MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
Search Forum |
07-11-2009, 07:42 AM | #1 |
Rep Power: 0 Thanks: 2
(Thread Starter) | Not Ranked : 0 score Doing a corksport test pipe install, bought it used, what bolts will I need Hey guys, Going to install my test pipe in the morning. I got it used and dont' have hardware, so was wondering what bolts I will need or has everyone just used stock? I seen 1 guy posted to use M10 1.25 bolts, any other opinions. I thought I had read you can use stock, but I don't want to start the job and get my car on the stands only to figure out that the stock bolts won't work. Also, I see 2 braces on there, that look like they will probably need to be pulled, did you guys pull them? I'm surpised there is no test pipe install in the how to section. I searched and found nothing. Any info to prepare for this would be great. Thanks |
07-11-2009, 08:09 AM | #2 |
Rep Power: 4956 Thanks: 5,585
Groans: 370
| Not Ranked : 0 score hard to say.... it really depends on all the other variables....what DP and CBE you are running. I had to buy new bolts for mine when I installed it, but I was running the CS DP with stock CBE...so its probably not going to be the same for you. You'll probably be able to use the stock bolts at least on one end, but I could be wrong. Hopefully someone will drop by who has this exact same setup as you and can give you exactly what you need. As far as the install.... its 4, 14mm bolts and you just have to pry it off the hangars. Should be pretty self explanatory once you're down there. You might want to pick up some copper 'spray gasket' stuff at autozone and use that on the ends of the test pipe to help make sure it seals 100%. I've read a few guys who had minor issues...since the test pipe is designed for sure with their 3" system. |
07-11-2009, 09:58 AM | #3 |
(Thread Starter) | Not Ranked : 0 score I have the stock DP and stock CBE. SO, did you rear bolts fit since you had the stock CBE?
07-11-2009, 02:22 PM | #4 |
(Thread Starter) | Not Ranked : 0 score Anybody? I really can't jack the car up and get under there to take it off and then go get the bolts. Don't have the luxury of another car being here while I do the install. Can anyone tell me the bolts I will need to do this install??? |
07-12-2009, 12:34 AM | #5 |
Rep Power: 165 Thanks: 2
| Not Ranked : 0 score Check out this thread http://www.mazdaspeedforum.org/forum/foru...do-i-need.htmlI tried doing my test pipe today and I'm not sure if the stock bolts will fit. I stripped the head completely off one of the bolts which led me to hack sawing it for 2 hours.
__________________ Cobb AP, CPE SRI, Cobb Turbo Inlet, Turbosmart Dual-Port BOV, ETS 3.5" TMIC, TRZ Rear Motor Mount, TurboXS Race Pipe, TWM Shifter Bushings, Dabears2k 35W 6000k HID's, Luminiacs 2500k halogen fogs, Putco brake light led bulbs, CPE tow plate, Cobb Springs, OZ Racing Ultraleggara Gold Wheels, weapon r torque damper |
The Following User Says Thank You to iracer7 For This Useful Post: | jasonspeed3 (07-12-2009) |
07-12-2009, 12:35 PM | #6 |
(Thread Starter) | Not Ranked : 0 score Thanks bro. I will head to the parts store and get those bolts and exhaust puddy. Did that get yours ok?
07-12-2009, 07:12 PM | #7 |
Rep Power: 0 Thanks: 7
| Not Ranked : 0 score |
07-12-2009, 07:32 PM | #8 |
Banned Join Date: Jun 2008 Location: misery
Rep Power: 0 Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score stripped bolt heads... hacksawing for 2 hours...sounds like win. you will probably have to get bolts going from rp to dp as the dp has welded nuts on it. i believe the reason you need to get new ones is to accommodate for the distance between flanges. but this could be totally different for you. nonetheless, those are 14mm hex heads, so probably 10mm threads, as you've already stated. get ones that are around 3 inches or 75mm if possible. it might be overkill, but at least it'll do the trick. get some nuts that fit as well JUST IN CASE. also, get washers. make sure the bolts are threaded all the way too. for the side with the cbe, you'll most likely need new hardware here as well. since these are just nuts and bolts, you can use sae instead of metric shit here. they will be less expensive nuts and bolts. get washers. the idea is to reuse the spring bolts here. although, you have hangers on that cs piece, so maybe you don't need to use the springs. anyway, get some nuts, bolts, and washers, and have at it. yes, remove the braces...and have fun. spray with pb blaster if you have to. those bolts off the dp were a pita for me |
07-12-2009, 07:48 PM | #9 |
07-12-2009, 07:49 PM | #10 |
(Thread Starter) | Not Ranked : 0 score Thanks man! I got a shitload of nuts and bolt, I will just take back what I dont' need. THink I'm gonna go try this right now.
07-12-2009, 08:22 PM | #11 |
| Not Ranked : 0 score My dad will probably kill me tomorrow when he gets a chance to yell at me. He didn't know I was trying to install a rp and when he got home today from his parent's river house the car was on ramps and I was driving his 2005 Mustang GT which he never lets me drive. I had to go to work and couldn't finish. He absolutely hates me doing anything to MY car though his name is also on it. This was the biggest pita ever and my mom just put the stock pipe back in there.
07-12-2009, 09:41 PM | #12 |
07-13-2009, 10:56 AM | #13 |
| Not Ranked : 0 score My dad wasn't home and we weren't expecting him home until today. My grandpa helped and thought the Turboxs wouldn't fit so they put the stock one on while I was at work. I had to work 12-9 so I couldn't help.
07-14-2009, 12:11 AM | #14 |
| Not Ranked : 0 score wow I just thought of a few your momma jokes that wouldn't be that funny. Like "Your momma... nvm |
12-03-2009, 01:25 PM | #15 |
Rep Power: 0 Thanks: 138
| Not Ranked : 0 score When I did my Test Pipe, it was missing the pieces on it that go into the rubber grauments on the sides bolted to the frame. Since it was missing it, I have noticed vibration in the car that was not there before. |
12-03-2009, 01:41 PM | #16 |
KR....i haz it Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 Thanks: 1,652
Groans: 166
Groaned at 56 Times in 41 Posts
| Not Ranked : 0 score your test pipe does not have hangers. some do, some dont. the vibration is not from a lack of hangers, its from the lack of flexing in the exhaust now that you dont have spring bolts.
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp |
Corksport Test Pipe | taf0422 | MazdaSpeed 3 - Engine, Transmission & Driveline | 28 | 09-20-2009 09:09 PM |
Corksport test pipe leak.. | booya620 | MazdaSpeed 3 - Engine, Transmission & Driveline | 33 | 02-06-2009 10:45 PM |
