> CX-7 > Accessories
Welcome to Mazdaspeed Forums
Search Forum
  • 1 Post By lvdukerider
 Old 07-30-2014, 03:08 PM   #1
DrewFlu33's Avatar
Posts: 16   (View Stats)
DrewFlu33 will become famous soon enoughDrewFlu33 will become famous soon enough
Default Hitch Wiring - External plug options?
I suppose this is the place to put this one. I'm looking to add a trailer hitch to my 2010 CX-7 Touring, and have shopped around for various hitch wiring harnesses. They all seem to be designed to be left inside then hung out the back when in use.
Has anyone found a harness or figured out a way to get the plug mounted outside, on the hitch? I'd prefer this much more than having to hang wires out the back when I've got something hooked up. I've found some how-tos that allow this on the CX-9, and I'm wondering if anyone has done the same with the CX-7.
DrewFlu33 is offline   Reply With Quote
 Old 07-30-2014, 06:38 PM   #2
lvdukerider's Avatar
Posts: 44   (View Stats)
lvdukerider has a spectacular aura aboutlvdukerider has a spectacular aura about
Did exactly that with my 2010 GT. I purchaced the factory pig tail from Mazda which plugs right in the stock harness, the connection is behind the right rear plastic trim panel in the cargo area. It then goes through a hole in the floor which is sealed with a rubber plug. Very ease do it yourself install.
Alpha Wolf likes this.
lvdukerider is offline   Reply With Quote
 Old 08-04-2014, 03:42 PM   #3
DrewFlu33's Avatar
Thanks for the reply!
Do you have any sense of whether a non-OEM plug would be able to do the same? I'm mostly concerned with sealing around the pass-through point. Or am I better off just getting the Mazda pig tail and going with it?
 Old 08-04-2014, 09:43 PM   #4
I went with the Mazda plug just for the clean and instalation but I dont see any reason you cant use any other plug, you just have to probe the wires and splice it into the harness. If I remember right I think theres already a rubber plug in the right rear floor to run the wires through, forgive my memory as I did mine four years ago shortly after purchace.
MS3 Tow Hitch cesaros Gen2 MS3 General Discussion 30 05-20-2013 04:15 PM
Hitch options?! json CX-7 > Accessories 7 02-13-2013 10:06 AM
Curt Class I hitch and wiring harness SRTie4k Mazdaspeed3/6 General Discussion 10 07-31-2011 01:34 PM
Apricorn Aegis 250GB USB 2.0 External Portable Hard Drive w/ Built-In Plug $95.99AR Free Shipping Haltech Hot Deals Section 0 04-04-2008 02:20 PM
Page generated in 0.23922 seconds with 21 queries
