MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
Search Forum |
08-03-2012, 08:18 PM | #1 |
Rep Power: 0 Thanks: 0
(Thread Starter) | Not Ranked : 0 score oil consumption?? i changed my oil about 2000 miles ago and put in 6 qts and i checked my oil today and it showed almost just above the min line i waited a good couple hrs after i drove it so the oil could fall down to the oil pan.. i have about 155psi in all cylinder for compression |
08-03-2012, 08:52 PM | #2 |
Rep Power: 0 Thanks: 545
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
08-03-2012, 09:19 PM | #3 |
Rep Power: 0 Thanks: 503
| Not Ranked : 0 score pull, wipe, reinsert, pull, read magic
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
08-03-2012, 09:24 PM | #4 |
(Thread Starter) | Not Ranked : 0 score Same thing when I rewipe and reinsert and I'm using penz ultra 5w 30 |
08-04-2012, 05:34 AM | #5 |
08-04-2012, 02:18 PM | #6 |
(Thread Starter) | Not Ranked : 0 score 82xxx and yest i do get some dark smioke when i go wot but i think its fuel more then oil but i dont really know i have 5% tint all the way around |
02-13-2014, 07:19 PM | #7 |
| Not Ranked : 0 score Good evening all, Any update on this thread, other causes of exsessive oil comsumption, I have the same issue, no varience in compression, no smoke on idle, smoke on WOT but its dark, I have used about 5 litres of oil over the last 10,000km. I am looking for suggestions on things to start checking/replacing. Thanks in advance! |
High Oil Consumption | RichieRichness | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 11-09-2016 11:01 AM |
huge increase in fuel consumption | d_crew_man | 2010 MS3 - Troubleshoot/Diagnostics | 17 | 07-24-2011 09:16 PM |
A glass of water a day can help keep your fuel consumption at bay | Haltech | Automotive News | 2 | 07-24-2010 08:06 PM |
Fuel Consumption | corbs | Mazdaspeed3/6 General Discussion | 12 | 04-13-2009 03:22 PM |
Mazda to cut fuel consumption 30 percent by 2015 | Haltech | Automotive News | 0 | 06-23-2008 06:50 AM |
