Search Forum |
04-20-2015, 11:39 AM | #1 |
Rep Power: 0 Thanks: 8
(Thread Starter) | Not Ranked : 0 score Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? My clutch pedal sticks to the floor about 15-20% of my shifts. Very sporadic. I just use my foot to pull the pedal back up and its fine again for a while. Is this a common characteristic of a lightweight flywheel?
__________________ 2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line |
04-20-2015, 11:54 AM | #2 |
Rep Power: 0 Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Make sure to check your pedal for cracks.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
04-20-2015, 12:14 PM | #3 |
Rep Power: 0 Thanks: 161
| Not Ranked : 0 score nothing to do with FW weigt, it is probably the pedal mechanism or a bad slave cylinder... As long as everything got installed correctly during clutch replacement... Are you seeing it since day1 of install or just recently ? Did you put mixed new and old parts without checking to stay inside specs ? Sometimes if the height of FW blocs isn't compatible with PP travel and disc thickness, you may experience that kind of issues. But usually you would see the clutch forks to be loose or needing alonger travel to operate... I would check the slave for leaks first...i had to replace mine right after a clutch job and it wasn't funny to manage into traffic with a dead clutch pedal.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 04-20-2015 at 12:54 PM. |
04-20-2015, 12:24 PM | #4 |
Rep Power: 3058 Thanks: 4,683
| Not Ranked : 0 score My oem/fidanza combo doesn't do that, got almost 19K on it now.
04-20-2015, 04:46 PM | #5 |
(Thread Starter) | Not Ranked : 0 score I have checked on the past but I'll get down and look at the pedals again. I bought the 6 modded so I don't know if the slave was ever changed but maybe that's a good place to start. And I would say it's been doing it a few months now so not since day 1 of the clutch flywheel install which were both new a year ago.
__________________ 2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line Last edited by Douggievee; 04-20-2015 at 04:46 PM. Reason: MSF Database - Automerged Doublepost |
04-20-2015, 05:01 PM | #6 |
Rep Power: 0 Thanks: 68
| Not Ranked : 0 score Other than the chatter after driving for a while while not on gear, i've never experienced anything worth mentioning after doing the OEM clutch/Fidanza flywheel combo and especially no clutch issues like the ones you mention. It's probably on your best interest to get a new slave and master cylinders based on your mileage though.
__________________ __________________________________________________ ____________________________ 2008 BM Mazdaspeed3 / Fidanza Flywheel / E-Focus RMM / Bone Stock |
04-20-2015, 11:22 PM | #7 |
Rep Power: 0 Thanks: 593
04-21-2015, 10:28 AM | #8 |
| Not Ranked : 0 score Sure man. Just got your PM check your inbox.
04-20-2015, 09:41 PM | #9 |
Rep Power: 0 Thanks: 205
| Not Ranked : 0 score Maybe corrosion around master cylinder push rod. I've had a 626, several probes, and a ranger do it. The common factor was that none were driven regularly. |
04-21-2015, 06:27 AM | #10 |
Rep Power: 1485 Thanks: 16,886
Groans: 78
| Not Ranked : 0 score bleed - fail replace slave, bleed - partial victory adjust pedal - win my experience. Not with findanza, but I don't think the flywheel has anything to do with your issue.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
04-21-2015, 07:48 AM | #11 |
(Thread Starter) | Not Ranked : 0 score Ok, im gonna have to look into geting the master and slave replaced and see if it clears up
04-21-2015, 08:40 AM | #12 |
| Not Ranked : 0 score make sure to get the upgraded slave with mazda part # finishing by a ''B'' you can search here for full #.
The Following User Says Thank You to Jeff23spl For This Useful Post: | Douggievee (04-21-2015) |
05-14-2015, 08:35 AM | #13 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score my clutch went, car is in the shop for over a week now because only one mazda dealer around and going for OEM clutch.. anyway.. my flywheel may possibly be fuked as well but we wont know until the clutch comes and and we start taking shit apart... if so, i would LOVE to know if the OEM clutch and fidanza combo is safe and that there will be no problems... i really do not want to spend more for an oem flywheel and im sure no one does... THANKs |
05-14-2015, 10:44 AM | #14 |
__________________ __________________________________________________ ____________________________ 2008 BM Mazdaspeed3 / Fidanza Flywheel / E-Focus RMM / Bone Stock | |
05-14-2015, 10:25 AM | #15 |
| Not Ranked : 0 score start looking right now because the oem isn't suppose to be re-usable with a new disc. When i look for one, the price was between 800-1500$ for just the OEM Luk FW... You will have a hard time to find someone to re-manufacture it like we could be used too with, ordinary clutch system, The chance that the FW isn't worn with a failed disc is very thin... Some have found places that work on the oem LUK fw but i think most goes with an aftermarket solid 1 piece FW...Just make some search on msf and you will find manny thread about clutch kits... You will also heard about pro and cont of using a lightweigt FW on the DD use. I have an ACT but i won't suggest it for a stock use...
The LuK clutch with Fidanza Flywheel Combo | CaseyBueno | Mazdaspeed3/6 General Discussion | 22 | 05-14-2015 08:30 AM |
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel | zer010gic | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-15-2014 11:12 PM |
