MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
Search Forum |
11-17-2014, 04:12 PM | #1 |
Rep Power: 0 Thanks: 19
Groaned at 7 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score Not sure what to make of this, log included I've been noticing my AFR sometimes as low at 8.8 and was logging my drive all the way home today and caught something but I don't know what to make of it. I was driving on the highway and it felt like I lost a bit of power all of the sudden while cruising and I immediately let off the pedal and and everything seemed fine the rest of the way home. The logs are in this spreadsheet under the worksheet 'Issue'. You can see the AFR suddenly drop to 8.96 and then WGD jump to 57% out of no where. I have been getting a P0401 for the EGR exhaust gas recirculation insufficient. Not sure if that could cause something like this. I also did a quick 2nd gear WOT to see what would turn up in the logs. In that one you can see the AFR is really rich dropping down into the 9s. The logs for this is in the same spreadsheet above under the '2nd WOT' worksheet. Does anyone know what to make of these or should I be concerned? My mods are BNR S1, HTP 2.5" Turbo Inlet, GS EBCS, and Freaktune OTS+Map. Last edited by ddevil; 11-17-2014 at 04:41 PM. |
11-17-2014, 05:22 PM | #2 |
Rep Power: 0 Thanks: 6,760
Groans: 42
| Not Ranked : 0 score Might want to actually attach the file here instead of a link somewhere else. 2nd gear log isn't going to give us anything. Try 4th or at least 3rd. If AFR is dropping and holding 8.8 you probably have a mechanical issue somewhere. IE. boost leak, but I would get with @Justin@Freektune since he is your tuner
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
The Following User Says Thank You to chaser27 For This Useful Post: | ddevil (11-17-2014) |
11-17-2014, 05:34 PM | #3 |
Rep Power: 0 Thanks: 52,496
| Not Ranked : 0 score @Justin@Freektune.com; You are having some sort of electrical issue, imo. For whatever reason, your throttle position is spiking to what the ecu thinks is full throttle. I would 1) clean the connection @ the throttle body 2) hard reset the ecu. 3) Wait until Justin gets with you until you drive the car hard. This is likely just a bad connection and nothing overly concerning. When the ecu interprets the TP as full throttle, it is driving the bcs so you see wgdc spike. |
The Following User Says Thank You to rfinkle2 For This Useful Post: | ddevil (11-17-2014) |
11-17-2014, 05:36 PM | #4 |
Rep Power: 0 Thanks: 2,861
Groans: 126
| Not Ranked : 0 score Provide a little more info too, Year/model/mileage of the car?
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
The Following User Says Thank You to ASHMS3 For This Useful Post: | ddevil (11-17-2014) |
11-17-2014, 05:39 PM | #5 |
(Thread Starter) | Not Ranked : 0 score Thanks, I'll try those as soon as I can. I emailed Justin a couple days ago but haven't heard back yet. I'll go ahead and send him the logs and take it easy on the car until I can get a response. 2007 MS3. 94k but with a brand new motor and turbo. About 500 miles on those. Last edited by ddevil; 11-17-2014 at 05:39 PM. Reason: MSF Database - Automerged Doublepost |
The Following User Says Thank You to ddevil For This Useful Post: | ASHMS3 (11-17-2014) |
11-17-2014, 05:46 PM | #6 |
Rep Power: 3180 Thanks: 7,265
Groans: 665
| Not Ranked : 0 score You need to take WOT logs in at least 3rd gear, preferably 4th. Your also missing some important parameters to log, like Injector Duty Cycle. Just log everything. When you experience the power drop and AFR going rich, is it under hard acceleration? Do you have the wheel turned at all? When you see AFRs drop into the 9.xx region it's usually do to SWAS intervention. |
11-17-2014, 05:55 PM | #7 |
The short power drop was while cruising on the highway going straight. I believe I was going over a dip in the road though which could possibly have triggered SWAS? Not sure what would cause the low AFR though for the 2nd gear log. | |
Looking to buy(link included) | druddock | Mazdaspeed3/6 General Discussion | 13 | 11-09-2012 01:42 PM |
Am I on the right track? log/map included | torq | 2010 MS3 - ECU Computer Tuning | 11 | 10-27-2012 12:20 PM |
Car is feeling sluggish.. log included | CornBread | 2010 MS3 - ECU Computer Tuning | 23 | 10-11-2012 10:28 PM |
Marketing 101: Make stuff up, make it visible - BMW's subtle 1-Series shilling | Haltech | Automotive News | 0 | 04-13-2008 08:51 AM |
