Welcome to Mazdaspeed Forums
Search Forum
 Old 07-18-2008, 08:29 PM   #1
JimmyMac's Avatar
Posts: 558   (View Stats)
JimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the world
Thanks for the info.
So what setup did you go with? Did you change out the WGA? Or did you just use the quick tap? I'm currently (and have been) using the quick tap. Maybe I should try and tee it differently....? I don't think I have a 14.7psi spring in my WGA. When I put the turbo on for the very first time, I just ran the line from the WGA to the quick tap (same exact location in the pic on the ATP site linked) and left the stock boost control solenoid capped off. So my boost was all mechanical at the time. It would only reach 9-10psi.
Hmmmmmmmm..............
2012 MX-5 SE
JimmyMac is offline   Reply With Quote
 Old 07-18-2008, 09:07 PM   #2
phailerider's Avatar
Posts: 4,639   (View Stats)
you got to put the restrictor in the line bro..... i had the exact same problem. they talk about the size in the link in that thread.
after i put it in.... my turbo held like a charm..... you may need to mess with the pid settings on the standback though. nice oppurtunity for some street tuning once you get the restrictor in there.
even without tuning the PID values.... you'll still hold boost though. It just wont be real smooth unless you get lucky.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/gt-series-turbo-questions-8572/
albuquerque nm mazda 6 owners - Mazda6 / Atenza This thread Refback 02-15-2009 10:36 AM
ENDING: lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) Haltech Hot Deals Section 0 04-10-2008 05:21 AM
Expiring: lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) Haltech Hot Deals Section 0 04-07-2008 07:02 AM
lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) Haltech Hot Deals Section 0 04-04-2008 09:50 AM
EXPIRING lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) Haltech Hot Deals Section 0 03-27-2008 11:50 AM
lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.27176 seconds with 23 queries
