Miata MX-5
> Miata - Engine Conversions
 Old 02-25-2016, 05:47 PM   #1
txsilverado's Avatar
Posts: 1   (View Stats)
txsilverado is an unknown quantity at this point
Default Picked up an 05 MSM with thrown rod.
This is my first post & I am diving right in. I found an 05 MSM in Black Mica with a thrown rod. This is a project I am taking on with my youngest nephew who has recently become a Miata enthusiast. We currently have the drivetrain out and are stripping the motor down. He wants to do a rebuild on the original motor with Eagle rods, aftermarket forged pistons "Wiseco?", & ARP studs. I am currently discussing balancing the rotating assembly with him as well. Anyway, he wants to do a replacement Garrett turbo setup with stock ECU for now. I am for this, however can he save any $ by buying something other than the FM kit? Keep in mind, I am a decent mechanic. However, I am NOT a fabricator!
2005 Mazdaspeed Miata
txsilverado is offline   Reply With Quote
 Old 02-26-2016, 03:34 AM   #2
SeanE's Avatar
Posts: 594   (View Stats)
SeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the worldSeanE is the leader of the world
First of all, welcome. If you decide to keep the stock ecu, you'll soon discover how much it sucks. if you're taking that much time to rebuild the engine, i'd invest in an aftermarket ecu. Either Hydra or the plug and play megasquirt unit for our cars. The stock turbo will put out adequate power with a capable ecu.
As far turbo kits, FM is the name everyone goes to. It may cost more than putting together your own kit, but like you said you're not a fabricator, and the fm kits come with everything you need.
I'm on two other sites: mazda-speed.com which is a site just for msm's and miataturbo.net which is a great site with lots of information. mt.net won't tolerate stupid newbie questions so like our site here, search and read. You'll learn everything you need to know to do the turbo build the right way.
Sean E.
2005 MSM (Lava Orange)
Enthuza downpipe, midpipe, XR exhaust, Flyin' Miata Full Intake Kit, custom made clutch with lightened stock flywheel, block8head vent gauge pod
2017 Chevy SS (Orange Blast Metallic)
SeanE is offline   Reply With Quote
The Following 2 Users Say Thank You to SeanE For This Useful Post:
Code Monkey (02-26-2016), sporkbomb (02-26-2016)
 Old 02-26-2016, 06:26 AM   #3
Welcome.
 Old 02-26-2016, 02:09 PM   #4
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Do not put any other turbo on that car without a standalone ecu, and larger injectors. The MSM has 265cc injectors. Yes, the same size injectors as your run of the mill 100whp Miata. Not to mention, the ECU does not go into open loop until 5k, meaning, there is already a lean spot between when the stock turbo reaches full spool, and when the ECU starts giving the motor adequate fuel.
No money can be saved once you upgrade the turbo, you are looking @ 2k+ just for the ECU, injectors, and tuning. It is quite a can of worms with regards to the oil drain back from the OEM catch can, and the intake system, the tiny intercooler, the useless rubber throttle body inlet and fmic piping. Lots of supplementary modifications need to be made to get that motor over 250whp, reliably, so good luck.
Past Mazdas & Speeds
SeanE (02-26-2016)
Permanent erection lawsuit against BMW thrown out Haltech Automotive News 0 03-19-2014 05:40 PM
The gauntlet is thrown: VW Jetta TDI vs. Toyota Prius Haltech Automotive News 0 09-24-2008 10:30 AM
McLaren appeal over Hamilton penalty thrown out of FIA court Haltech Automotive News 2 09-24-2008 08:27 AM
Gauntlet thrown: Corvette ZR1 laps the 'Ring in 7:26.4 Haltech Automotive News 0 06-27-2008 11:10 AM
Page generated in 0.25313 seconds with 23 queries
