Search Forum |
12-16-2011, 12:02 PM | #1 |
Rep Power: 0 Thanks: 667
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score The Official Diff Mount Thread One of the weaker links in the MS6 is the rear diff's bushings. You can buy replacement bushings, or if you're hardcore like all of us here on MSF, you'll just upgrade the whole damn mount! Because RACECAR!! The rear diff actually has 2 mounts. Here are ALL the options you have for rear diff mount upgrades. Bushing Upgrade: $44.08 USD - Turbine Tech Bushings Turbine Tech Bushings Stock bushings for reference "Rearward" Rear Diff Mount: $255 - SURE Motorsports Dreadnaught $269.00 - CP-E Rear Diff Mount "Forward" Rear Diff Mount: $245 - SURE Motorsports Juggernaut $289.66 USD - Turbine Tech Differential Mount |
The Following 10 Users Say Thank You to RhoadBlock For This Useful Post: | greenespeed (12-16-2011), jjfam1 (03-08-2012), Juyoung (09-02-2012), MATT DAMOND (10-07-2012), mayer (02-24-2012), Micha (01-07-2014), MS6FL (01-01-2012), MZRSpeeder6 (11-17-2012), phate (05-28-2012), Poohster (12-20-2011) |
12-16-2011, 12:07 PM | #2 |
Two nuns and a pack mule Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 Thanks: 459
| Not Ranked : 0 score My stock bushings were thrashed to oblivion. I have Street Unit's old school Stiff Diff mount. Shifts got a bit tighter. Just like the rear motor mount, this is a necessary upgrade for the MS6s.
__________________ |
The Following User Says Thank You to AtTheDriveIn For This Useful Post: | Juyoung (04-24-2013) |
12-16-2011, 02:31 PM | #3 |
(Thread Starter) | Not Ranked : 0 score Feel free to post your own pics & rants/raves of your diff mounts. The more feedback we get, the better we'll be able to help newer guys looking to upgrade theirs not have to ask too many questions. |
12-24-2011, 12:07 PM | #4 |
Rep Power: 0 Thanks: 2,125
| Not Ranked : 0 score is the full mount recommended or will the bushings suffice? also is a press needed for the bushings or can they be done by hand?
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) |
12-25-2011, 03:19 PM | #5 |
Rep Power: 0 Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score Also, for someone new at this, are any little tools helpful or any extra parts helpful that will/might break while doing the install like bolts sheard off or anything?
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
12-25-2011, 04:00 PM | #6 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score Yes I also wanna know if the bushings are good enough and if a press is needed. The whole brace is expensive! |
12-27-2011, 05:25 AM | #7 |
(Thread Starter) | Not Ranked : 0 score IMHO the bushings would *probably* be good enough, especially if it's mostly just a daily driver and you don't thrash it too hard on the weekends. I don't really recall seeing any snapped factory mounts. It was usually either torn bushings or sheared bolts. I don't know if you need a press to do the bushings or not. I know I did my AWR bushings for my side motor mounts by hand so I couldn't imagine the diff bushings being much harder, but I personally didn't do the bushings. You'll have to do some searching on the forum for bushing install threads. As far as tools, air would be great, phenomenal actually since you're gonna drop the subframe to get the mount out. But it's a pretty straightforward install with basic tools. One note is to install a rear sway bar while you're at it, since you have to take the stock one out to get to the diff mounts anyway. 2 birds, 1 stone. 3 birds if you install both mounts at once too. The price for the mounts actually are pretty good, but if you feel it's too much to swing, you can always check the for sale/classifieds section. Access is for VIP members only. You can find them in good condition for much cheaper every now and then. Here's a pretty good how-to to remove the rear subframe to make life much easier to do the mounts: How-To: MS6 Rear Subframe Removal |
01-01-2012, 03:04 PM | #8 |
Rep Power: 0 Thanks: 2,290
Groans: 43
| Not Ranked : 0 score Great sticky! Just want to add for those of us that have trashed our rear..... -Front Diff case-------------------------------Part#MA2727681 -Bearing--------------------------------------Part#996068206 -Oil Seal--------------------------------------Part#M05427165 -Front Diff mount bolts(the 2 that sheer off)---- Part#H26034037A (I Used 12mm 1.25 pitch Grade 8.8 bolts) -Rear Axle Seals-------------------------------Part#M0A727238A -Bolts (The ones that secure the front diff case to the rear) -------------------------------------Need 2 of Part#M05327604 (Didn't use these as mine were a lil shorter. Dunno why) ---------------------------------------and 6 of Part#907812830 (Only used 4 as the SURE mount came with 2 long ones you need) Pic of mount on the diff case:
__________________ [SIGPIC][/SIGPIC] “From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley Last edited by MS6FL; 02-05-2012 at 10:46 AM. |
The Following 2 Users Say Thank You to MS6FL For This Useful Post: | phate (05-28-2012), RhoadBlock (01-02-2012) |
06-20-2014, 09:59 AM | #9 |
Rep Power: 0 Thanks: 33
__________________ 2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck | |
06-20-2014, 11:14 AM | #10 |
Rep Power: 0 Thanks: 228
Groaned at 79 Times in 52 Posts
| Not Ranked : 0 score One thing I don't understand about T-Case reassembly is setting the lash at the bevel gears. This is typically done with shims, like at the rear diff. With correct lash, a bluing test would show contact at the pitch diameter of each gear. At a minimum, there should be some type of lash specification. Hard to believe you can just bolt it together, when bevel gears are involved. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 06-26-2014 at 10:17 AM. Reason: added shims, deleted crush tube |
07-24-2012, 07:19 AM | #11 |
i was thinking with the bolt issue, what if you get grade 8 bolts along with bushings you think that would help eleminate the shearing issue | |
02-05-2012, 05:13 AM | #12 |
Rep Power: 0 Thanks: 88
| Not Ranked : 0 score Has anyone compared the rear TT + CPE combo vs. the Sure Combo? |
02-05-2012, 09:34 AM | #13 |
Speeeeeed Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 7490 Thanks: 6,190
| Not Ranked : 0 score No because you arent going to break either of them and they are basically the same.
02-05-2012, 07:06 PM | #14 |
| Not Ranked : 0 score I guessed as much, was more thinking in regards to whine etc as AFAIK no one has broken any of the upgraded mounts |
05-26-2012, 08:25 AM | #15 |
Rep Power: 0 Thanks: 124
| Not Ranked : 0 score Ok so yesterday I noticed while downshifting there was a clunk noise which felt like something hitting the bottom of the car. Gotta be a diff mount right? I knew I should of done the diff mounts before AP but I want more Powa!! So question is. Do I stock out go to dealer and have them fix it under warranty or just upgrade the mount now and avoid the hassle. I can just limp around until it's fixed right?
__________________ 07 MS6 Sport............. JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals * |
09-14-2012, 04:25 AM | #16 |
Rep Power: 0 Thanks: 92
Had the sure mount on since i got the car just over a year now. Dissappointing to say the least. I have a clicking type noice that changes with acceleration and if you pull up a couple clicks on the ebrake. Going in tomorrow. pretty sure it is the internals. Fidelity extended warranty is about to get tested... worried they are goung to tell me to shove off because of what is in my sig below...
__________________ Velocity Red Mica 2006 MS6 GT #000517 AP v3 - - ACT Stage 1/pedal reinforced - JBR 80a RMM - Dreadnaught - TWM Stage 2 - Turbosmart BV - Denso20s - Hawk HPS Pads - SPCs - MAZDASPEED CAI - CS SS Braided Clutch Line - CS Bypass Hose - JBR EGR DELETE BLOCK8HEAD POD/PS Boost Guage - RED LED Footwells - CAR LED & Brake Mod - Nokya Yellow H11s/WITH FOGMOD - LED turns Rockford 200w Amp/12" Sub - RPM AUXMOD /// Plasti Dipped - Lots of Things /// REDLINE FLOOIDS - Royal Purple K1 and Wiseco - M2 DP - ETS TMIC - Internals - JBR Trilogy and a BSD | |
05-26-2012, 09:33 AM | #17 |
Groans: 43
| Not Ranked : 0 score Could very well be. Just get under and take a peek at your bolts. I limped around for a bit but wouldn't recommend it if you don't HAVE too. Depending on how cool your service dept is maybe you can go in for warranty and give them the aftermarket mount to put on instead of that oem pos.
__________________ [SIGPIC][/SIGPIC] “From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley |
The Following User Says Thank You to MS6FL For This Useful Post: | weakdog85 (05-26-2012) |
05-26-2012, 09:37 AM | #18 |
Rep Power: 0 Thanks: 4,160
Groans: 201
| Not Ranked : 0 score Definitely upgrade to something aftermarket rather than going with OEM.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
05-26-2012, 01:50 PM | #19 |
| Not Ranked : 0 score Now that's a good idea. I'll check my local nator people and see what they say
The Following User Says Thank You to weakdog85 For This Useful Post: | MS6FL (05-26-2012) |
09-14-2012, 04:57 AM | #20 |
Groans: 43
| Not Ranked : 0 score Well I can tell you Fidelity is one if not the best extended warranty out there. On the other hand warranty direct can go fuck them selfs.
The Following User Says Thank You to MS6FL For This Useful Post: | DPFISUMS6 (09-14-2012) |
09-14-2012, 05:25 AM | #21 |
Rep Power: 0 Thanks: 1,687
Groans: 33
| Not Ranked : 0 score Here are my videos on the stock mounts Front: Rear vs CPE:
__________________ Mazdaspeed6 -06 Tuned with by Alex@Stratified CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
The Following User Says Thank You to SpeedRebirth For This Useful Post: | Juyoung (04-24-2013) |
09-14-2012, 06:39 AM | #22 |
Rep Power: 0 Thanks: 352
| Not Ranked : 0 score what about diff straps always a viable option, been holding it down on my car for 45,000 miles at least!!!!
__________________ 2006 Mazdaspeed6 GT Liquid Platinum Metallic "because racecar!" " I love this $%&*ing car" -Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps -2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete -TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender -Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod -Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge |
The Following User Says Thank You to ESB Jiu JItsu For This Useful Post: | Juyoung (04-24-2013) |
09-14-2012, 05:49 PM | #23 |
This makes me feel warm and fuzzy, but when it comes to them paying a lot off money to fix this car, and they see ehat i have done to it, will they leave me out in the cold? side note, mazda thinks its the drive shaft ujoint, 1300 for a replacement. not e a rear diff issue, they think.
09-14-2012, 06:04 PM | #24 |
Rep Power: 0 Thanks: 496
| Not Ranked : 0 score going to install my sure diff mounts and rear sway bar this weekend, a bit nervous. looked at the how to's. i dont want to mess up.
__________________ ^^^My fail boats^^^ 2006 mazdaspeed 6: fujita CAI, PG TIP, Turbosmart dual BOV, ITV22, Corksprt TBE, Cobb AP, SURE front/rear diff mounts(FTW), whiteline RSB 1978 280z(s30): currently needs some love....and going turbo o.0 1990 300zx: 850cc injectors, 300degree fuel rail, aeromotive FPR, garrett gt 28's twin turbo upgrade(@19psi), stillen IC's, CZP's 3in dp and mid pipe, Selin dual intakes, GTR R32 brakes, Nismo clutch, HKS hi-power exhaust, megan coil-overs, SPL full titanium suspension parts, z1 boost tubes, 2 AEM AFR's, AEM boost guage RWHP:???? RWTRQ: 475@4500 rpm. needs new clutch(blown). 2008 350z HR: Greddy dual Ti-C, Carbonetics LSD, Nismo diff, GTM TP's, Stillen CAI's (waiting on full metal CSC and carbonetic clutch and light wieght flywheel, then it's TT time!) currently on hold due to needing new clutch and flywheel/metal csc and master. wanting skyline manifold. |
10-04-2012, 08:40 PM | #25 |
Rep Power: 0 Thanks: 75
| Not Ranked : 0 score For someone who is not a hardcore track guy and is just trying to prevent serious damage while having fun on the street, is the front or rear diff mount the more necessary purchase? I can always pick up the other down the road, but I'd like to know which of the two is considered more important to upgrade. |
10-07-2012, 08:49 PM | #26 |
Rep Power: 0 Thanks: 5,127
Groans: 75
Groaned at 31 Times in 20 Posts
| Not Ranked : 0 score Hey guys, I installed the SURE Dread and Jugg Diff mounts yesterday. Everything feels freeking awesome!!! Much stiffer on the rear end! I love it. Although... While downshifting I felt a "Clunk" in the rear end. This is after I put on the mounts. I can recreate the noise every time. I've heard of clunks from the stock mounts, but not after the install. I drove it home from our NATOR house this morning and the car runs fine, no squeaks, no grinding, no odd noises other than this. (I swerved my car side to side to see if something was really loose, nothing out of the ordinary.) Any thoughts on what it could be? I did disconnect my Sway bar (No funds for a new one.) I've read it could be the endlinks? or something else? Any help will be greatly appreciated. I'll double check all the bolts to make sure they are tightened down again tomorrow. @RhoadBlock @MS6FL - since you guys have quite a bit of knowledge on this lol
__________________ ///VRM 2006 UNICORN Speed6 GT #02418/// STOCK AS OF 2015... Old Stuff.... /// COBB AP /// AT HPFP /// 20psi Teck5 Tune by Ekanddsm /// JBR RMM /// HTP 3" Intake System /// SURE Dreadnaught and Juggernaut /// /// Denso ITV22 /// Mystery Testpipe /// Fidanza Lightweight Flywheel /// Eagle Motorsports Full-Faced Clutch Upgrade /// /// Megan Racing Springs /// SPC Adjustable Balljoints /// JBR TIGS, EGR Delete and Coolant Bypass /// |
10-07-2012, 08:53 PM | #27 |
Groans: 201
| Not Ranked : 0 score Probably end links IMHO. Did you get them reconnected right?
The Following User Says Thank You to Stealth01 For This Useful Post: | xI Leveler Ix (10-07-2012) |
10-07-2012, 09:19 PM | #28 |
Groans: 75
| Not Ranked : 0 score Yeah I believe so! lol I'll check them out tomorrow. Thanks Stealth.
10-07-2012, 08:54 PM | #29 |
Rep Power: 364 Thanks: 480
| Not Ranked : 0 score The top mount is more important that the front. I have just the Sure too mount and stock front and the difference from stock is amazing. Sent from my ADR6300 using tapatalkreplace 2
__________________ CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers! |
10-07-2012, 09:25 PM | #30 |
| Not Ranked : 0 score i think this is a good place for this went to the track one night, took off fine, shifted into 2nd, heard a boom and hit redline. quick systems check, hit the gas and kept going lol. took the left axle with it so the driveshaft shop replacement is on the way. its actually marginally cheaper than the oem after the core price...
The Following User Says Thank You to chuckms6 For This Useful Post: | Micha (05-21-2014) |
10-07-2012, 10:04 PM | #31 |
I have candy in my van Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 Thanks: 4,091
Groans: 70
| Not Ranked : 0 score After doing roughly a dozen diff mount installs(I cannot remember the exact number), I'll share my opinions on the subject. First off, the stock rear diff mount(the one with 2 bushings), should be upgraded on pretty much every MS6. Every mount I've pulled, even once on a MS6 with 14k miles, the bushings were completely shot. The OEM bushings of the rear mount are a poor design, and they allow for way too much flex of the diff. That's why ppl break the rear diff mount, front diff casing, or the front diff mount at the bolt holes. For 90% of the MS6's out there, you really only need to upgrade one mount. The 10%(you know who you are), pushing lots of power, doing many launches, tracking, and hitting up the strip, it's better to have both of the mounts upgraded. But for the occasional launcher, daily driver, light track duty, 90% only need to really upgrade the REAR mount. Upgrading the rear mount, will pretty much take all the flex out of the diff, under high loads, launches, etc. If you upgrade to just a front diff mount, you'll still get the diff to flex, since the OEM bushings in the rear are garbage. This could lead to the rear mount breaking, and the cases could crack. As for which mounts are the best, the rears are all pretty much the same. They're all beefy as fuck, they have little to no flex in the bushings, and they cost roughly the same. I don't really recommend just adding the TT rear bushings, unless you don't plan on launching the car. They still use the rear cast mount, and it can still break. For the front diff mounts, I'd recommend the TT FDM over Sure's FDM. Simply because it has more mounting points, and more effectively "wraps around" the diff. However, the FDM's are really only need for the 10%, and once the rear has been upgraded, adding either FDM will have the same effectiveness. As for NVH, you'll barely experience any with the mounts upgraded.
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project |
The Following 17 Users Say Thank You to MATT DAMOND For This Useful Post: | 6ixof1 (10-15-2012), 6not3 (05-03-2014), ButtholeRedMS3 (08-23-2015), Docnox (06-24-2016), dot584 (10-07-2012), dvcn (06-07-2016), Funkster777 (01-03-2014), jucca (09-20-2013), Juyoung (04-24-2013), Micha (01-07-2014), MZRSpeeder6 (11-17-2012), RhoadBlock (10-08-2012), silvapain (10-08-2012), SpeedRebirth (02-27-2014), Speed_j23 (10-11-2012), xI Leveler Ix (10-07-2012), Zoomer_Esiason (10-11-2017) |
10-08-2012, 06:48 AM | #32 |
Groans: 201
| Not Ranked : 0 score I would caution against any decisions based on whether or not you plan on launching the car. My front diff mount bolts sheared when my wheels slipped on ice, then caught on dry pavement a moment later. Same thing could happen with sand, water, etc. Same could happen with the rear brace.
01-04-2014, 02:11 PM | #33 |
But, when they first started selling this special model, it was the front mount that had equal or more failures, due to BENDING FATIGUE of the 2 bolts at the 1st thread. These bolts DO NOT fail by SHEAR (see the smooth fracture surface in the next link). Once this happens, the contact surface at the two soft aluminum casing bosses were rounded off at the edges, allowing even more rocking at this interface after new bolts were properly installed: Bolt Failures, front mount Because this compromised fit of the front mount if a bolt failed in fatigue, and the multiple owners of many cars, I think for reliability, the front mount should be replaced with the Turbine Tech mount, that we both agree is the best choice. This front mount eliminates the critical bending loads on the 2 side bolts. Note that this offset, one sided front mount was a design error by Mazda, that was corrected with the same AWD differential design for the Cx-7. They used symmetric left and right side front mounts, each with two bolts to the casing with vertical separation, and not the incorrect horizontal sepatation like the MS6. Cx-7 AWD differential Front Mount This setup is currently used in a custom AWD MS3, putting down 625 hp and 570 ft-lbs of torque to 4 wheels ... with oem mounts!. pte-6466-awd-conversion .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 10-03-2015 at 10:58 AM. Reason: NEW PIC of Failed Bolts, added Cx7 AWD mounts | |
10-07-2012, 10:44 PM | #34 |
| Not Ranked : 0 score I noticed nothing different NVH wise with the rear different mount. If anything it felt smoother all around. I agree every 6 should have this even if you never plan to launch or go to the track. Shifting gets easier, less slop ect Sent from my ADR6300 using tapatalkreplace 2
01-03-2014, 08:03 AM | #35 |
Rep Power: 0 Thanks: 205
| Not Ranked : 0 score For those who bought the SURE mount(s), which durometer of bushing did you buy? |
01-04-2014, 12:55 PM | #36 |
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | |
01-03-2014, 08:26 AM | #37 |
Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 Thanks: 3,349
| Not Ranked : 0 score Turbine Tech and Corksport
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post: |
01-04-2014, 01:37 PM | #38 |
| Not Ranked : 0 score From an engineering stand point, the CP-e rear mount is the only rear mount I would choose, tough steel design, and most important, 60 Duro bushings. " ... bushings are 60-duro rubber inserts that positively locate the differential, but will not rattle your passenger’s teeth out ... " The stiff bushings others use are for suspension arms or sway bars, where you want minimal deflection. For the front mount, Turbine Tech for the best spreading of the attachment to the case on the driver's side (opposite side to the original 2 bolts). I had posted about this type of fix back before TT released their design. The Sure looks like a good 2nd place. .
02-27-2014, 07:14 AM | #39 |
Rep Power: 0 Thanks: 475
Groans: 51
| Not Ranked : 0 score Just an update, Turbine Techs website is broken. You have to send them an email with what you want and they send you an invoice. |
02-27-2014, 07:22 AM | #40 |
Rep Power: 0 Thanks: 53
| Not Ranked : 0 score Does anybody know / can find out what are the size of the bolts that hold front part of diff to the rear? I got TT front mount used and it didnt have any hardware, but in the instruction it says to use longer bolts, i need to know what are they, can somebody help?
__________________ ---------------------------------------- Building it from ground up: |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/official-diff-mount-thread-99783/ | ||||
Posted By | For | Type | Date | |
Diff Mounts/Braces | This thread | Refback | 02-05-2014 07:35 PM | |
uprated diff bushes vs. uprated diff mounts | This thread | Refback | 01-29-2014 09:42 PM | |
Diff Mounts/Braces ? Mazda MPS Owners Club | This thread | Refback | 12-03-2013 01:02 AM | |
Power upgrade concerns or tips? : mazda | This thread | Refback | 03-26-2013 02:12 PM |
Rear diff locks while turning after SURE diff mount and brace install | wettoast | MazdaSpeed 6 - Engine, Transmission & Driveline | 47 | 11-04-2018 04:50 PM |
rear diff "stiff diff" brace vs. rear diff front mount | giordanos4 | MazdaSpeed 6 - Engine, Transmission & Driveline | 18 | 03-03-2011 08:38 AM |
