MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
Search Forum |
08-04-2013, 01:48 PM | #1 |
Rep Power: 0 Thanks: 93
(Thread Starter) | Not Ranked : 0 score Parted out, stock tune -- constant knock? Hi, This past week I've started parting out my car but have the following still on: JBR 80 duro TMM COBB Intake + TIH Denso IVT 22 PTP HPFP COBB XLE Couldn't change any of the parts above because I don't have the stock parts and am waiting for them to arrive. I put the stock tune on and took it for a test drive monitoring knock. I get a constant knock of 7 without fail. Every time I press the gas it reads 7 knock and when I let off I get 0. Did a solid 10 minute test with the same outcome every time. I also had a catted CPE DP which smelt slightly of gas when running, when I put the OEM DP in it smells 10x worse. Did some research and there seems to be no posts with the same issue. Could it be the plugs? Stock tune? It seems to be idling fine but smells too strong of gas. During the day there is also what I think to be more than usual smoke coming from the exhaust (as in if I can see it during the day there's too much smoke -- usually I wouldn't be able to), the smoke is light gray so doesn't seem to be burning oil or coolant. Any idea? I'm worried about running logs or even running the car too long..
__________________ 2007 Mazdaspeed 3 -CP-e CATTED DP-PTP HPFP-COBB SRI-COBB TIP-COBB XLE-COBB AP FREEKTUNE-DENSO ITV24-JBR CHROME MOLLY-JBR PMM-JBR TMM-JBR OCC-JBR RSB-RALLY ARMOR-DASHHAWK-E4P STS-DEFI GAUGES-RL COILOVERS- |
08-04-2013, 01:50 PM | #2 |
Rep Power: 0 Thanks: 759
| Not Ranked : 0 score 7 could be a false reading. Were you in wot when those points came up? And maybe post a log. I would think false reading, cause 7 is a little outrageous. |
The Following User Says Thank You to ABloodBrother For This Useful Post: | curlyface (08-04-2013) |
08-04-2013, 01:53 PM | #3 |
I was thinking it might be because my PMM is super weak, my TMM is the only remaining MM with any balls and my engine is seemingly shaking like a bitch.
__________________ 2007 Mazdaspeed 3 -CP-e CATTED DP-PTP HPFP-COBB SRI-COBB TIP-COBB XLE-COBB AP FREEKTUNE-DENSO ITV24-JBR CHROME MOLLY-JBR PMM-JBR TMM-JBR OCC-JBR RSB-RALLY ARMOR-DASHHAWK-E4P STS-DEFI GAUGES-RL COILOVERS- | |
08-04-2013, 02:08 PM | #4 |
| Not Ranked : 0 score We had some people in our krew hitting numbers like 8.2 and what not. It was definitely false reads. Didnt look to see if you had gen one. I guess the update on ap made the knock sensor extremely sensitive. Not saying that's exactly what it is but IMO it is most likely just that. I had a legit reading of 4.0 once and the number scared me but not nearly as much as the actual feeling! Car felt like it hickupped and was bout to smack the ground haha. |
08-04-2013, 02:10 PM | #5 |
(Thread Starter) | Not Ranked : 0 score My car is a Gen1, the other thing throwing me off is the smell of gas in the cabin. I was supposed to take the car for a 4 hour road trip today (although I have another I prefer not to use) but I guess that won't be happening now and I'll take the other to be on the safer side. Any other tests I could run to see if maybe taking it today is still an option?
08-04-2013, 02:17 PM | #6 |
| Neutral : +1 score
I would definitely log tho. That could answer more of your worries and you could post em here. Definitely would get some answers from that. If when wot car does anything odd just immediately let off. Throw in neutral if needed. | |
08-04-2013, 02:23 PM | #7 |
(Thread Starter) | Not Ranked : 0 score Well I was running a catted DP and it smelled less of gas than my stock DP does now which is why I think it's weird.
08-04-2013, 02:23 PM | #8 |
Rep Power: 0 Thanks: 5,963
Groans: 47
| Not Ranked : 0 score The smell of gas and the engine shaking sounds like it could be misfiring. Have you checked the plugs? You should be running OEM plugs now, not the step colder plugs. They could be fouled and causing a misfire.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs |
08-04-2013, 02:24 PM | #9 |
(Thread Starter) | Not Ranked : 0 score How can I check? I have no CEL although the car has ran a grand total of 10 minutes since we started the part out
08-04-2013, 02:25 PM | #10 |
Groans: 47
| Not Ranked : 0 score I added a bit more to my post. Try pulling the plugs to see if they are fouled.
The Following User Says Thank You to sidekick For This Useful Post: | curlyface (08-04-2013) |
08-04-2013, 03:08 PM | #11 |
| Not Ranked : 0 score Didnt even realize op says itv22. If your stock listen to @sidekick; you want oem plugs. |
The Following User Says Thank You to ABloodBrother For This Useful Post: | sidekick (08-04-2013) |
08-04-2013, 03:17 PM | #12 |
Rep Power: 0 Thanks: 975
| Not Ranked : 0 score Had same issue just recently. Like clockwork, on part throttle - up to 5-6kr. I pulled plugs and retigtened, plus switched toon, and went away. I think one plug backed out. Aside, you can feel real kr. And to make sure rods are ok, go find a big hill and low gear it up the hill and compression down it.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
The Following User Says Thank You to jm211 For This Useful Post: | curlyface (08-06-2013) |
08-05-2013, 03:39 PM | #13 |
Rep Power: 0 Thanks: 11,169
Groans: 423
| Not Ranked : 0 score OP what you are experiencing is very normal. My own car and countless others do exactly what yours is doing. The most popular theory is that the ecu is advancing low load timing in order to increase fuel efficiency. This should ease your fears. Part throttle knock question???
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
The Following User Says Thank You to smoogs12 For This Useful Post: | curlyface (08-05-2013) |
08-05-2013, 03:43 PM | #14 |
Rep Power: 2705 Thanks: 766
| Not Ranked : 0 score coil unplugged?
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
The Following User Says Thank You to m4tic For This Useful Post: | curlyface (08-05-2013) |
08-05-2013, 03:50 PM | #15 |
The cars my DD, until I change the plugs (and maybe that won't even help judging by the above link) do you guys think it's safe to drive ~30KM a day? All my stock parts will be here on Wednesday. Is there any surefire way to check that at least my engine wont explode? If I cruise at a constant speed and it keeps constantly knocking should I assume something is wrong? I'm worried about a WOT test otherwise I would have posted logs already. Any logs I can provide you guys with? Weirdest thing is it never ever did this before. I've seen knock > 0 like twice in the 2 years I've owned the car. I checked the clamps and bolts and everything is tight. Maybe I'm not as good a backyard mechanic as I once believed, heh. /paranoid
08-05-2013, 03:58 PM | #16 |
Groans: 423
08-05-2013, 04:58 PM | #17 |
(Thread Starter) | Neutral : +1 score Just got in the car to test it out, went for afr reading and get 0.00 on AP no matter what I do. Also have 147 constant psi apparently, even when I'm not giving gas Sent from my SGH-I337M using tapatalkreplace 4
08-05-2013, 06:33 PM | #18 |
Groans: 47
| Neutral : +1 score @curlyface; try reflashing your map.
The Following User Says Thank You to sidekick For This Useful Post: | curlyface (08-05-2013) |
08-05-2013, 06:50 PM | #19 |
(Thread Starter) | Not Ranked : 0 score Updated the AP, put a different map on and she runs like a dream. Thank you all for your time.
__________________ 2007 Mazdaspeed 3 -CP-e CATTED DP-PTP HPFP-COBB SRI-COBB TIP-COBB XLE-COBB AP FREEKTUNE-DENSO ITV24-JBR CHROME MOLLY-JBR PMM-JBR TMM-JBR OCC-JBR RSB-RALLY ARMOR-DASHHAWK-E4P STS-DEFI GAUGES-RL COILOVERS- Last edited by curlyface; 08-05-2013 at 07:28 PM. |
The Following User Says Thank You to curlyface For This Useful Post: | sidekick (08-05-2013) |
~3 gal e85 tune knock | Speed3eak | 2010 MS3 - ECU Computer Tuning | 8 | 10-13-2012 02:30 PM |
How do I tune out this knock? | Qtip | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 06-26-2010 01:48 PM |
Can I use ATR to tune out this knock? | Speedn3 | Cobb ATR Support | 12 | 05-25-2009 07:09 PM |
Persistent Knock Retard on stock tune | Ploppity Drown | MazdaSpeed 3/6 - ECU Computer Tuning | 26 | 04-23-2009 01:37 PM |
Tune day. knock retard after 5000rpm | johnac08 | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 12-23-2008 10:57 AM |
