MazdaSpeed 3/6 - Turbo Induction MazdaSpeed 3/6 - Turbo Induction - Have a turbo, intercooler, downpipe question? Anything turbo related belongs here! |
Search Forum |
02-22-2009, 03:19 PM | #1 |
Rep Power: 0 Thanks: 2
(Thread Starter) | Not Ranked : 0 score q"s for all big turbo disi cars Whats the most boost you can run before the tp closes? i'm still trying to diagnose my cut issue and i'm cutting at 15.xx psi but i can't boost more because the car falls on its face. I know this has been killed on the forums but i can't find it written out...cut and dry.
__________________ I hate my mazdaspeed3 more than anything else in this world! |
02-22-2009, 04:18 PM | #2 |
ILL3ST Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 Thanks: 3,292
Groans: 105
| Not Ranked : 0 score sorry if you've covered this in another thread. but have you tried getting the cp-e fuel cut flash? my friend with a bt ms6 couldn't go WOT in 3rd gear for the longest time because of the cut - no more cut after getting the new cp-e flash. |
02-22-2009, 06:15 PM | #3 |
Rep Power: 2562 Thanks: 1,586
Groans: 125
| Not Ranked : 0 score i personally havent had any fuel cut issues. 17psi on a 3071r... havent hit fuel cut once. dont know how to help you. Your using a standback right? whats your fueling/timing maps look like?
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
02-23-2009, 01:47 AM | #4 |
Speeeeeed Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 7490 Thanks: 6,190
| Not Ranked : 0 score I am not at all sure that the throttle plate and fuel are related, if you have a SB and the 3.5" maf and I am going to assume the ECU flash to go with it and a CDFP... you shouldnt be cutting at 15psi unless something is set wrong.
02-23-2009, 05:23 AM | #5 |
Groans: 125
| Not Ranked : 0 score im not sure if hes running the 3.25" maf housing or the big maf flash just yet... but ill let him throw that one out there.
02-23-2009, 06:06 AM | #6 |
Fux Wit It Join Date: Mar 2008 Location: Li
Rep Power: 10 Thanks: 7,795
Groans: 175
Honestly if your car is falling on its face that means your out of fuel for some reason or your TP is down to like 50% and lower. since a bigger turbo has power later in the rpm band plus the fact you have the ecu butt fucking you by closing the plate around 5600 rpms and up your car feels lethargic.
__________________ Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
02-23-2009, 06:55 AM | #7 |
(Thread Starter) | Not Ranked : 0 score Ecu is out for the flash. i'm running the perrin so I have to scale the boost in standback. right now in the standback i'm at 29 and 31 lbs my biggest problem is the minimum boost i suppose to be running is 1.1 bar...so like 16.5 lbs. just tell what to log in the dashhawk to diagnose this problem and i'll do it.
02-23-2009, 10:51 AM | #8 |
Groans: 105
| Not Ranked : 0 score well let us know if you're still having problems post-flash. |
02-23-2009, 11:20 AM | #9 |
| Not Ranked : 0 score Dont log with the dashhawk, that is your first problem. Log with the standback.
02-23-2009, 11:26 AM | #10 |
Rep Power: 0 Thanks: 225
| Not Ranked : 0 score I don't understand the problem you're having. We installed the Perrin ECBS on a client's car recently and had no issues with the scaling of boost using the standback, eg. 15 psi = 15 psi. The PID parameters are different but that doesn't fit the scenario you're describing. The TP closure is eliminated with the fuel cut flash. Otherwise, numerous factors will cause it to close. |
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 1441 | 06-25-2019 06:11 PM |
Manley "turbo tuff" I-Beam connecting rods *oem replacements | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 02-12-2009 04:40 PM |
duPont Registry's 11 "Best of" cars set horsepower, price records | Haltech | Automotive News | 0 | 10-09-2008 08:00 AM |
CARB requires all new cars in California to bear "green" labels | Haltech | Automotive News | 0 | 06-30-2008 03:30 PM |
Suzuki SX4t: "t" is for turbo, courtesy of Road Race Motorsports | Haltech | Automotive News | 1 | 04-23-2008 11:51 AM |
