Search Forum |
11-13-2015, 10:48 PM | #1 |
Rep Power: 0 Thanks: 261
Groaned at 29 Times in 14 Posts
(Thread Starter) | Not Ranked : 0 score Stock MS3 genPu tune results: 33whp / 50wtq increase. No bolt-ons. First off some quick notes: I have been tuning a stock MS3 platform for about 6 months now, as I believe that fairly significant gains can be had without any modifications beyond the safety net of an HPFP upgrade. I keep seeing folks throwing parts on their car before even buying a COBB AP or any tuning platform, and it just seems like a waste of money and a non-scientific approach to making power. So, here is the premise: We have a ‘12 genPu, bone stock, 190 psi compression across all 4 cylinders, .028 gap on stock heat range NGK plugs, 20K miles on the engine (stock engine from Mazda), no aftermarket parts on it save for the HPFP, 93 Octane (possibly winter blend already). Having previous non-DISI tuning experience and having tuned this platform with various mods (3”intake, full catless and full catted DPs, and an FMIC) this particular tune took 22 very incremental maps to get to where I believe it is nearly final. The only issues I can see are a) very minor (< 1) transition KR around 2,500 rpm, and b) the 1.31KR under WOT described below. The following dyno runs were made, with an approx. 60 deg F ambient temp on a DynoJet. I have AP logs of dynos 2) and 3) but not 1), as the COBB AP was not married to the car during the first run: 1) (Blue) - Bone stock PU, HPFP upgrade, no COBB AP installed. Rounded 217 whp / 239 wtq. Video: https://youtu.be/p1D8Ag8RBn0 Ignore the weird plateau table thing in the AFR section, the dyno software had some glitch. The real AFR line for this is the bottom blue line. 2) (Red) - Bone stock PU, HPFP upgrade, my tune, version B.1.7.5 (I have a method for labeling each consecutive map). Rounded 257 whp / 294 wtq. Video: https://youtu.be/K4npPz-xfU4 At the end of the pull you can see the black smoke caused by a fuel-cut created KR which leads to a fuel dump by the ECU, a phenomena discussed here: Gen 2 Cobb ATR discussion Main tune points: Target AFR: 11.3, Target boost: 17psi tapering off to 15 (more like 14 on the dyno), and fairly conservative timing (12.5 deg max logged). 3) (Green) - Bone stock PU, HPFP upgrade, COBB OTS Stage 0. This was dynoed to show my long-standing suspicion that the stock Mazda map is NOT exactly what COBB tells is Stage 0 is, and the difference is obvious - 16whp / 10wtq increase in Stage 0 vs. the stock Mazda tune. I don’t know what is different about the Stage0 vs. the Mazda tune, but aside from very slightly colder intake temps, there were no environmental differences. A few degrees should not make that huge of a difference, hence it’s COBBs tune. Rounded 232 whp / 249 wtq. Video: phone wasn’t cooperating/rebooted. Identical to run 1). Dyno result notes: I believe run 1) was slightly under performing because the car sat on the dyno for a bit, heat soaking while we were getting ready. Since I don’t believe the COBB Stage 0 tune to be THAT far off from Mazdas’ stock tune, the real stock numbers are probably half way between the two, so around 224 whp / 244 wtq, which puts the car around a fairly average 13% drivetrain loss relative to the official stock 260hp/280tq crank figures. So the real tune gains are ~33whp / 50wtq, if we’re being conservative, or 40 whp / 55wtq if we go right by the difference between 1) and 2). Regardless, I have yet to see anyone post a bone stock tune with dyno results anywhere near those gains. Typically these are achieved with an intake/TIP or both, a DP and E blend. My philosophy is that this doesn’t need to be the case. I dislike the extra noise when it is not directly related to performance (and even then it’s a trade off for a daily). Having all stock parts and making this kind of power on 93 is how I believe this car should have been sold by Mazda. I’m sure there are some reliability concerns, but none that overshadow those present with a modded (with parts) platform. As an aside: Virtual Dyno representation of the logs for pulls 2) and 3) is showing power numbers about 40% higher than noted. Sort of useless. (http://oi64.tinypic.com/20aas5g.jpg) Tune notes: I tried to be as conservative as I could, most of the timing is 1-1.5 degrees under any KR values of .5 or above that I’ve encountered during my logs. I’ve been very incremental about increasing timing, so I never really hit KR over 1 (except for the 1.31 on the dyno). The 1.31KR seen in the log is responsible for the power dip around 5k rpm. This wasn’t present during my street logs, as the loads hit on the dyno were lower than on the street and those cells will need to have 1-1.5 deg of timing taken out, just to be safe. I only got to do 3 pulls, so I didn’t have the opportunity to log another run with my tune to see if it was a fluke. Overall notes: I hope this map and dyno help the community, as I’ve gotten help from the multiple guides (and put one together myself in the FAQ), threads, and other people’s expertise to get to this point. My map is free for anyone to copy as they wish, I just ask that you don’t do it for commercial purposes - I’m posting it up here so that folks can have a much better base for their tunes than what COBB provides us with, and potentially decide that this is more than plenty for a reliable daily. Some slight alterations may be necessary as no one car is exactly the same, but this gets you 95% there. I did learn a crap load while working on this tune, so keep that in mind before you simply copy/paste and never touch it again. One of my biggest goals with the maps was to create a very smooth map, which I’ve succeeded at if you look at the power curve compared to the stock and Stage 0 maps. I’ve applied this to most tables, making them as smooth and non-peaky as possible, while maintaining values needed to run the mpg/power figures I was looking for. I may stop here (after fixing the transition/tip-in KR and the 1.31 KR spot), and perhaps wait ‘til the stock turbo craps out and throw the hybrid K04 on there down the road, which would warrant a re-tune. The car drive great and smooth, slightly touchy after you pass the 1.0 load threshold, but that is a preference that can be tuned out, if so inclined. The dyno sheet, my logs and my map are attached. Comments and questions are welcome. I’d like to thank everyone who has been putting up with my bugging them about random stuff over the past few years and their posts/threads which I’ve perused over and over, especially @Enki; @ms3blackmica; @phate; @rfinkle2; @Lex; @Rokusek; @Captain KR; @silvapain; @timjs; @JeffroMS3; @dereeek; @mikesms3; @SofaKingAwesome; whoever banned/unbanned me from shout at any given point, and the entire CT NATOR community for being awesome. Bonus: Corner weighed stock genPu MS3, full tank of gas, TRMotorsports C3 17x9 wheels, Hankook V12 255/40-17 tires, and a small 8” ZoomBox-cased sub in the driver side trunk cavity + small 1ch amp in place of stock spare-mounted sub (both weigh 25lbs at best): Without driver (3311 lbs): https://lh3.googleusercontent.com/-t...4_175351-1.jpg With 194lbs fat ass driver (3505 lbs): https://lh3.googleusercontent.com/-f...024_175836.jpg DISCLAIMER for map downloads and usage: Downloading and using these maps are AT YOUR OWN RISK. Neither MSF nor I will be held accountable if anything were to happen to your car after using/mimicking/copying/installing one of these maps. Update: Uploaded map vB.1.7.9 - Minor tweaks to Closed Loop, Fuel and ignition tables, made sure CL is entered early and the newly available Closed Loop Max Load Limit tables are the same as the Closed Loop Max Load tables. Finally fixed the overly touchy throttle between load 1 and 1.5, now the acceleration is much smoother and linear. SWAS disabled in 1st/2nd gears, using the new COBB update. This is the final stock map. All future maps will be supporting mods. Having driven on it, transition, part throttle, and WOT KR are all 0.5 or less, which I believe is the true mark of a proper tune.
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb http://www.mazdamotorsports.com/ Last edited by BAT-man; 12-28-2015 at 08:13 AM. Reason: Updated map B.1.7.9 |
The Following 26 Users Say Thank You to BAT-man For This Useful Post: | Aro (05-04-2016), aviator79 (11-13-2015), biggman026 (11-14-2015), BlackFlag (11-14-2015), btstarcher (11-27-2015), Code Monkey (11-14-2015), doctavus (11-26-2015), Easter Bunny (11-14-2015), Enki (11-14-2015), Erick13Speed3 (11-14-2015), Fusion_MS3 (11-23-2015), hartlch (11-14-2015), jabeel00 (11-25-2015), KCi (11-14-2015), macdiesel (11-26-2015), MacheteJames (12-06-2015), maisonvi (11-18-2015), Mattyhawk1 (11-27-2015), memin (11-25-2015), mzr0818 (11-19-2015), neganox (11-30-2015), Pu Manchu (11-14-2015), rfinkle2 (11-15-2015), Rokusek (11-18-2015), smoogs12 (11-14-2015), speed23 (11-19-2015) |
11-13-2015, 11:30 PM | #2 |
Rep Power: 0 Thanks: 122
| Not Ranked : 0 score pretty cool comparison
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
11-14-2015, 04:42 AM | #3 |
Rep Power: 0 Thanks: 6
| Not Ranked : 0 score Thank you This is exactly the info I wanted and thanks for making the maps available. I knew there were gains to be had from just a tune. PS I didn't think it would be this much good job man. |
11-14-2015, 06:35 AM | #4 |
MSF's Punishing Member Join Date: Apr 2011
Rep Power: 2794 Thanks: 5,165
Groans: 546
| Not Ranked : 0 score now start all over and do e85.
__________________ 94 M MS6 IS350 |
The Following 11 Users Say Thank You to Pu Manchu For This Useful Post: | BlackFlag (11-14-2015), broda (11-14-2015), btstarcher (11-27-2015), Cheapspeed (11-25-2015), Easter Bunny (11-14-2015), MS3Shadow (11-14-2015), mzr0818 (11-19-2015), Neverlift (11-14-2015), Rokusek (11-18-2015), smoogs12 (11-14-2015), WAMBUSHHHH! (11-17-2015) |
11-14-2015, 11:20 AM | #5 |
Rep Power: 0 Thanks: 674
| Not Ranked : 0 score Its CT. One E85 station an hour away in Groton. Its not an option for most....well for the 7 of us left its too far.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
The Following User Says Thank You to aviator79 For This Useful Post: | smoogs12 (11-14-2015) |
11-14-2015, 02:45 PM | #6 |
Rep Power: 0 Thanks: 11,169
Groans: 423
| Not Ranked : 0 score Waterford =P
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
11-18-2015, 04:37 PM | #7 |
Rep Power: 3957 Thanks: 9,694
| Not Ranked : 0 score Good work man. I'm just glad you have stopped asking a million questions in a matter of minutes and don't give me enough time to answer the first one before I have to start thinking about the 7th one lol. Either way, This is awesome! -PJ
__________________ I'm not back... But help me find SOMETHING Daily: Evelyn (Eve), 04 4Motion 6Speed VW Passat W8 Sold to @yourstruly; : Isabella (Izzy), 06 MS6 GT with Navigation #1271 Sold to @downmented; : Audrey, 95 Miata Totaled: Vivian (Viv), 07 MS3 bolted and built, brutally murdered by a texting driver |
The Following 3 Users Say Thank You to Rokusek For This Useful Post: |
11-18-2015, 09:18 PM | #8 |
(Thread Starter) | Not Ranked : 0 score Oh, I'm not done w/questions. This is just the beginning of a beautiful friendship
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb http://www.mazdamotorsports.com/ |
11-23-2015, 11:53 PM | #9 |
Rep Power: 0 Thanks: 19
| Not Ranked : 0 score Excellent Work. Thank you for posting this! If you don't mind me asking what brand HPFP was on the vehicle? |
11-25-2015, 05:32 PM | #10 |
(Thread Starter) | Not Ranked : 0 score Autotech internals.
11-25-2015, 07:41 PM | #11 |
Rep Power: 0 Thanks: 2,778
__________________ 3rd rebuild on the way...maybe... |
11-25-2015, 11:20 PM | #12 |
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb http://www.mazdamotorsports.com/ | |
11-26-2015, 07:08 AM | #13 |
Sent from my SM-G360T using tapatalkreplace
__________________ 3rd rebuild on the way...maybe... | |
11-26-2015, 08:06 AM | #14 |
| Not Ranked : 0 score breh follow the right threads and u might know there is a fix for running 100% e85.. come on now!!!
11-26-2015, 08:36 AM | #15 |
| Not Ranked : 0 score The fuck you talking about.
11-26-2015, 09:02 AM | #16 |
| Not Ranked : 0 score this shit nigga!!! @Cheapspeed; E85 Remedy with HPFP Hardware modifications IE HPFP Internals For E85 read away!!!
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna Last edited by MSP611; 11-26-2015 at 12:23 PM. |
The Following 2 Users Say Thank You to MSP611 For This Useful Post: | btstarcher (11-27-2015), Easter Bunny (11-30-2015) |
11-26-2015, 11:32 AM | #17 |
(Thread Starter) | Not Ranked : 0 score Hmm... a bit off topic @Cheapspeed;, this is a 93-only tune, results, and thread. Nowhere in my thread did I indicate that e85 was being used or that the car was using the HPFP upgrade you mentioned.
The Following 2 Users Say Thank You to BAT-man For This Useful Post: | btstarcher (11-27-2015), robbspeed (11-26-2015) |
11-26-2015, 01:57 PM | #18 |
11-26-2015, 10:03 PM | #19 |
(Thread Starter) | Not Ranked : 0 score This is why @Pu Manchu; is not allowed to post. You see what u did to the goddamn thread...
11-26-2015, 11:47 PM | #20 |
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna | |
The Following User Says Thank You to MSP611 For This Useful Post: | btstarcher (11-27-2015) |
11-27-2015, 07:28 AM | #21 |
11-27-2015, 07:44 AM | #22 |
Rep Power: 1975 Thanks: 6,199
| Not Ranked : 0 score More importantly, why the fuck would a completely stock MS3 want to run pure e85? Makes no sense.
The Following User Says Thank You to btstarcher For This Useful Post: | BAT-man (12-20-2015) |
11-27-2015, 08:17 AM | #23 |
Rep Power: 0 Thanks: 152
| Not Ranked : 0 score @littleloogy; has gone 1000s of miles on full corn with no issues so yes IE internals are the shit. I still have mine new in the package since im running out of full with my turbo on e30 so no need for them yet.
__________________ 06 MS6 GT Titanium Gray II Metallic |
The Following User Says Thank You to davychronic For This Useful Post: | Cheapspeed (11-27-2015) |
11-27-2015, 08:34 AM | #24 |
| Not Ranked : 0 score Because MSF.
11-28-2015, 09:47 AM | #25 |
Rep Power: 0 Thanks: 117
| Not Ranked : 0 score The same reason someone would run 93 octane vs 91 octane on a completely stock MS3...
__________________ 2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks 2003 A4 1.8TQ APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars. |
11-28-2015, 12:05 PM | #26 |
Rep Power: 0 Thanks: 1,356
Groans: 50
| Not Ranked : 0 score I don't think you could get anywhere close to exploiting e85's potential with a completely stock ms3.
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. |
The Following User Says Thank You to robbspeed For This Useful Post: | btstarcher (11-28-2015) |
11-28-2015, 12:16 PM | #27 |
| Not Ranked : 0 score We're talking simply the HPFP like the OP did. Just to see, why the hell not?
11-28-2015, 12:26 PM | #28 |
Groans: 50
| Not Ranked : 0 score Btstarcher said why would you run e85 on a completely stock car and the other dude said same reason someone would choose 93 vs 91. 93 and 91 are more comparable with 93 having a bit of an edge. But with how much extra boost you can safely run on straight e85 you would need a bunch of flow mods. I'm assuming that's what btstarcher meant when he said that.
11-28-2015, 08:05 PM | #29 |
| Not Ranked : 0 score Because there's absolutely no advantage to running straight e85 with the stock turbo. You can achieve MBT with an e33 mix.
The Following 2 Users Say Thank You to btstarcher For This Useful Post: | robbspeed (11-28-2015), speedfreak44 (11-28-2015) |
11-28-2015, 08:08 PM | #30 |
Rep Power: 0 Thanks: 462
| Not Ranked : 0 score I would bet a completely stock ms3 on full e85 would gain quite a bit of power. E85 would offset the poor capability of the stock tmic to cool and it would also allow max timing which is where a lot of the ms3 power comes from
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
The Following User Says Thank You to speedfreak44 For This Useful Post: | btstarcher (11-29-2015) |
11-29-2015, 12:52 AM | #31 |
Groans: 546
| Not Ranked : 0 score would you bet your own labor to turn your car back to stock? i bet your tuner would donate the tune if you were on board.
11-29-2015, 03:45 AM | #32 |
| Not Ranked : 0 score I would bet he wouldn't because it is self tuned lol. It is also a pain in the ass for me to get e85 I have to drive over an hour with large fuel tanks to store it in my shed so I gave up on it a while back
11-29-2015, 05:11 AM | #33 |
You would gain literally no timing advantage by using e85 vs using e33. That's why I pointed out that MBT can be achieved with the 33% mix.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
11-29-2015, 06:10 AM | #34 |
Your post was 3 mins before mine and I did not refresh my screen...
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) | |
11-29-2015, 06:18 AM | #35 |
I'm considering doing this same thing with either e50 or e33 in the not so distant future, will post my results.
11-29-2015, 07:04 AM | #36 |
| Not Ranked : 0 score Hands down the best way to quick power for us on k04 is 3" full intake, fuel pump internals, accessport, e85, tune. These cars make great power on the cheap! I <3 my ms3 Used 3" intake = 150-200 Internals = 200-350 Apv2 = 250-300 Tune = priceless
11-29-2015, 08:07 AM | #37 |
| Not Ranked : 0 score Plus test pipe. Maybe TMIC. I want to try tuning first and after each modification to see how much each piece opens it up. I'll probably tune for 93 octane and the e50 (easier to mix). Need to see if any tuners would be willing to work with me; the last time I attempted to tune for e50 I blew my shit up LOL
The Following User Says Thank You to btstarcher For This Useful Post: | robbspeed (11-29-2015) |
11-29-2015, 08:18 AM | #38 |
| Not Ranked : 0 score Yes those would be great additions but I was stating best bang for the buck that should land you at 300whp in a 3200lb car The tune is not too terrible to do especially if you already have a dialed in 93 to start with
11-29-2015, 08:55 AM | #39 |
| Not Ranked : 0 score i was going to try to map you posted but when i go to transfer the map to my AP3 it comes up with a notice that says "this map is locked to a V2 serial number. to use V2 locked maps, you contact technical support to upgrade your V3 accessport. are you sure you want to copy this file to the accessport?" is it still all right to use that map? |
11-29-2015, 10:31 AM | #40 |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f428/stock-mazdaspeed-3-genpu-tune-results-33whp-195501/ | ||||
Posted By | For | Type | Date | |
Stock MPS - Looking To Mod - Page 2 | This thread | Refback | 11-18-2015 07:18 PM |
Drag race results for GenPU k04 | doctavus | Drag Racing | 5 | 01-09-2014 10:12 PM |
Results of a tune by RichTune | snypeZ | MazdaSpeed 3/6 - ECU Computer Tuning | 32 | 06-08-2013 12:41 PM |
First tune w/bolt-ons in | lug | Ford Focus ST Ecoboost - General Discussion | 27 | 10-17-2012 02:40 PM |
Dyno results after lex tune | Zbrit00x | 2010 MS3 - Dyno Sheets/Discussions | 6 | 02-25-2012 05:48 PM |
GM sales increase, but tight stocks crimp results | Haltech | Automotive News | 0 | 08-02-2011 10:00 PM |
