| Mazdaspeed Forums Performance Parts Reviews Mazdaspeed Forums takes a look at performance parts aimed for you Mazdaspeed vehicle. These are honest, thorough & unbiased reviews based off a manufacturers products. |
| The Editor ![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Neutral : +1 score ![]() Review Written By Lenny127 | Edited By Haltech Introduction We have finally received the much anticipated set of motor mounts from Cp-e. The set consists of the Rear Motor Mount (that has been out on the market for a while) and the newly released Passenger Side Motor Mount and the Transmission Motor Mount. At first glance it is obvious that some serious time was spent both engineering these pieces and machining them. They come in polished aluminum finish with their corresponding Cp-e logos engraved on them. As a community, we have been waiting for a company to provide us a solid mount solution and CP-e has delivered that to us. I can remember back in late 2007 and early 2008 when we needed a transmission mount solution. We would have to epoxy our torn mounts just to get some durability out of them. Let's not forget how many engines we saw hit the ground while moving due to failed mounts! Well, we no longer have to worry about this problem any longer. Please give a steady look at these pics as proof. Pure billet baby! ![]() ![]() ![]() ![]() Some of the research for these mounts comes after 8 months of testing in the Grand Am series mazdaspeed3s. These motor mounts cater to both the mild street car enthusiast and also to the hardcore racer that isn't as concerned with vibrations. The mounts can be chosen in either 60 or 75 durometer form, and unlike a lot of the other mounts out there Cp-e has chosen to use rubber instead of urethane for their bushings, it's felt that rubber has a better tolerance to engine heat than urethane , therefore increasing the life of the part . They have spared no cost when researching the materials to be used on these mounts, , billet 6061-series aluminum is used for a few reasons, durability, lessening of vibrations and harshness and of course looks. (these pieces look like they belong on a $100,000 car.) Also, on some of the parts that even more strength was necessary , ¼ inch mild steel was used ,laser cut of course for perfect fitment. One of the last differences you will notice with Cp-e motor mounts vs the competition is the size of the bushings used, they feel that rather than concentrating the forces created by the engine load all on the center bushing pin, increasing the material around this pin not only distributes the load more evenly but also absorbs some of those annoying vibrations usually related to performance mounts. The quality of these mounts speak for themselves as do the materials used, this makes these parts perhaps a bit higher cost than the competition, but when it comes to holding your engine in place and letting the pavement feel every bit of horsepower that you have earned then Cp-e mounts might just be the mounts for you. Why get the complete set? Let's face it, if your drive a Mazdaspeed3 and have spent any type of money modifying it's power output then you know that every horsepower you have made hasn't seen the pavement. We cannot kid ourselves into thinking that a FWD/Manual Transmission platform is the easiest power delivery platform out there..hardly the case. At some point we all have to make a choice about how intelligently we are going about putting some of this expensive added power to the ground. From torque steer, excessive tire-spin to the dreaded wheel-hop the Cp-e Motor Mount set addresses all these issues in a very balanced way that doesn't leave the driver thinking he is driving a go-kart from all the vibrations and noises. 1 2 3 4 5 6 7 8 9 Next» |
| The Following 22 Users Say Thank You to MSF Editor For This Useful Post: | 08.5MS3 (04-19-2011), 13Greyspeed3 (10-26-2013), ak_spray (04-19-2011), Arnie1229 (01-12-2015), Dano (04-27-2011), doizumi (04-30-2011), doubleflusher (04-17-2011), flappypaddles (10-30-2013), Hodgii (04-21-2011), i8urgti (04-19-2011), jo.jacques (04-18-2011), Juyoung (09-29-2012), labikesrcool (03-16-2012), mike8748 (05-18-2011), Miltron (12-20-2012), onelove221 (06-29-2011), rednofive (02-14-2012), ScarMS3 (04-17-2011), simply_pandora (06-17-2012), Skyman88 (04-25-2013), Speed3eak (04-17-2011), Staceye77 (09-06-2012) |
| Custom Performance Engineering™ Side Mounts are RELEASED | Adam is so pro | MazdaSpeed 3 - Engine, Transmission & Driveline | 251 | 10-10-2015 10:38 AM |
| Custom Billet Wheel Spacers | hnda etr | MazdaSpeed 3/6 - Wheels & Tires | 9 | 01-10-2011 11:45 PM |
| Anybody with a custom rear motor mount | DeadWayt | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 07-13-2010 10:42 AM |
| Pt Performance Driverside Motor Mount Bushings Failure | broncoblitz | Mazdaspeed3/6 General Discussion | 18 | 01-17-2009 02:04 PM |
