Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
Search Forum |
07-29-2008, 10:56 PM | #1 |
708 Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 Thanks: 21,982
(Thread Starter) | Not Ranked : 0 score Second bung on CP-e downpipe On the cast mouth downpipes, is the second bung (or should I say the first bung, the one that is originally cast) usable with the stock exhaust manifold? Doesn't seem like there is enough clearance to put a sensor in there. |
07-30-2008, 10:16 AM | #2 |
Approved MSF Vendor Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 Thanks: 425
You've got it right. The cast bung is a provision for a thermocouple if you want to monitor exhaust gas temperatures. You can buy oxygen sensor to EGT probe adapters that you can use with that threaded hole. | |
07-30-2008, 02:13 PM | #3 |
(Thread Starter) | Not Ranked : 0 score So a thermocouple for EGT will fit under the stock manifold? Do I need to be concerned with what gauge I am buying or should the thermocouple that comes with pretty much any EGT gauge fit? |
07-30-2008, 02:17 PM | #4 |
| Not Ranked : 0 score The thermocouple is actually just a thin piece of steel (I forget what alloy the K-type thermocouples are) so it's actually very easy to install in terms of space useage. I *believe* all EGT gauges use type K thermocouples, so it shouldn't make any difference really. |
07-30-2008, 10:30 AM | #5 |
ILL3ST Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 Thanks: 3,292
Groans: 105
| Not Ranked : 0 score wait i'm confused. so they both accommodate O2 sensors - if you want to run EGT you need an adapter? a lot of people say you should run a heatsink if you're putting in a new wideband - has it been necessary in your experience? |
07-30-2008, 02:14 PM | #6 |
Translation: I'm of no help Honestly, I'd just run the sensor and see if it eventually fails. If it does they're not a lot of money so they're (relatively) cheap to replace. But if you were really clever, you'd call Bosch (NGK, or whoever) and ask them directly. Sorry I couldn't be of more help! | ||
07-30-2008, 03:19 PM | #7 |
Groans: 105
just to make things clear - I want to run a Innovate LM-1 in the second bung in the cast bellmouth - is this not possible? | |
08-09-2008, 08:14 AM | #8 |
Rep Power: 0 Thanks: 154
| Not Ranked : 0 score subbing |
08-09-2008, 10:29 AM | #9 |
Eatin' Your Tuna Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 Thanks: 1,602
| Threads on EGT TK's are different across many manf's. You could do the standard o2 sensor bung, than get an adapter for your own TK threads... Or, just tap it yourself.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite | |
08-09-2008, 10:32 AM | #10 |
Banned Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 Thanks: 1,321
Groans: 57
| Not Ranked : 0 score yea i just noticed this, it looks like a aftermaket wb MIGHT fit witht the pg manifold, but i was under the impression that it was there for a wideband lol |
08-09-2008, 10:55 AM | #11 |
| I think the PG's are tapped for an aftermarket WB opposed to a EGT. YOu can find the adapters online as long as you know what NPT your EGT is.
08-09-2008, 12:11 PM | #12 |
Groans: 105
| Not Ranked : 0 score so where's the best place for a second wideband bung if that second one is unusable? also where's the best place for the EGT? turbo housing? manifold? i didn't think the DP would be a good place...? |
08-09-2008, 03:35 PM | #13 |
Rep Power: 2468 Thanks: 810
Groans: 60
The EGT should be in the runner coming from the leanest cylinder or in the collector of your manifold where it will get an average reading across all the cylinders..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
08-09-2008, 03:28 PM | #14 |
Rep Power: 0 Thanks: 1,642
Groans: 78
Groaned at 48 Times in 31 Posts
| Not Ranked : 0 score EGT - Turbo Manifold AFR - Some people put them on the DP others put them on the MP.
__________________ In reality I love lenny |
08-09-2008, 03:54 PM | #15 |
Groans: 105
| Not Ranked : 0 score alright, i'll just go to an exhaust shop and have one welded in near the stock 2nd. then i won't have to worry about a heat shield either. awesome. |
Stock exhaust manifold bung??? | supergoose | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 06-23-2008 04:56 PM |
downpipe | babcockxmx | Mazdaspeed3/6 General Discussion | 38 | 05-08-2008 07:47 PM |
Anyone with a Downpipe | speed3 | MazdaSpeed 3/6 - Turbo Induction | 1 | 03-30-2008 03:47 PM |
