MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
Search Forum |
10-18-2009, 10:13 AM | #1 |
Rep Power: 0 Thanks: 263
Groans: 75
(Thread Starter) | Not Ranked : 0 score Just an idea... Me and my roommate were sitting here thinking about our problem with fuel and whatnot and he came up with something...so i figured id run it by you ppl. His idea was to put a T in the fuel line between the "lift pump" in the tank and the CDFP, then add a line with maybe another pump on it and do direct port with that line set up on a progressive controller. This would be a cheaper alternative to upgrading the CDFP or adding another fuel system/tuning solution(PI) for that system. The only problem i can think of is it possibly drawing to much pressure from the "lift pump" reducing the pressure to the CDFP....Any thoughts? |
10-18-2009, 10:27 AM | #2 |
Fuck sushi rolls Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 Thanks: 2,168
Groans: 356
| Not Ranked : 0 score have u ever measured the injector duty cycle on a 400hp mzr engine?
The Following 5 Users Say Thank You to rodrigo For This Useful Post: | aaronc7 (10-18-2009), Addikted To Boost (10-18-2009), glocK23 (10-18-2009), mazdarati (10-19-2009), phantom3 (11-12-2009) |
10-18-2009, 11:15 AM | #3 |
Groans: 75
10-18-2009, 11:18 AM | #4 |
Rep Power: 0 Thanks: 1,559
| Not Ranked : 0 score its a joke that you havent been around long enough to understand man...
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
10-18-2009, 11:21 AM | #5 |
Groans: 356
| Not Ranked : 0 score ^^^^ cawk blocker
10-18-2009, 11:26 AM | #6 |
| Not Ranked : 0 score lol...so did cpe get banned from msf or what? I cant find their motor mount thread anymore...
10-18-2009, 11:27 AM | #7 |
Groans: 356
| Not Ranked : 0 score they couldn't pay their bill......
10-18-2009, 11:32 AM | #8 |
Groans: 75
10-19-2009, 09:50 PM | #9 |
Groans: 75
(Thread Starter) | Not Ranked : 0 score I guess there is no real thought on this idea? |
10-19-2009, 09:55 PM | #10 |
NEC Join Date: Mar 2008
Rep Power: 473 Thanks: 129
| Not Ranked : 0 score Thats how the nitrous wet kits work... its feasible. Give it a try and see what happens
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
10-21-2009, 08:39 AM | #11 |
Rep Power: 0 Thanks: 179
| Not Ranked : 0 score taking away volume from the cdfp is not a good idea, even if its going back into the motor anyway. youre basically talking about a secodary port fuel injector right? if i were you and you were concerned about your fuel pressures, i would just upgrade the pump and/or get a meth kit. either way is adding more fuel without robbing from peter to give to paul so to speak.
__________________ Formerly: TG 06 MS6- CAI, TMIC, TBE Currently: RR 08 Evo X- SRI, UICP, TP, CBE, Tune |
11-12-2009, 01:09 PM | #12 |
Rep Power: 0 Thanks: 29
| Not Ranked : 0 score ^^ lol nice |
11-13-2009, 05:11 PM | #13 |
Speeeeeed Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 7490 Thanks: 6,190
Actually it is a good idea that just doesnt work.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
just an idea | superskaterxes | Website Help/Feedback | 5 | 12-16-2008 06:26 PM |
