Search Forum |
03-23-2012, 03:28 PM | #1 |
Rep Power: 0 Thanks: 122
(Thread Starter) | Not Ranked : 0 score cobb AP stage 1 tune question okay i am confused. i just got my AP and cobb loaded the stage 1 tune for stock intake on 2012. why is everyone running the satge 0 tune if cobb is saying the stage 1 is good and safe for the 2012 speed3 also what needs to be in a log to get good feedback from forum and be useful |
03-23-2012, 03:32 PM | #2 |
Rep Power: 0 Thanks: 2,633
Groaned at 34 Times in 31 Posts
| Not Ranked : 0 score No clue. You are doing it right. Stage 0 is the equivalent to the stock tune. Just keep an eye on your fuel pressure, any dips below 1600psi and you need internals. All of the default values are fine for the logs, you'll want to add MAF voltage for MAF logs.
__________________ |
The Following User Says Thank You to Pseud0logik For This Useful Post: | jimmy (03-23-2012) |
03-23-2012, 04:16 PM | #3 |
Rep Power: 0 Thanks: 7,199
Groans: 219
| Not Ranked : 0 score lol....1600? Read the COBB manual and even that is on the safer side sometimes..
03-23-2012, 04:28 PM | #4 |
| Not Ranked : 0 score I'm pretty sure the Gen2s take a shit if their pressure drops below 1500psi at WOT, thus the 1600psi minimum recommendation which allows a little headroom.
03-23-2012, 04:36 PM | #5 |
Groans: 219
| Not Ranked : 0 score Ahhhh Gen 2 *doh* just replace it off the lot if you plan on modding . lol
03-23-2012, 04:13 PM | #6 |
Rep Power: 0 Thanks: 220
| Not Ranked : 0 score 3rd gear wot log is good. Find straight, flat and clean road. I use a freeway on ramp. Turn dsc and ac off. Set AP rev warning to 6500 rpm. In third gear around 2500 rpm start logging, wait a couple of seconds then stomp on pedal to floor (throttle position at 75-76%). Then when AP blinks when you hit 6500 let off gas and shift gears as normal. Prolly to 6th since you be going about 80 mph. Turn logging off. But honestly I wouldnt go wot much until you get fp internals. Use standard item list for the log and save as excel file.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
Stage 1 OTS tune help/question | captain slow | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 03-06-2012 07:39 PM |
What are the requirements for Cobb ap stage 1 tune? | caesura | 2010 MS3 - ECU Computer Tuning | 3 | 01-23-2012 08:32 PM |
Quick Question about Stage 1 vs Stage 2 | Roguevice | 2010 MS3 - ECU Computer Tuning | 11 | 07-16-2011 01:58 PM |
AP stage 1 tune Vs stock + TIP/SRI? | Ex_WRX_driver | Gen2 MS3 General Discussion | 12 | 05-24-2011 05:27 PM |
need tune after TurboXS Stage 1 kit? | solar | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 03-17-2011 10:12 PM |
