Welcome to Mazdaspeed Forums
Search Forum
 Old 03-31-2019, 02:19 PM   #1
Izapyou's Avatar
Posts: 41   (View Stats)
Izapyou has a spectacular aura aboutIzapyou has a spectacular aura about
Default Lateral Links (HELP)
So I'm not sure what the issue is, but I just replaced everything in the rear of a mazdaspeed 6 minus the differential. The issue I'm having is my toe is still out and cant be adjusted even though the link is all the way in. Everywhere I've been to the link is curved on 1 end (on the inward side of the car) but yet the stock one was straight. I did find a set of aftermarket ones that are straight like the factory ones that came out but don't have a clue as to how the fit because the angle at which the spindle and the subframe currently sit don't seem to line up. I need help on what I'm doing wrong so I can fix this asap.
Izapyou is offline   Reply With Quote
 Old 03-31-2019, 05:41 PM   #2
Izapyou's Avatar
Found the correct ones finally now the toe looks more adjustable then where it was sitting originally. Really can't stand most of these aftermarket parts stores. Admin you can remove if you'd like.
Replacing the rear lateral links div2 MazdaSpeed 3/6 - Suspension & Brakes 2 04-13-2015 06:52 PM
Excessive lateral run out: stock tire 1990tsi 2010 MS3 - Wheels & Tires 3 07-17-2013 01:29 PM
end links autotech88jtaw CX-7 > Engine, Transmission & Driveline 2 02-22-2012 08:19 PM
Page generated in 0.22960 seconds with 20 queries
