MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
Search Forum |
10-20-2009, 12:54 PM | #1 |
Rep Power: 0 Thanks: 1
(Thread Starter) | Not Ranked : 0 score Engine mounts? How difficult is it to change out the engine mounts? and another question, is cobb still making the replacement shifter weight? just wondering... |
10-20-2009, 12:57 PM | #2 |
Rep Power: 3771 Thanks: 18,108
Groans: 326
| Not Ranked : 0 score changing the rear mount takes roughly a half hr, not hard at all. having 2 people helps a lot as the engine may need to be rocked to get re aligned with the bolt holes. Not sure about the other 2 tho.... No, cobb's shifter weight has been discontinued, but if you do some digging you may find a few vendors still have some. i got mine from JSCSpeed. you could also just get a saw and cut half the stock weight off |
04-06-2010, 04:02 PM | #3 |
Rep Power: 0 Thanks: 3
10-20-2009, 01:36 PM | #4 |
Rep Power: 0 Thanks: 147
| Not Ranked : 0 score I have heard that some people drill holes in their stock weight for the same effect. The rear motor mount is cake. The side engine mount and the tranny mount are more challenging but very doable, you have to hold the engine up with a jack when you replace those two and I would recommend a tq wrench to make sure the bolts get tight enough. If you plan on doing the side mounts there is a great write-up on SUF, there may be one on this site as well but idk.
__________________ 08' Black Mica MS3 Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight. Sponsored by NATOR VA |
The Following User Says Thank You to soccerballz For This Useful Post: | wette460 (03-04-2011) |
10-20-2009, 02:40 PM | #5 |
patrick failman Join Date: Mar 2009
Rep Power: 2905 Thanks: 4,275
Groans: 74
| Not Ranked : 0 score rear and passenger mounts are easy and the engine doesn't shift much. the tranny mount isn't hard, but you have to remove your battery and the engine really shifts if your jacks aren't in the right place. there's a great how to by abilor over on 247.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
10-20-2009, 04:26 PM | #6 |
Rep Power: 0 Thanks: 3,362
| Not Ranked : 0 score i took me about 2hrs to install my side mounts. now that i've had them out-in-out again, the last time i pulled them out was 45min. a torque wrench is an absolute must for any of the mounts, and i use blue loctite for piece of mind. torque specs for the mounts can be found in the shop service manual
__________________ |
12-02-2009, 09:45 PM | #7 |
Rep Power: 0 Thanks: 852
| Not Ranked : 0 score at what point do upgraded motor mounts pay off? DO you have to be pushing major HP to see any improvement?
__________________ gtx3076 and shit |
12-03-2009, 05:10 AM | #8 |
| Not Ranked : 0 score The rear motor mount will pay off on a stock ms3, its a must have. The sides help but aren't necessary on motors that are just lightly modded, imo anyway.
The Following User Says Thank You to soccerballz For This Useful Post: | predapio (12-11-2009) |
12-03-2009, 05:40 AM | #9 |
Groans: 74
i'd say upgraded rear and tranny mounts are worth it on an otherwise stock car (less wheel hop and missed shifts). an upgraded passenger mount is probably just preventive from the stocker going poop.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket | |
12-03-2009, 05:43 AM | #10 |
Groans: 326
| Not Ranked : 0 score This is what your motor is doing under the hood scary isnt it...rmm cleans that up a lot |
The Following 4 Users Say Thank You to 8.5MS3 For This Useful Post: |
12-03-2009, 08:39 AM | #11 |
| Not Ranked : 0 score wow, that is impressive! so what brand is best, and where do i start?
12-03-2009, 08:50 AM | #12 |
Rep Power: 2562 Thanks: 1,586
Groans: 125
| Not Ranked : 0 score I have a CPe rear engine mount, and its like they combined some sort of magic pixie dust, and black magic voodoo to make a stiff engine mount that didnt rattle my car to death. i dig it. I tried the poly TRZ and Delrin TRZ and both were MUCH MUCH more vibrations.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
The Following User Says Thank You to socks For This Useful Post: | kgb (03-31-2010) |
12-03-2009, 08:58 AM | #13 |
Rep Power: 0 Thanks: 219
| Not Ranked : 0 score With the mods in my sig i can def tell you that you need mounts all around! The RMM does a good job for a while but as you get closer to fully bolted it doesnt cut it. I have SU rmm in right now and getting the other 2 SU mounts when the mail comes. With my mods you can feel the engine move esspecially around turns. Also the whole engine shakes pretty good when you turn on the car and turn it off so i want to prevent all those movements. Its gonna suck for vibrations though!
__________________ 09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic [Today 11:50 PM] aaronc7: i just measured mine, a little over 12 |
12-03-2009, 09:06 AM | #14 |
Groans: 326
| Not Ranked : 0 score cp-e 75 duro is awesome |
12-03-2009, 09:18 AM | #15 |
Groans: 74
| Not Ranked : 0 score trz combo ftw.
12-03-2009, 10:52 AM | #16 |
| Not Ranked : 0 score full SU mount set
12-11-2009, 11:18 AM | #17 |
(Thread Starter) | Not Ranked : 0 score Thanks guys, I appreciate the input! |
12-11-2009, 01:05 PM | #18 |
Rep Power: 0 Thanks: 3,135
Groans: 234
Groaned at 154 Times in 122 Posts
| Not Ranked : 0 score if you cant find the shifter cobb shifter weight anywhere i have one im willing to sell you.
__________________ '08 MazdaSpeed3 - sold |
12-11-2009, 01:24 PM | #19 |
Rep Power: 0 Thanks: 23
| Not Ranked : 0 score I just have the rear, feels real solid but when the car is ideling with the AC on its kinda annoying..... |
12-11-2009, 01:31 PM | #20 |
Join Date: Sep 2009 Location: Surburban Detroit Michigan
Rep Power: 2266 Thanks: 2,223
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Re: Engine mounts? I also have the CP-E rmm, but still get hop. I'm going to try SU other two mounts as well. Probably the ptp kicker mount too. |
12-12-2009, 05:37 AM | #21 |
Groans: 74
| Not Ranked : 0 score i'd start with a tranny mount and see what that does for you. i added a passenger mount in fear of the stocker exploding, but i don't think it's necessary.
The Following User Says Thank You to karl-hungus For This Useful Post: | BudUMfan (12-12-2009) |
12-12-2009, 05:25 AM | #22 |
Rep Power: 0 Thanks: 483
| Not Ranked : 0 score Yea my bone stock car bucked the fan off the TMIC on the dyno, heh. Once I saw that I knew I had to start looking into mounts.
__________________ 2011 Mustang GT Premium 5.0 2009 True Red Mazdaspeed3 - Sold Cobb SRI | Cobb TIP | Cobb AP | CP-E DP | SU TMIC | Denso ITV22 | PTP HPFP | Synapse Synchronic BPV | Saikou Michi OCC | SU 90A RMM | SU Side Mounts | TWM Stage 2 STS w/Bushings | Dashhawk |
12-12-2009, 06:31 AM | #23 |
I'll start there! Thanks. | ||
12-15-2009, 03:31 PM | #24 |
Rep Power: 0 Thanks: 12,832
Groans: 109
| Not Ranked : 0 score all you need to do is remove 4 bolts right? i just got my RMM in yesterday and i'm thinking of doing it tomorrow morning... just need to get it done before i have to leave for classes... lol, maybe i should wait till the weekend |
12-15-2009, 05:38 PM | #25 |
Groans: 74
HOW TO: Install TRZ DogBone Rear MotorMount - Mazda Forums tranny... How to: Install TRZ Transmission Mount - Mazda Forums 247 sucks... Hello faggot it appears that you have not posted on Mazda Forums (Mazdas247.com) in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another Member in the Community? See you on the forums! Sincerely, Antoine Tokar
12-15-2009, 05:58 PM | #26 |
Groans: 109
| Not Ranked : 0 score ^ post pics of naked people and get banned, you'll stop getting those emails lol, and thanks for the links... just wasn't sure how great 247 was for tutorials, i found one of M3F and that one seems fine too |
01-07-2010, 07:56 PM | #27 |
Groaned at 16 Times in 2 Posts
| Not Ranked : 0 score thanks for all the info all. now going to look for the diy rmm
__________________ Jesus saves! 07 ms3 |
12-15-2009, 02:52 PM | #28 |
Rep Power: 0 Thanks: 10
| Not Ranked : 0 score anyone have a recommendation of a tranny mount vs ETD? i've currently got the SU rmm installed and an ETD thats still in the box. wondering would would be preferable as far as performance gain & minimal increase in vibes....dont wanna install the ETD if id b better off w/ a tranny mount |
01-10-2010, 06:12 PM | #29 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score Need to do mine Bad |
01-12-2010, 02:51 PM | #30 |
Rep Power: 0 Thanks: 208
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score You prolly won't have to rock the engine if u use a spare jack to just raise it a half a click (depending on the jack). I did that and everything went smooth.
__________________ ::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 ::: ::: DIZZY TUNED by Boost_creep ::: |
01-22-2010, 02:43 PM | #31 |
Join Date: Sep 2009 Location: Port. St Lucie, Florida / Queens, New York
Rep Power: 0 Thanks: 1,472
Groans: 129
| Not Ranked : 0 score Just a quick question... Im assuming some of you go to the dealer for various reasons, did the dealer ever hassle you guys for the mount?
__________________ NATOR NJ/NY/FL 09 MS3 tuned by Nishan |
01-22-2010, 02:50 PM | #32 |
Groans: 326
| Not Ranked : 0 score |
01-22-2010, 02:51 PM | #33 |
| Not Ranked : 0 score Re: Engine mounts? Never. Sent from my iPhone using tapatalkreplace |
01-22-2010, 03:02 PM | #34 |
Rep Power: 0 Thanks: 4,450
| Not Ranked : 0 score I know it's been said a million times already, but the rear mount is easy and makes the car drive 100x better. After about 10 minutes trying to rock the new one in, I took out those two tranny bracket bolts and the thing slid right in and all the bolts lined right up. You definitely feel the vibrations but it's nothing major. For reference I have the street unit one with the street bushing.
__________________ 2009 MS3 sport MGM |
03-04-2010, 03:41 PM | #35 |
Rep Power: 0 Thanks: 130
Groans: 33
Groaned at 32 Times in 15 Posts
| Not Ranked : 0 score i been looking at all the forums i could and see an installation with pictures for the rear mount and side mounts.. but no luck, unless im blind,, anybody that has a link i would really appreciate
__________________ Silly Lebron, rings are for Kobe 2011 WRX STI pro tune Invidia Downpipe and Exhaust,Cobb Intake Cobb AP 91 The nigga bought aluminum tubes! Do I need to tell you what the fuck you can do with an aluminum tube!?! ALUMINUM!! Dave Chappelle |
03-04-2010, 07:13 PM | #36 |
__________________ 08' Black Mica MS3 Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight. Sponsored by NATOR VA | |
03-04-2010, 09:51 PM | #37 |
| Not Ranked : 0 score I just installed the CPE-RMM / 60. The shifting is totally different from stock. Very direct and smooth. The install was very easy. Make sure you take the three bolts off of the tranny bracket. This will make the install a lot easier. There is a slight vibration when I tip the throttle, but it is very slight. Overall very please with the upgrade. My 08.5 only has 14,000 miles and the stock RMM look fine but the improvement with the CPE RMM is instantaneous. |
The Following User Says Thank You to jliu For This Useful Post: | kgb (03-31-2010) |
03-04-2010, 10:16 PM | #38 |
03-25-2010, 11:15 PM | #39 |
Banned | Not Ranked : 0 score I just bought a set of trz mounts does any one have any recommendations for bushings and when they would have to be replaced? |
03-30-2010, 09:34 PM | #40 |
Rep Power: 0 Thanks: 5
| Not Ranked : 0 score The rear mount is easy to install. Just 4 bolts. I did it with the car on ramps, it's a little tight, but you can do it. Once you get the mount in and are trying to line the 3 bolts up, just push up on the motor. I spent 15 minutes trying to wrestle the mount around until I figured that out lol. I put the SU mount in and it makes a huge difference. The power is now getting to the ground in 1st and 2nd (for the most part). |
side engine mounts or torque damper | jamspeed3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 08-10-2009 08:34 PM |
TRZ TM and SU engine mounts | ms3boost | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 03-27-2009 07:56 PM |
SU Side Engine Mounts Completed & Installed | Grim | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 10-30-2008 02:29 PM |
