Search Forum |
05-25-2019, 05:35 PM | #1 |
Rep Power: 132 Thanks: 12
(Thread Starter) | Not Ranked : 0 score Transmission Fluid Leak This is a transmission fluid leak, right? I can’t tell where it’s coming from. Anyone know or have any ideas? |
07-03-2019, 03:43 AM | #2 |
Rep Power: 161 Thanks: 8
| Neutral : +1 score It could very well be the Pivot Shaft Seal, which is on the top of the transmision. Then leaking down the sides? Take a look at this how to, with great pictures to see if this is your problem. How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement - Mazdaspeed Forums
__________________ [FONT="Franklin Gothic Medium"]2007 MS3 // Cobb AP // Cobb SRI // SURE TIP // Forge BPV // ATP 3" Catless Downpipe // Custom Midpipe // Autotech Internals // JBR 88 RMM/TMM 80 PMM // Denso ITV22 // DCR VVT // Custom Head P & P // Wiseco 9:5 CR on Eagle Rods // Prosport Boost & Wideband Gauges // Rebuilt K04 // 20% Tint // H&R Sports // HID 9K Low / 6K Fogs // Engine built at IAG Performance, Westminster, MD // Stratified Tuned (partial due to engine noise = knock)[COLOR="Red"] |
The Following User Says Thank You to speed31982 For This Useful Post: | Itchy (10-04-2019) |
10-04-2019, 05:33 PM | #3 |
(Thread Starter) | Not Ranked : 0 score I replaced the pivot shaft seal. No more leak. I had stumbled across that post on my own and decided to try it. Way less expensive than what I thought a transmission leak would cost. |
The Following User Says Thank You to Itchy For This Useful Post: | Db09ms3 (10-04-2019) |
Transmission fluid leak? | trifdignn | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 07-27-2018 09:12 PM |
OEM transmission fluid | spinixguy | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 10-13-2014 11:04 AM |
Nissan recalls 3,065 Pathfinders for transmission fluid leak | Haltech | Automotive News | 0 | 04-24-2014 08:50 AM |
Transmission Fluid | Crazyspeed3 | Mazdaspeed3/6 General Discussion | 6 | 12-23-2011 07:32 PM |
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A | Haltech | Automotive News | 0 | 05-15-2009 04:10 PM |
