MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
Search Forum |
06-21-2009, 11:25 AM | #1 |
Rep Power: 854 Thanks: 14
(Thread Starter) | Neutral : +1 score Oil restrictor bolt install PICS ARE GONE, SORRY! First, remove the stock TMIC cover. 2 ten mm head bolts. Next, remove the TMIC nuts (12mm head) and loosen the upper hose connection on the TMIC inlet from the turbo (10mm head). Then, pull the TMIC off of the mounting studs and push forward enough to let you reach the heatshield. Remove the 5 heatshield bolts (8mm head). Pull the heatshield out. It's tight, but it will fit past everything. Now, you can remove the stock banjo bolt (can't really see it from this angle, but it's straight down from the driver's side rear of the TMIC, on top of the turbo. DO NOT FORGET TO REUSE THE 2 STOCK COPPER SEALING WASHERS! One on top of the banjo fitting and one below!!! Better view of where the bolt will be as shown on my PTP SST. UPDATE 9-4-2012
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall Last edited by Raider; 09-04-2012 at 08:07 AM. | |
The Following 16 Users Say Thank You to bnoon For This Useful Post: | Abilor (06-27-2011), ak_spray (06-14-2012), Constantin (05-10-2012), Dasleeper (02-28-2012), FreeFlyFreak (06-21-2009), hartungenator (03-17-2010), jack_hammer (11-01-2011), keychain12 (10-13-2013), labikesrcool (06-19-2011), Menace1 (04-14-2013), mike8748 (03-18-2010), p057 (01-09-2012), sjdannen (11-26-2017), SLOWHATCH (02-14-2012), TexasSpeed3 (11-26-2011), urbansurfer (08-18-2011) |
06-21-2009, 11:43 AM | #2 |
(Thread Starter) | Not Ranked : 0 score This post will take you through how to make your own restrictor bolt from a regular M12x1.5 pitch bolt. Below shows the part number of the bolt you need. I got these from Advance Autoparts store. They had to order them in this length for me (30mm length). This is the bit I used from True Value Hardware store. #52 is roughly .0635" in size. Drill the small side hole first with the #52 bit. Center punch the bolt about 4 threads down from the head. You only need to drill about halfway though or so on this hole to meet the center hole you'll drill next. Do it this way first because if you don't, you run the risk of breaking the bit if you drill the center hole first (bits tend to break when they drill through the far side of the drilled material) Drill the center hole last. I used a 15/64" bit for the center hole I believe. That about it. I used a small deburring rasp made for making custom sized carb jets to take the side holes out to about .065", but just deburr the best you can with the bit itself and you'll be fine.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall Last edited by bnoon; 03-02-2010 at 07:39 AM. |
The Following 17 Users Say Thank You to bnoon For This Useful Post: | Abilor (05-26-2011), ak_spray (06-14-2012), bioevolve (07-01-2009), Constantin (05-10-2012), Doc (03-02-2010), Fobio (07-13-2009), jack_hammer (11-01-2011), Jsn_Rob (08-17-2012), labikesrcool (06-19-2011), Menace1 (04-14-2013), p057 (01-09-2012), phillyb (07-01-2009), Prodigalson (02-14-2017), psychophyr (11-27-2011), rfinkle2 (05-23-2011), sjdannen (11-26-2017), urbansurfer (08-18-2011) |
06-21-2009, 12:43 PM | #3 |
Rep Power: 0 Thanks: 1,559
| Not Ranked : 0 score sweet nice write up man and good work on fixing this annoying problem its about damn time somebody figured it out. I will be getting one from you friday when i get payed to go along with my saikou michi catch can and hopefully that will stop my 09 from smoking and all i have is a test pipe.
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
06-21-2009, 01:20 PM | #4 |
Rep Power: 0 Thanks: 179
Groans: 46
| Not Ranked : 0 score In the last picture, it's the Top gold colored bolt, correct? A banjo bolt in the pball world looks like the one on the side that looks to be an allen head screw. |
06-21-2009, 05:17 PM | #5 |
EDIT: Here's what a banjo body looks like in the automotive world. Used at brake line connections, clutch connections, oil fittings, etc. Also used a lot in the hydraulic industry.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall | |
The Following User Says Thank You to bnoon For This Useful Post: | phillyb (06-21-2009) |
06-21-2009, 05:24 PM | #6 |
Banned Join Date: Jun 2008 Location: misery
Rep Power: 0 Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score elaborate please |
The Following User Says NO Thank You to phillyb For This Un-useful Post: |
06-21-2009, 05:26 PM | #7 |
(Thread Starter) | Not Ranked : 0 score Edited above post for you.
06-21-2009, 05:32 PM | #8 |
Groans: 1,940
| Not Ranked : 0 score thanks, but i meant more like, what is this? what am i reading about and what does this do... pardon my ignorance |
06-21-2009, 05:47 PM | #9 |
Banned Join Date: Jun 2009 Location: Central Florida
Rep Power: 0 Thanks: 337
Groaned at 18 Times in 18 Posts
| Not Ranked : 0 score If I am not mistaken he is trying to reduce the amount of oil going into the CRHA. I think he is trying to reduce the amount of oil being burned. Hence his other thread but I could be wrong. |
06-21-2009, 08:28 PM | #10 |
Groans: 46
| Not Ranked : 0 score |
06-22-2009, 03:59 AM | #11 |
Groans: 1,940
| Not Ranked : 0 score ugh, i was trying to avoid that thread. thanks villa |
06-26-2009, 12:18 PM | #12 |
(Thread Starter) | Not Ranked : 0 score Resistance is futile! :phillyb:
07-01-2009, 05:24 PM | #13 |
(Thread Starter) | Not Ranked : 0 score Updated second post.
07-01-2009, 05:54 PM | #14 |
| Not Ranked : 0 score mine should be here tomorrow thank god my car is smoking a lot lately. are you using grade 8 bolts?
07-01-2009, 06:39 PM | #15 |
Groans: 1,940
| Not Ranked : 0 score shit is dope. thanks |
07-02-2009, 02:15 PM | #16 |
| Not Ranked : 0 score No more smoke Well i just got through installin my bnoon bolt (im claiming that term) and no more smoke. Just for good measure i let my car idle for about two minutes before i installed it and guess what, after two minutes blue smoke was pouring out the back, big surprise and i only have a test pipe. The install was pretty easy and once i fired her back up and let it sit for 8 minutes, not a puff of smoke at all. I am concerned though about one thing, the stock bolt has a small hole drilled all the way through it near the head, the bolt i got from bnoon only has a hole in one side of the bolt that doesnt go all the way through.... is everyone else's who got one of these like that? I hope i dont have to go uninstall all this shit because my bolt was fucked up.... but anyway if it was intentional good fucking job man im glad somebody finally figured this shit out. I also have a saikou michi catch can installed which seems to help in the process according to bnoon. Im glad i got one of these while they lasted...
07-02-2009, 03:52 PM | #17 |
(Thread Starter) | Not Ranked : 0 score Yes, it's supposed to only be drilled on one side to restrict flow down to .065".
The Following User Says Thank You to bnoon For This Useful Post: | Addikted To Boost (07-02-2009) |
07-02-2009, 03:57 PM | #18 |
| Neutral : +1 score awesome man thanks a lot.
07-04-2009, 08:48 PM | #19 |
MSF Punished Member Join Date: Jan 2009 Location: Vancouver, B.C.
Rep Power: 0 Thanks: 0
Groaned at 35 Times in 19 Posts
| Not Ranked : 0 score dude... love the pics |
07-06-2009, 07:26 PM | #20 |
Rep Power: 0 Thanks: 6,984
Groans: 88
| Not Ranked : 0 score I really appreciate you doing this....I now feel secure with my OCC, thicker oil, 900 idle and now bnoon-bolt.
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
07-06-2009, 07:54 PM | #21 |
Rep Power: 0 Thanks: 194
| Not Ranked : 0 score if anyone else takes this on i'd like to purchase one. don't have access to a drill press. |
07-13-2009, 10:11 AM | #22 |
Anyone else installed their bolt yet? Any troubles?
07-13-2009, 10:59 AM | #23 |
Driver Join Date: May 2008 Location: Toronto
Rep Power: 1986 Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I'm interested in one of your bolts, but I hear you don't ship to Canada...lemme know if that changes.
__________________ DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
The Following User Says Thank You to Fobio For This Useful Post: | mazda-speed-3 (06-04-2014) |
07-13-2009, 11:58 AM | #24 |
(Thread Starter) | Not Ranked : 0 score I will do it for actual shipping charges now. I talked to the UPS Store today and got setup so that it won't take me so long to ship international items.
The Following User Says Thank You to bnoon For This Useful Post: | Fobio (07-13-2009) |
12-03-2009, 01:23 PM | #25 |
Rep Power: 0 Thanks: 138
Last edited by shpankey; 12-03-2009 at 02:00 PM. Reason: MSF Database - Automerged Doublepost | |
12-13-2009, 09:43 AM | #26 |
| Not Ranked : 0 score are these still being made? I may take one if you make another batch
__________________ 2008.5 Mazdaspeed 3 AEM CAI, Forge BoV |
12-14-2009, 07:23 AM | #27 |
(Thread Starter) | Not Ranked : 0 score Yes, I can still make these. I've had them on EBay from time to time too. Paypal is brad@bnmotorsports.com, just make sure to PM me if you send funds as I don't check that email account very often anymore.
The Following User Says Thank You to bnoon For This Useful Post: | MarylandSpeed (05-08-2013) |
12-15-2009, 10:00 PM | #28 |
| Not Ranked : 0 score Could you e-mail me on how much it is shipped to Minnesota? xtreme_nickel@hotmail.com |
12-15-2009, 10:47 PM | #29 |
Rep Power: 371 Thanks: 558
| Not Ranked : 0 score looking for a bit of advise, my car has never smoked and I don't have the bnoon bolt currently installed, however I do have the PTP PVC restrictor on the car. Now I have a DP and there is never any smoke. Should I install the bnoon bolt or just leave well enough alone ? THANKS
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
01-07-2010, 08:27 PM | #30 |
Rep Power: 0 Thanks: 99
| Not Ranked : 0 score so, pls forgive the possible newbie question, but my take on this is that we have to restrict the oil flow to the CHRA of the stock turbo? And we KNOW that 065 is the correct size? Is/was there any thought on UNDER oiling the turbo? Also, does it have to be in the bolt itself or is it just anything in the oil feed line/bolt/banjo fitting itself? Thanks for the great effort!
__________________ 06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver 91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's |
01-10-2010, 06:13 PM | #31 |
| Not Ranked : 0 score ^^ |
01-11-2010, 04:44 PM | #32 |
| Not Ranked : 0 score I have already ordered the PTP Fix and hopefully it will be here soon. Should I get one of your bolts as well (Bnoon)?? How do I order one of your bolts?
__________________ 08.5 Mazdaspeed 3:CP-E Nano,CP-E Standback EMS w PNP,Custom DP w GHL Catback, Custom FMIC,H&R Sport Springs w SPC Rear Cambers,Turbosmart DP BOV |
02-06-2010, 03:35 PM | #33 |
My trials are documented on this site as to what I did to get rid of the oil/smoke burning issue due to crankcase overpressurization. Thicker oil, catch can, second PCV... even the PTP pill works all of the time except on trailing throttle, which my bolt gets rid of, so I run both. I'm currently working with electric vacuum modules to increase vacuum on the crankcase, especially under boost. Also need to prove/disprove that the stock PCV valves don't seal under boost well enough. Stay tuned... eventually.
The Following User Says Thank You to bnoon For This Useful Post: | Caldazar (02-06-2010) |
02-06-2010, 06:04 PM | #34 |
| Not Ranked : 0 score Thanx. As well, I have done some research on this issue with other cars as I have been involved with turbo Talons for 8 years or so now. People who have upgraded thier turbos to certain kinds often end up with smoking issues due to over oiling. It turns out that, yes, too much inlet oil is a bad idea, but ALSO having adequate oil drainage is just as important. I have not had a chance to look at the drain tube on the MZR yet. Is this adequate?
03-02-2010, 07:41 AM | #35 |
03-02-2010, 05:35 PM | #36 |
| Not Ranked : 0 score Cool, thanx for the info.
03-03-2010, 07:09 PM | #37 |
| Not Ranked : 0 score i sent you a pm bnoon about ordering one i just ordered my ptp pcv fix and im gonna change my oil to a thicker one any recommendations? How does 5w-40 sound and which brand should i use? Thanks, Alex |
03-17-2010, 04:54 AM | #38 |
| Not Ranked : 0 score HMMM... on ebay I found a similar bolt, the item number on ebay is 280479927007, but I'm not sure if the bolt is too long or too short. Anyone try the ebay one? |
03-18-2010, 05:36 AM | #39 |
03-18-2010, 01:54 PM | #40 |
Two feed holes, about .090 or .095 on both holes if I remember right.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall | ||
Getting new intercooler bolt? | iracer7 | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 05-18-2009 04:28 PM |
Broken Lug Bolt(s) | MrBig | MazdaSpeed 3/6 - Wheels & Tires | 4 | 01-20-2009 11:47 AM |
Full Bolt-On MS3 | 07cobaltss/sc | Mazdaspeed3/6 General Discussion | 20 | 12-24-2008 01:05 PM |
2871 really bolt on? | Speedie6 | Mazdaspeed3/6 General Discussion | 15 | 10-03-2008 01:03 PM |
