Like Tree5Likes
  • 5 Post By Haltech
Closed Thread
 Old 12-18-2010, 11:25 PM   #1
Default Cobb Tuning - Mazdaspeed 3 & 6 / Subaru WRX/STi XLE BPV
Table of Contents
1 - Cobb Tuning - Mazdaspeed 3 & 6 / Subaru WRX/STi XLE BPV
2 - Page 2 - Technical Specs
3 - Page 3 - Installation
4 - Page 4 - Conclusion
With the introduction to Cobb Tuning making a comeback to producing hard parts, their anticipated release of a bypass valve is welcomed. Many of us have been waiting for a valve that is easy to adjust, sounds great and works 100% without any surging on the turbo compressor.
Question: So what exactly is a BPV and what is the difference between a BOV ( Blow off valve ) and a BPV (Bypass Valve)?
Answer: Its simple.. It all boils down to whether or not your car runs on speed density or mass air. If you have a car that is speed density, you will not have a mass air meter. So, effectively, you can run a Blow Off Valve which give off a very loud WHOOSH sound as you shift gears when in boost. A Bypass Valve takes that boosted air its venting, and recirculates it back into the intake. The importance of this on a mass air car is, that air was already metered and counted, therefore, venting that air to the atmosphere will cause your can to go rich. You are effectively removing air once counted and letting it blow in the air, so the car is going to add more fuel thinking that air is still incoming. Many enthusiast prefer the sound of a BOV, but generally they end up doing damage to their catalytic converters because of the rich conditions incorporated into running a VTA ( Vent To Atmosphere ) system on a MAF equipped car.
Question: Whats the purpose of these valves anyways?
Answer:
1) Boosted cars produce tremendous amounts of pressurized air that is pumped very quickly throughout the intake system. When the throttle body is open, this air can move very quickly into the engine. Once the throttle body closes, that fast moving air has no place to go. You have an abundance of air trapped in a small place ( charge pipes ) which can burst, causing significant damage to your intake system and even your cars hood. On turbocharged cars especially, its main function as a Bypass Valve (BPV)/Blow Off Valve (BOV), is to release this boost pressure to prevent this pressurized air from being diverted back toward the turbo impellers. If this pressurized air is not released, the diverted air can cause the turbine wheels to slow and possibly even stall, causing wear and damage to the turbocharger. A turbochargers impeller wheels can spin in excess of over 60,000 RPM, so if the impeller was to fail, you would see a lot of damage.
2) Its second function is being able to hold peak boost during gear change without a significant loss of boost during this event. A good BPV/BOV can hold a high amount of boost, for the needed time of shifting gears, without degrading performance.
3) One important thing to remember on a Mazda, the stock BPV leaks, even at as low as 8 psi of boost. That is almost half of the rated 15 psi a speed can produce stock!
Cobb Tuning has an answer for those looking for that loud blow off sound but with a safety margin, the Cobb Tuning XLE BPV. It can be setup to run in 3 modes, one of them being a hybrid mode that allows a minute amount of VTA without placing the car in a lean condition. You get that loud WHOOSH but you also get that important counted air, recirculated back into the system.
Even though this valve comes in at a steep price of $299, its not any more expensive then the most over-rated BPV on the market, the HKS SSBOV... The Cobb XLE doesn't require any type of flange adapter. The HKS requires an adapter to be fitted to it before it can be mounted on a Mazdaspeed 3 or 6. Installing the adapter is a pain since it uses a snap ring... The most troubling part of the HKS is how much plastic is found inside the valve, but more daunting, its inability to be adjustable. $300? Really? There are numerous reports on our forum about the HKS falling apart... The plastic inside is breaking... This is definitely not the type of valve i want inside my car. Step aside, we have a new BPV on the market thats going out be worth the $299.
The Cobb Tuning XLE BPV is one unit that can be adapted to several cars. First off, if you plan to replace your Mazda with a scoobie, this can be done with a simple part change without having to buy a new valve. Below are the specs on the Cobb XLE:
1 2 3 4 Next»
Haltech is offline
The Following 14 Users Say Thank You to Haltech For This Useful Post:
:: Gusto :: (12-25-2010), acidbbg (12-26-2010), AJ713 (12-25-2010), Ckmazdaspeed3 (12-18-2010), clowncar (12-19-2010), demonspeed09 (01-10-2013), HurricaneNOLA (12-21-2010), kritz (12-19-2010), labikesrcool (12-23-2010), mazdaspeed619sd (07-13-2011), MGM_GT3 (02-27-2011), sl33py24 (03-26-2013), speedysix (03-18-2012), Wholegrain (08-03-2013)
 Old 12-31-2010, 01:22 PM   #2
Added Videos of valve.. Idle Video and Flyby Video.
Haltech is offline
 Old 12-31-2010, 02:41 PM   #3
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
For $299 that BOV should work and look perfect..... that cast outlet makes it look like some Chinese crap.
SSinstaller is offline
 Old 12-31-2010, 04:04 PM   #4
True it does, but its also interchangeable to fit the other cars. Its probably much cheaper to do a cast piece then a nice billet piece.
Haltech is offline
AustinShoki (12-15-2013)
 Old 10-05-2012, 10:49 PM   #5
48k miles and still haven't had to degrease or had an issues.
Haltech is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f337/cobb-tuning-mazdaspeed-3-6-subaru-wrx-67552/
Blow Off ?? MPS ??????????????!!!!!!!!! - ???????? 19 - ??? ? Mazda3 MPS - ????? 3 ???? (Mazda 3 .ru) This thread Refback 03-20-2013 03:31 AM
Cobb Tuning - Mazdaspeed 3 & 6 / Subaru WRX/STi XLE BPV | Kevin Pugh This thread Refback 07-25-2011 07:33 PM
Cobb XLE BPV Mazdaspeed 3 - Subaru Impreza/STI - Autos - Maintenance and Repair This thread Refback 05-24-2011 08:01 PM
BOV et BPV de MS3 - Mazda 3 Quebec This thread Refback 05-06-2011 05:23 AM
Blow Off MPS !!!!!!!!! - 3 (Mazda 3 .ru) This thread Refback 03-11-2011 04:08 AM
Cobb Tuning - Mazdaspeed 3 and 6 Subaru WRX/STi XLE BPV This thread Refback 01-09-2011 09:21 AM
VIDEO: PIA/Cobb Tuning give the full STI swap treatment to Subaru Forester Haltech Automotive News 0 12-10-2009 10:50 AM
Cobb Tuning Mazdaspeed 3 Downpipe: Haltech MazdaSpeed 3/6 - ECU Computer Tuning 40 03-06-2009 06:16 AM
Cobb Tuning Mazdaspeed 3 FMIC Haltech Review Discussion 28 03-02-2009 12:40 PM
Cobb Tuning Mazdaspeed 3 Turbo Inlet Haltech Mazdaspeed Forums Performance Parts Reviews 0 01-30-2009 02:14 AM
Cobb tuning Mazdaspeed 3 STS Haltech Review Discussion 53 12-01-2008 04:08 PM
Page generated in 0.33380 seconds with 21 queries
