 Okay guys, we all know that keeping our engines in place and firm drastically aids this platform, but with all the motor mounts available it's easy to under or overshoot the perfect combination. While most of us use these cars as a daily driver, I'm looking to get your experienced recommendations as to which combination delivers the most stability without producing unbearable or excessive vibrations. I personally have a SU Rear and TT Front Engine mount and while it's firmed things up nicely, I still have some driveline slop. Vibes with this combination are also negligible and VERY minimal/tame. My stock side mounts may also be tired. I know TRZ and AWR also make Trans (Driver) and Passenger side mounts as well. I'm strongly considering going with both sides and the rear and removing the front mount if necessary. LMK what you guys like/recommend.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper |
05-11-2011, 09:05 AM | #2 |
Rep Power: 0 Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Fuck the sides and SU rear. Keep the front. Buy JBR RMM.
__________________ |
The Following User Says Thank You to triplejumper18 For This Useful Post: | JBR (05-12-2011) |
05-11-2011, 05:36 PM | #3 |
Rep Power: 0 Thanks: 4,160
Groans: 201
| Not Ranked : 0 score I'm told SURE is coming out with a mount set, but it'll be awhile before they have it ready for sale....
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
05-11-2011, 06:04 PM | #4 |
Rep Power: 0 Thanks: 2,193
| Not Ranked : 0 score Jamie has mounts coming out late summer early fall. I think that's what I'm going to wait for not too impressed with the CPE ones now.
__________________ 07 MS3 Sport CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon) JBR: RSB Cobb: Accessport Corksport: TMIC CNT: Catted Downpipe |
05-12-2011, 12:48 AM | #5 |
Speeeeeed Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 7490 Thanks: 6,190
| Not Ranked : 0 score OP has a MS6 lol. I am running a SU rear, TT front, and AWR 70 duro trans and the vibs are no more than your setup. It just takes a few thousand miles for the trans mount to settle in. The main difference is the added noise from the trans, it quiets down as the mount breaks in but it doesnt completely go away. The AWR 70 duro is a special order item, but SU Mark can order it.
05-12-2011, 11:40 AM | #6 |
Is it just a slight tranny whine, nothing crazy? I might have to jump on it if so!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper | |
05-13-2011, 07:56 PM | #7 |
| Not Ranked : 0 score Its quiet enough that I dont notice it unless I am listening for it. I usually drive with the radio on and that helps. I am thinking of getting the 70 duro engine mount, its the last piece before I have all of the mounts.
The Following User Says Thank You to 06Speed6 For This Useful Post: | Alpha (05-13-2011) |
05-13-2011, 08:21 PM | #8 |
Rep Power: 2468 Thanks: 810
Groans: 60
| Not Ranked : 0 score IMO the best combination for a DD is what you already have... The tranny mount adds noticeable gear whine especially in reverse, and combined with a fidanza flywheel makes the transmission very noisy at idle... The passenger side mount added more vibrations than the other three combined... That being said, i'm now running the CPE rear mount along with the 90 duro AWR tranny and PS mount. It vibrates like crazy, but pedal movement = forward motion, the motor does not move.
The Following User Says Thank You to SSinstaller For This Useful Post: | MPSdriver (05-15-2011) |
05-13-2011, 11:33 PM | #9 |
05-18-2011, 04:37 PM | #10 |
Groans: 60
| Not Ranked : 0 score I'd fill the OEM tranny mount and try the 70 duro rear and passenger mount...
05-13-2011, 09:55 PM | #11 |
Rep Power: 739 Thanks: 517
| Not Ranked : 0 score I ran the su mount + awr 88 mount. When the engine goes back in, itll have a jbr mount + 95 awr mount.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
The Following User Says Thank You to jroc For This Useful Post: | JBR (05-24-2011) |
05-18-2011, 12:15 PM | #12 |
(Thread Starter) | Not Ranked : 0 score Bump for this.
05-18-2011, 05:04 PM | #13 |
gonads and strife Join Date: Jul 2009
Rep Power: 241 Thanks: 210
| Not Ranked : 0 score I have the AWR RMM in 88 duro right now, and like it. I plan on picking up their trans and side mounts in 88 duro as well. If you're after reducing drivetrain slop as much as possible, then another good thing to get is both the SURE diff mounts. They made a pretty noticeable difference. |
05-18-2011, 06:47 PM | #14 |
Rep Power: 637 Thanks: 1,048
| Not Ranked : 0 score At first i had just the AWR rear mount. 70 duro. and it only helped a little. Since then i've added an AWR 88 duro tranny mount and it helped alot. There is some tranny whine and a little more vibes in the pedals. But it has faded as the miles pile on. You can really hear the tranny winding up, or down, which i kinda like frankly. Adds a little communication that was missing. But its easily drowned out by road noise at highway speeds or with the radio on. The install was easy enough, and at this point i can't see the need to add another mount. Maybe just for track days, but not really necessary for DD, imho. FYI, I've had both mounts for approx: 20-30k miles. |
The Following User Says Thank You to Mistersix For This Useful Post: | Alpha (05-19-2011) |
05-19-2011, 07:39 AM | #15 |
(Thread Starter) | Not Ranked : 0 score So even the 88 Tranny mount isn't bad? It's weird, on AWR's website is specifically says that the 70 duro isn't recommended... I wonder why?
05-19-2011, 09:39 AM | #16 |
| Not Ranked : 0 score Ive had both the AWR 70 and 88 duro trans mount on the car for more than 20k miles each. There is no difference in engine movement between the two mounts, but the difference in nvh is almost orders of magnitude. After running the 70 duro, you couldnt pay me to run the 88 again.
The Following User Says Thank You to 06Speed6 For This Useful Post: | Alpha (05-19-2011) |
05-19-2011, 09:59 AM | #17 |
Thanks guys!
05-24-2011, 07:56 AM | #18 |
Rep Power: 0 Thanks: 10,516
Groans: 89
| Not Ranked : 0 score i have the awr trans mount and SU lower engine mount.. looking to get the awr passenger engine mount........70 duro ??
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
05-24-2011, 11:47 AM | #19 |
(Thread Starter) | Not Ranked : 0 score I believe that mount only comes in 88 or 95, but you may be able to get it made with a 70 custom. Not sure.
The Following User Says Thank You to Alpha For This Useful Post: | jracer (05-24-2011) |
05-24-2011, 01:14 PM | #20 |
| Not Ranked : 0 score |
05-24-2011, 04:24 PM | #21 |
| Not Ranked : 0 score Its available but its special order.
The Following User Says Thank You to 06Speed6 For This Useful Post: | jracer (05-24-2011) |
05-13-2012, 09:48 PM | #22 |
Rep Power: 0 Thanks: 7
| Not Ranked : 0 score Any updates? im a new MS6 ownern and as you know the options for mounts can be daunting. im just looking for the best set for the best price. cant really afford to test all options. |
05-14-2012, 03:33 PM | #23 |
Rep Power: 0 Thanks: 372
| Not Ranked : 0 score Holy shit this is an old thread.... Well Im here fuck... AWR psm makes the motor sit crooked I would not use it. |
05-14-2012, 06:58 PM | #24 |
Banned Join Date: May 2012
05-17-2012, 01:43 PM | #25 |
| Not Ranked : 0 score I've been considering the same question, after reading as much as I can on here and trying to come up with my own conclusion, this is the setup I'm thinking of going with: JBR - RMM AWR - Passenger tranny mount Turbine Tech - Rear Diff rear mount bushings Turbine Tech or Sure Juggernaught - Rear Diff front mount TT RDFM is 199$ on special right now Sure Jugg is 245$ What do you guys think? (Use is street and sometimes track. No drag racing at all, eww) |
05-17-2012, 01:50 PM | #26 |
Rep Power: 0 Thanks: 2,098
Groans: 78
@SpICeZ
__________________ - 2006 Black Mica MS6 - - GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP - - Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught - - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete - 12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30 12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20 - 2004 Silver Sunlight Metallic RX-8 - - 6MT - Stock - Last edited by Black Metal; 05-17-2012 at 03:50 PM. | |
05-17-2012, 01:47 PM | #27 |
Rep Power: 2705 Thanks: 766
| Not Ranked : 0 score the juggernaught is cheaper with coupon code and free shipping, for me at least
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
05-17-2012, 05:44 PM | #28 |
| Not Ranked : 0 score I just put it there to fill the avatar space, I dont give a flying rats a$$ about avatars, but I just didint want the "avatard". About the TMIC cover, its obviously still there. Back on topic... |
05-22-2012, 03:40 PM | #29 |
Rep Power: 0 Thanks: 284
| Not Ranked : 0 score make sure you get a proper rear diff mount not the bushings. ive personally decided against a trans mount because of reviews of vibration and hearing the gear noise of the transmission.
__________________ 2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS [SIGPIC][/SIGPIC] formerly pursuit_special |
05-22-2012, 04:23 PM | #30 |
| Not Ranked : 0 score For the rear diff, I was thinking of getting a full front mount, but just the bushings for the rear. Since this is generaly a DD, I think I dont really need to replace both mounts. |
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's | Dre | 2010 MS3 - Engine, Transmission & Driveline | 23 | 05-21-2016 08:47 AM |
Why you need a 4th motor mount! | ptperformance | Mazdaspeed3/6 General Discussion | 39 | 10-04-2009 07:19 PM |
is transmission mount the same as motor mount? | spoonher | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 08-26-2009 02:21 PM |
weakest motor mount..? what mount takes a dump first? | Lvis | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 03-02-2009 11:39 PM |
