Ohlins coilovers review Year 97 My old suspension (AGX/ Eibach) was good, but just wasn't good enough. A little too bumpy on the streets and not stiff enough (yeah I know). Let me say that just it a shame that you can't leave them off the car because the quality of their product is fantastical. Installing was way easier than any shock and spring setup (no spring compressor needed) and was very straight forward. Took about 3 hours including adjusting ride height, which is set to 12.5 fr 13r for now until it settles but I expect it not to do much of that because how much stiffer the rates are 8kg fr 6kg r or 450lbs fr 336lbs r . Dampers are set to about 6 fr 3 r , for street use and 24 f, 12 r for autoX/track use. These coilovers have a range of 32 for adjustment. Will anyone use them all.. prolly not. Intial Driving Impression: Holy SXXX. The Ride is much stiffer yet way more comfortable than older setup (boo..bumpstop).Railroad track are much more pleasant, small bumps are invisible, but pothole still let you know they are there. Steering response is strong and crisp. Squat and dive are practically zero and can feel what the brakes are doing better. Took an insterstate loop at higher than normal speed and theres no more rear tail wagging. Body-roll is about gone but slight. Cornering is great and gives the driver more confidence. I would definately recommend this setup or even the PCV's for anyone who does lots of autoXing/ track, but still wants a good ride for the streets. My current alignment specs are as follow: (variation of Lanny's) Front: -1.2* camber 1/16'' total toe-in (1/32'' per side) 5.0* Caster Rear: -1.8* camber 1/16'' total toe-in (1/32'' per side) this gave my car more mechanical grip than I did with Icehawks specs that had toe-out and more camber. I give Ohlins 2 thumbs up Here are some pictures For your enjoyment and if you have any questions, just ask. Ohlins in a box: http://i230.photobucket.com/albums/e...9/100_0414.jpg Fronts installed: http://i230.photobucket.com/albums/e...9/100_0424.jpg End-link clearance at droop(bulky RB's): http://i230.photobucket.com/albums/e...9/100_0423.jpg Front Adjuster on pillowball mounts: http://i230.photobucket.com/albums/e...9/100_0427.jpg Fronts at full droop total est 2in: http://i230.photobucket.com/albums/e...9/100_0428.jpg Rears installed: http://i230.photobucket.com/albums/e...9/100_0429.jpg |
Ohlins are so badass. |
OHLINS FTW. My next mod for my ZX10! |
mr has big pockets! |
hey, just realized I've jinxed this car's radiator before |
I absolutely love the feel of My Ohlins, SOLID choice on a suspension upgrade! |
one day...... |
Fuuuuuck you got them new! How much? Shit was prolly worth more than the car. |
Quote:
$2500 for those Ohlins is a solid price if they are at least 3 way adjustable |
