Car Detailing Wanna show off your hard work? Need help with swirl removal, scratches or general detailing questions? Come on in! |
Search Forum |
11-03-2015, 02:39 PM | #1 |
Rep Power: 0 Thanks: 0
(Thread Starter) | Not Ranked : 0 score No one uses a steam extractor? really? I've always rented steam extractors once a year because buying them used to be so expensive... I'm surprised literally every thread in here is only about soap and wax or tire shine. Barely a thread in detailing more Than just the paint on your ride... There's so much more to do than that if you're truly detailing your car! These days, you don't need to use any chemicals except a good wax, and a decent soap if your ride is really salty and dirty before detailing the exterior with steam cleaner. I'm about to buy An MR-100 primo steam cleaner for my MS3. Reasons: Clay bar detailing is ridiculously time consuming and hard to get every part of the body done right. Try a steam extractor and you'll probably never do this again. Cleaning the interior becomes fun, actually seeing the difference right before your eyes. Oh yeah.. It works on rims, rotors, calipers and even under the hood. Hell, you might even be able to clean your valves with it, I dunno. This thing is a home unit that's as close to a professional $3000 steam extractor as you're gonna get, and it costs about $300. Probably gonna save you tons of money in the long run, and not just on cleaning supplies. I'll post an in depth review once I have it, unless someone has tried it already and wants to chime in. Looks solid from what I've seen. The best detailing shops use industrial versions of these on the exterior and interior of your ride... It's their secret. |
11-03-2015, 03:10 PM | #2 |
Rep Power: 265 Thanks: 84
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Now that's a novel idea. People typically use walnut media blasting or chemical treatment to clean the valves. I have a steam gun. I wonder if that would make any impact on the carbon build-up..then there's the risk of hydrolocking if you too much water goes into the combustion chamber..so maybe that's why it hasn't been done. And FWIW, I purchased a Bissell Little Green Machine for carpet and upholstery cleaning. That machine is simply awesome. So much so that I picked up another one and a Bissell Big Green Machine.
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
11-03-2015, 03:26 PM | #3 |
Rep Power: 0 Thanks: 1,624
Groans: 63
| Not Ranked : 0 score If you're worried about it pull your spark plugs before doing the cleaning, no way to hydro lock it then
11-03-2015, 03:55 PM | #4 |
(Thread Starter) | Not Ranked : 0 score What temperature can you get your steam gun to? I know the unit I'm thinking of buying has a range of 110-265 Fahrenheit (I believe) I'm sure it would have to be somewhere near the maximum for it to have a chance at removing the buildup. |
12-20-2015, 06:57 PM | #5 |
Rep Power: 0 Thanks: 48
Groaned at 7 Times in 3 Posts
Argh... I saw this on sale at slickdeals but never bought it. Does it still require you to vacuum stuff up with a wet vac?
__________________ 2007 Mazdaspeed 3 | |
12-21-2015, 07:48 AM | #6 |
| Not Ranked : 0 score @furinax What is the "it" you're referring to?
12-21-2015, 08:32 AM | #7 |
12-21-2015, 09:08 AM | #8 |
| Not Ranked : 0 score The Bissell does not require a wet/dry vac as it is essentially a shampoo vacuum. I usually run the regular vacuum first then use this. The bissell lays down shampoo detergent and then picks it up via its own vacuum hose.
12-21-2015, 11:30 AM | #9 |
Rep Power: 0 Thanks: 6,760
Groans: 42
At those temps you are referring to a hot water extractor, NOT a steam extractor. Post of some before/after shots. I'd like to see this section grow
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci | |
03-19-2019, 01:26 PM | #10 |
Rep Power: 0 Thanks: 2
| Not Ranked : 0 score How does it replace clay baring? Not being sarcastic or anything. Genuinely curious because I can't see the mechanics of it working in my head. |
03-19-2019, 02:52 PM | #11 |
| Not Ranked : 0 score it melts the paint then after the pain melted you dont have to worry about claying your car.... |
03-21-2019, 06:30 AM | #12 |
| Not Ranked : 0 score |
03-21-2019, 03:01 PM | #13 |
| Not Ranked : 0 score lol but yeah interesting how does it eliminates using clay bar |
Steam Summer Sales | cshunter | Hot Deals Section | 6 | 07-20-2012 05:40 PM |
Steam Senna on Netflix... NOW | Haltech | Automotive News | 2 | 05-02-2011 10:54 AM |
Juiceman 2-Speed Juice Extractor JM300 - $45 | Haltech | Hot Deals Section | 0 | 04-09-2008 04:40 PM |
