MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
Search Forum |
07-10-2013, 02:11 PM | #1 |
Rep Power: 0 Thanks: 1,042
(Thread Starter) | Not Ranked : 0 score Direct Injection Injectors So, I know that no one makes DI injectors for your platform yet, but know that there are plenty of DI platforms cranking out the power. Have not done much research, so pimp slap me if you want. I came across these DI injectors for VW fellows. Capable of supporting 500whp. Just sayin, if I found a set of injectors that looked the same as ours, I would be the guineau pig! Here is the link. I that sooner than later, we will find some injectors for our cars that will work. Hopefully someone can actually strap on a pair and make a set for the mazdaspeed crew Bosch OEM 2.0T FSI HDEV 1 Gasoline Direct Injection Injectors
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME |
The Following 10 Users Say Thank You to h.h.sk1nny For This Useful Post: | cshunter (07-10-2013), El_Diablo (07-12-2013), Juyoung (07-12-2013), Kyle Undefined (07-12-2013), mazdafreak (07-10-2013), ms3blackmica (07-11-2013), rfinkle2 (07-10-2013), Roddiy (07-12-2013), sidekick (07-11-2013), uncorked11 (07-10-2013) |
07-10-2013, 02:12 PM | #2 |
Eatin' Your Tuna Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 Thanks: 1,602
| cheaper than i suspected
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite | |
07-10-2013, 02:28 PM | #3 |
Rep Power: 0 Thanks: 39
| Not Ranked : 0 score Ask for a dimensioned drawing, They might be smaller diameter or something stupid like that.
__________________ 2010 - BMW 335i M-Sport - Lemans Blue Metallic 2005 - Kawasaki ZX-6R 636 - Magma Red |
07-10-2013, 02:33 PM | #4 |
Rep Power: 0 Thanks: 33
| Not Ranked : 0 score They look very similar. I can't figure out why someone hasn't built injectors for these cars. Hell, APR makes CP-E fuel pumps for the platform.
__________________ 2008 CBM MS3 CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune |
07-10-2013, 02:36 PM | #5 |
Rep Power: 0 Thanks: 4,489
| Not Ranked : 0 score I know the GTI guys will swap to the Cobalt SS injectors since they're both Bosch they just plug and play. I want to say DJ explained the math to me and the SS/TC injectors were equivalent to ~1000cc's. The cobalts also have a company that makes a cam for them with an extended fuel lobe to push the pump harder, and i have personally seen a cobalt with this set up make 502 whp on 100% E85, albeit with a small amount of meth injection as well. Point of this story being im willing to bet thats all these injectors are.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. Last edited by Voltwings; 07-10-2013 at 03:41 PM. |
The Following User Says Thank You to Voltwings For This Useful Post: | Juyoung (07-12-2013) |
07-10-2013, 02:42 PM | #6 |
Rep Power: 10249 Thanks: 14,116
Groans: 136
| Not Ranked : 0 score We also nee to make sure the impedance and dwell time match, as well as the connector itself.
__________________ |
The Following 3 Users Say Thank You to silvapain For This Useful Post: |
07-10-2013, 02:52 PM | #7 |
Rep Power: 0 Thanks: 644
| Not Ranked : 0 score Has anyone looked into modifying the stock injectors? I know other platforms have that available, may be a cheaper way to get a company interested in the idea?
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD |
07-10-2013, 02:58 PM | #8 |
Groans: 136
| Not Ranked : 0 score It's been discussed, and someone (PTP I think) cut open an injector to see what would be needed. Nothing ever came of it.
The Following User Says Thank You to silvapain For This Useful Post: | rfinkle2 (07-10-2013) |
07-10-2013, 03:20 PM | #9 |
Engineered Tuning Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 12034 Thanks: 6,485
| Not Ranked : 0 score The Bosch injectors have a different seal type (around the tip of the injector) to start.
__________________ We Engineer, and that's better than just tuning! www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
The Following User Says Thank You to Lex For This Useful Post: | silvapain (07-10-2013) |
07-10-2013, 03:40 PM | #10 |
Rep Power: 0 Thanks: 52,496
@ this point, it seems like some sort of swap would be the way to go, and the necessary adapters, wiring or scaling would need to be done. I don't know that we'll ever get something plug and play, but I can't fault hhskinny for continuing to look (thanks for posting the link btw). I gave up hope that higher volume fueling will come in te form of a drop in injector a while ago, but still think it is great for people to continue to search for the answer. | |
The Following 8 Users Say Thank You to rfinkle2 For This Useful Post: | Downmented (07-10-2013), El_Diablo (07-12-2013), h.h.sk1nny (07-10-2013), Juyoung (07-12-2013), Kyle Undefined (07-12-2013), ms3blackmica (07-11-2013), Roddiy (07-12-2013), SLOWHATCH (07-12-2013) |
07-10-2013, 06:59 PM | #11 |
(Thread Starter) | Not Ranked : 0 score I will email them asking dimensions, rated cc and what not. I may try to get a hold of a mazdaspeed injector and try to find something that comes close.
The Following 3 Users Say Thank You to h.h.sk1nny For This Useful Post: |
07-10-2013, 07:04 PM | #12 |
Rep Power: 0 Thanks: 6,748
Groans: 97
| Not Ranked : 0 score As long as I get it back I can send you one of the spares I have.
__________________ TEAM LUXURY |
The Following 5 Users Say Thank You to Sid3wayS For This Useful Post: | El_Diablo (07-12-2013), h.h.sk1nny (07-10-2013), Kyle Undefined (07-12-2013), rfinkle2 (07-11-2013), wolly6973 (07-11-2013) |
07-10-2013, 11:07 PM | #13 |
(Thread Starter) | Not Ranked : 0 score The new skyactiv motors use di that is rated at 3000psi, fords new na 2.0 gdi motor is also direct injected. Both fomoco parts, we need to get our hands on a set of these; Pablo!!!! I will let you know, I first want to see if we can get a hold of a new skyactiv injector. Unless you don't care I have it for a while. You can PM me if you'd like to send it to me
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME Last edited by h.h.sk1nny; 07-10-2013 at 11:07 PM. Reason: MSF Database - Automerged Doublepost |
The Following User Says Thank You to h.h.sk1nny For This Useful Post: | rfinkle2 (07-11-2013) |
07-10-2013, 11:13 PM | #14 |
The early adopters - N54s had piezo injectors that could flow enough for 800+whp and we had these oddball ones that no one else really used.
__________________ We Engineer, and that's better than just tuning! www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. | |
The Following 2 Users Say Thank You to Lex For This Useful Post: | h.h.sk1nny (07-10-2013), wolly6973 (07-11-2013) |
07-11-2013, 12:04 AM | #15 |
Rep Power: 8624 Thanks: 17,845
Groans: 95
| Not Ranked : 0 score The head could be machined to accept a different base profile it would also need to match the fuel rail. Connectors could be swapped as well. Sent from fastest ko4 Pu!
__________________ Nator is what it does. |
07-11-2013, 12:19 AM | #16 |
Rep Power: 0 Thanks: 233
| Not Ranked : 0 score The important thing to note here is that these aren't injectors that are developed by some aftermarket performance group but rather the OEM injectors from the S3 which naturally are a good fit for VWs. If there was a big enough market for these DI injectors maybe some performance manufacturer would be willing to invest the R&D into this. Even if someone comes out with a bigger DI injector it'd be crazy expensive at this point. Best bet is to continue improve on the 5th port/PI systems that we are using now.
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
The Following 4 Users Say Thank You to Karmat For This Useful Post: |
07-11-2013, 12:34 AM | #17 |
Rep Power: 0 Thanks: 2,125
| Not Ranked : 0 score I would like to know how close late model ecoboost heads are to fitting on the mzr.... Sent from my SAMSUNG-SGH-I727
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) |
07-11-2013, 12:38 AM | #18 |
Groans: 95
__________________ Nator is what it does. | |
The Following 4 Users Say Thank You to kritz For This Useful Post: |
07-11-2013, 02:22 AM | #19 |
Nishan Join Date: Apr 2012
Rep Power: 9816 Thanks: 13,290
| Not Ranked : 0 score We would still need to be able to calibrate for a new injector which we do not have the capability to do as of right now (i.e. dead time vs batt. voltage, IFR, etc..). I'd hope Cobb would release those controls should an injector upgrade become possible.
__________________ www.tunedbynishan.com |
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post: |
07-11-2013, 05:29 AM | #20 |
Rep Power: 3780 Thanks: 8,647
Groans: 493
There has already been a DISI modified to accept a head from the regular MZ3 and it made over 1300hp and ran 7s in the 1/4mile. He also uses 12 injectors Look up, Dee Karagiannis To my understanding the issue with doing head swaps, or frankenstein builds, is for us, the heads we would want to use have different passages for the oil/coolant.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! | |||
07-12-2013, 12:53 PM | #21 |
(Thread Starter) | Not Ranked : 0 score I emailed apr last night about interest in making injectors for us. He said they have not interest, as they don't make injectors and are Porsche, audi, and vw exclusive. He did say that on their stock direct injectors, they just upgrade the fuel pump and can make 650whp!!! We got hosed!!!
07-12-2013, 12:58 PM | #22 |
ZZPerformance - LNF Intake Camshaft With Upgraded Fuel Pump Lobe # Little to no information in that link other than "20% more fuel flow" but if anyone else is interested in taking a further look.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
The Following User Says Thank You to Voltwings For This Useful Post: | rfinkle2 (07-12-2013) |
07-12-2013, 01:04 PM | #23 |
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME | |
The Following 2 Users Say Thank You to h.h.sk1nny For This Useful Post: | Mauro_Penguin (07-14-2013), rfinkle2 (07-12-2013) |
07-12-2013, 01:10 PM | #24 |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite | ||
07-12-2013, 01:11 PM | #25 |
| Not Ranked : 0 score May as well, every other car they make parts for is discontinued anyways haha.
The Following User Says Thank You to Voltwings For This Useful Post: | sidekick (07-12-2013) |
07-12-2013, 01:25 PM | #26 |
Rep Power: 0 Thanks: 492
| Not Ranked : 0 score the injector seals on that page look interesting, and cheap. maybe something like that could work for our platform |
07-12-2013, 02:01 PM | #27 |
Rep Power: 0 Thanks: 27
| Not Ranked : 0 score How closely related is the 2.3 EB going in the new mustang to our engine? Aftermarket always seems to be quick for them, maybe some stuff will swap over easier than expected.
__________________ 2012 LSM MS3 | COBB SRI / TIP | Autotech HPFP | COBB AP | Corksport Racepipe |
07-12-2013, 02:22 PM | #28 |
Oh and the removal of MAF too.
The Following User Says Thank You to Haltech For This Useful Post: | Mauro_Penguin (07-14-2013) |
07-12-2013, 02:32 PM | #29 |
Rep Power: 5339 Thanks: 27,149
| Not Ranked : 0 score It always comes down to price. PI manifold, four PI injectors and a controller can easily double fueling capacity easily for ~$1600 dollars and not impact idle quality or require any tuning resources not currently on the market and is available today, or will be very shortly. Complete TBI injection kits are available today for $1000 and adds 50% more fuel. Upgraded DI injectors will also require a higher capacity HPFP which is not currently available, a higher capacity ITFP, tuning resources we don't have, and will need to stay close to that $1600 mark for the entire kit and at least double the fueling or nobody will bite. So $150 for the ITFP, and at least $500 for the HPFP leaves you with $950 for 4 drop in injectors. Zigatapatalkreplacea
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
The Following 5 Users Say Thank You to Ziggo For This Useful Post: | Downmented (07-12-2013), ms3blackmica (07-12-2013), qtrmile beast (07-12-2013), rfinkle2 (07-12-2013), silvapain (07-12-2013) |
07-12-2013, 03:52 PM | #30 |
Rep Power: 0 Thanks: 1,066
Groans: 82
| Not Ranked : 0 score There is a thread around here discussing all this already... I'm on my phone, but I think @06Speed6; started it.
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
08-14-2018, 01:06 PM | #31 |
Rep Power: 0 Thanks: 32
| Not Ranked : 0 score But why tho
__________________ 2007 Sunlight Silver Mazdaspeed3 Engine: \\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\ Tuning: \\Cobb AP V3\\ Freektune Custom Tune \\ Suspension/Brakes: \\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\ |
The Following User Says NO Thank You to flapjack For This Un-useful Post: | JSmith (08-14-2018) |
08-15-2018, 04:43 PM | #32 |
Rep Power: 0 Thanks: 55
| Not Ranked : 0 score Your post is exactly what EVERYONE is thinking...about your post.
The Following User Says Thank You to Fstrnyou For This Useful Post: | Thor Hammer (08-16-2018) |
Methanol Direct Injection | phate | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 290 | 10-01-2014 09:34 PM |
Direct Injection Systems | mrlilguy157 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 7 | 04-07-2014 01:51 PM |
The Dangers of Direct Injection | CorkSport | CorkSport | 0 | 02-20-2013 04:20 PM |
Direct Injection Systems | mrlilguy157 | MSF KB - Mazdaspeed 3/6 - Fuel | 7 | 09-19-2012 01:51 PM |
