Welcome to Mazdaspeed Forums
Search Forum
 Old 05-29-2012, 12:26 PM   #1
ms6_nate's Avatar
Posts: 35   (View Stats)
ms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud ofms6_nate has much to be proud of
Default Strut Help
Ok ladies and gentlemen heres my question,
I am trying to find a good adjustable strut to hook up with my Tein Stech springs. I am seriously considering Koni Yellows, since at low setting it should be nearly stock and at high setting, should be firm for auto x. My issue is that I cant find a fucking listing for anything for my speed 6. I called KONI and they only list the 6s and 6i FWD not the AWD mazdaspeed 6, and apparently, although from my understanding they still fit, the valves and set up for them would not work properly for my car. So heres my question, are ppl suing these flawlessly on speed 6 or is their an alternative that lists for a mazdaspeed 6 AWD application that I cant seem to find? I dont want coilovers, mostly becuase i like the spring rates on stech and tein stuff, but i want adjust ability and they dont offer SS for our cars.
ms6_nate is offline   Reply With Quote
 Old 05-29-2012, 12:48 PM   #2
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Have you used the search button.. theres suspension threads everywhere.
search for 24 hours.. then ask a question if no where to be found.
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
The Following User Says Thank You to silentwolf8 For This Useful Post:
Big_Burd (05-29-2012)
Where can I buy ms3 strut mount? clash0901 MazdaSpeed 3/6 - Suspension & Brakes 12 01-06-2012 04:00 PM
strut bar? bombdotcom MazdaSpeed 3/6 - Suspension & Brakes 4 02-12-2010 11:37 PM
Page generated in 0.23413 seconds with 21 queries
