Search Forum |
07-31-2011, 10:55 AM | #1 |
Rep Power: 269 Thanks: 173
Groaned at 22 Times in 8 Posts
(Thread Starter) | Not Ranked : 0 score installing downpipe ill be recieving tomorrow to tuesday the downpipe and wanted to know if i can do it with the ramps or should i got to a shop and have a lift what u suggest
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front ptp studs/seals pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car |
The Following User Says Thank You to dr_banano For This Useful Post: | seby1992 (10-02-2013) |
07-31-2011, 10:58 AM | #2 |
Rep Power: 1040 Thanks: 4,110
Groans: 661
| Not Ranked : 0 score It's doable on ramps. That's how mine was done |
The Following 3 Users Say Thank You to manelscout4life For This Useful Post: |
07-31-2011, 04:41 PM | #3 |
Rep Power: 0 Thanks: 7,500
Groans: 669
| Not Ranked : 0 score It's gonna take you a lot longer on ramps/stands, but it's doable. Be very patient. Give yourself 6-8 hours if this is your first DP install. Read as much HowTo guides as possible, and remember to be careful with the O2 sensors as they are very expensive to replace.
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
The Following 5 Users Say Thank You to adlpb For This Useful Post: | Broxer (09-01-2011), Monotonous ONE (08-01-2011), rfinkle2 (08-01-2011), skeurton (07-31-2011), TexasSpeed3 (10-06-2011) |
07-31-2011, 05:05 PM | #4 |
Rep Power: 2996 Thanks: 16,814
Groans: 451
| Not Ranked : 0 score I did mine on jackstands last week. Not too bad. See if you can get a second set of hands, that would have made it cake for me. Get a ratcheting 14mm for the DP to turbo bolts when you reinstall it. Make sure you have several extensions and at least a swivel for your socket. Wear gloves. Oh, and get a can or two of PB Blaster and start soaking that shit now.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot Last edited by Bucker; 07-31-2011 at 05:05 PM. Reason: MSF Database - Automerged Doublepost |
The Following 4 Users Say Thank You to Bucker For This Useful Post: |
07-31-2011, 05:11 PM | #5 |
Rep Power: 0 Thanks: 324
I PB blasted mine the night before, morning of, and 1 hour prior to installation. I also did it when the motor was warm, makes the o2 sensors come out a bit easier. The pb blaster will smoke a tad when the engine gets hot, dont be alarmed.
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers | Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ | |
07-31-2011, 05:50 PM | #6 |
Rep Power: 0 Thanks: 28,760
| Not Ranked : 0 score I installed a DP yesterday. First time for me and it took a good 7 hours... - I did it with the car up on jack stands and it wasn't bad at all. Just make sure you do all the work you need to do topside before raising it. - To reiterate what was already said, read as many how-to guides as you can find. I printed out 4 different ones. They were all relatively the same, except for a few steps here and there. So it allowed me to put together my own plan of attack. - I ended up removing all the heat shields in the engine bay, which was honestly the most time consuming part for me. But by doing so, I was able to remove the 5 turbo nuts from the top. - I had 10K miles on my car and the top O2 sensor and 5 turbo nuts came off like butter. - The second O2 sensor was the only problem I ran into. It would not come out. I PB'd the shit out of it, took a blowtorch to it, but it just wouldn't budge. Thankfully, I bought new sensors for backup, just in case I fucked them up. - When putting it all back together, check and re-check everything. I managed to miss tightening one of the TMIC hose clamps, but caught it during my re-check. I also always torque everything twice. - Tools that saved my ass: 18" breaker bar + wobble extensions.
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
The Following 2 Users Say Thank You to skeurton For This Useful Post: | BPASPEED (10-07-2011), uncorked11 (12-05-2011) |
07-31-2011, 06:07 PM | #7 |
Rep Power: 0 Thanks: 323
| Not Ranked : 0 score Probably easier to do on the lift..
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP |
The Following User Says Thank You to irishking03 For This Useful Post: | skeurton (07-31-2011) |
07-31-2011, 06:10 PM | #8 |
Rep Power: 0 Thanks: 524
| Not Ranked : 0 score @skeurton. Where did you buy the post cat sensor? Decent price? I'm doing my dp install sometime this week.
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) |
07-31-2011, 06:26 PM | #9 |
Rep Power: 1310 Thanks: 4,310
Groans: 134
| Not Ranked : 0 score I did it with JBarone and it was a first for both of us. It took about 3.5 hours. The two tips I have are: 1)take lots of time with the 02 sensor, douse that shit in pb blaster and just keep working it back and fourth super slow... I made us spend about 20 minutes going back and fourth to make sure that I didn't have to buy a new one... However I had to apply tons of force for the first jolt... we actually broke the first o2 socket!... Which leads me to the second and most important tip 2) Get as much off as you can easily, then, turn the car on and let that shit idle for a good 5-10 minutes so everything gets super hot, then proceed with all the hard to loosen shit... This made everything SO MUCH easier for us. ... we did it on jack stands. |
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post: |
07-31-2011, 06:28 PM | #10 |
Here are the part numbers for NGK and Bosch: NGK - 24442 (rockauto.com has these for $91 - LINK) Bosch - 13581 (Amazon has these for $76)
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges | |
The Following 2 Users Say Thank You to skeurton For This Useful Post: | BPASPEED (10-07-2011), turbo test (07-31-2011) |
07-31-2011, 06:37 PM | #11 |
| Not Ranked : 0 score Great info! Since my car is three months old I'm hoping the sensors come out easy. If not I now know where to get them. Thanks.
07-31-2011, 06:41 PM | #12 |
Rep Power: 0 Thanks: 24,632
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score subbed for good info.
__________________ 2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned |
07-31-2011, 06:43 PM | #13 |
Groans: 134
And my car didn't have that many miles, but it was a bitch to get them out and bewsted without many miles had his rear cross threaded from the factory! | |
07-31-2011, 06:56 PM | #14 |
| Not Ranked : 0 score Well I'm prepared, I've got two cans of PB, a torch, big ass breaker bar, swivel extensions, a heavy walled 02 socket from NAPA, your suggestion and the mind set that this bitch won't win. I will. LOL I'll probably do like you said: Bust loose what ever I can from the top and bottom. Whatever doesn't budge I'll warm up the car and then work on them till they do get loose. How did you guys keep the o2 wires from laying on the new downpipe? The oem heatshield has those clips that keep the wires from laying up against the hot dp.
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) Last edited by warlord; 07-31-2011 at 07:08 PM. |
The Following 3 Users Say Thank You to warlord For This Useful Post: |
07-31-2011, 08:02 PM | #15 |
Groans: 451
| Not Ranked : 0 score OH! Also, I used an adjustable wrench to remove the second o2, my o2 socket flexed from too much torque so I said fuck it and used something better. That did the trick.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
07-31-2011, 08:47 PM | #16 |
| Not Ranked : 0 score Is this enough selection for the o2 sensor?
The Following 4 Users Say Thank You to warlord For This Useful Post: |
07-31-2011, 08:49 PM | #17 |
| Not Ranked : 0 score sledge hammer for stress relief if you can't get it out???
07-31-2011, 08:58 PM | #18 |
| Not Ranked : 0 score "The persuader".
07-31-2011, 09:04 PM | #19 |
Groans: 451
| Not Ranked : 0 score LOL I was going to say... I wouldn't use the hammer on the sensor. Oh, another point... I pried the stocker off because I couldn't get it over the bottom left turbo stud... I know I could have removed the stud but that seemed like too much effort when I have a 30" screwdriver I have been itching to use.
07-31-2011, 09:44 PM | #20 |
Rep Power: 356 Thanks: 20,356
| Not Ranked : 0 score I have my pipe in the garage waiting to go in this week ill let you know how it goes too thanks for the PB tips im gonna start it now Lol
__________________ _____________________________________________ 2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, . |
08-01-2011, 06:26 AM | #21 |
(Thread Starter) | Not Ranked : 0 score [QUOTE=How did you guys keep the o2 wires from laying on the new downpipe? The oem heatshield has those clips that keep the wires from laying up against the hot dp.[/QUOTE] yeah what about it???
08-01-2011, 06:30 AM | #22 |
| Not Ranked : 0 score I was able to run it behind the foil heat shield that's against the firewall...
08-01-2011, 10:20 AM | #23 |
whats that grey stuff on the bolt?
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front ptp studs/seals pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car | |
08-01-2011, 10:22 AM | #24 |
Rep Power: 0 Thanks: 694
__________________ Stratified Tuned 2011 MS3 | 410 HP - 402 TQ | Dynojet 10-21-12 |
08-01-2011, 11:02 AM | #25 |
| Not Ranked : 0 score Anti-seize is right. I went a little overboard with it. You should have seen the big cloud of smoke coming from the engine bay as it burned off when I first started the car. Sent from my DROIDX using tapatalkreplace
The Following User Says Thank You to skeurton For This Useful Post: | rfinkle2 (08-01-2011) |
08-01-2011, 11:12 AM | #26 |
(Thread Starter) | Not Ranked : 0 score [QUOTE=skeurton;965230]Anti-seize is right. I went a little overboard with it. You should have seen the big cloud of smoke coming from the engine bay as it burned off when I first started the car. Sent from my DROIDX using tapatalkreplace[/ should i aply that too??on the bolts??
08-01-2011, 11:25 AM | #27 |
| Not Ranked : 0 score Yeah, in case you need to take them off again. Anti-seize will... well... help prevent the nuts from seizing up onto the studs over the long run. Sent from my DROIDX using tapatalkreplace
08-01-2011, 11:26 AM | #28 |
| Not Ranked : 0 score Oh, and use anti-seize on the O2 sensors as well. Sent from my DROIDX using tapatalkreplace
08-01-2011, 03:41 PM | #29 |
| Not Ranked : 0 score I installed my downpipe 2 weekends ago and my car did the same thing lol. Yes, use some if you plan on taking it off one day.
The Following User Says Thank You to krazycoble For This Useful Post: | skeurton (08-11-2011) |
08-01-2011, 05:01 PM | #30 |
Rep Power: 0 Thanks: 4,450
| Not Ranked : 0 score In anticipation of my dp install (when it cools off in a couple months) I pulled my 02 sensor and anti-seized it. The hardest part was threading it back in, the stupid wires kept twisting. I'm going to do the bottom one next time I'm under the car.
__________________ 2009 MS3 sport MGM |
The Following User Says Thank You to wankular For This Useful Post: | rfinkle2 (08-02-2011) |
08-01-2011, 08:35 PM | #31 |
(Thread Starter) | Not Ranked : 0 score well just began today the intake is comingo on wendsday today i changed the plugs and sprayed wd40 on the bolts and the o2 senors planning on taking apart everything tomorow night so when i get the downpipe just begin isntallation going part by part taking my time better so i dont get frustated illl keep up with the install tomorrow
The Following User Says Thank You to dr_banano For This Useful Post: | rfinkle2 (08-02-2011) |
08-01-2011, 09:29 PM | #32 |
Rep Power: 0 Thanks: 23,548
Groans: 30
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks | |
The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post: | skeurton (08-01-2011), TexasSpeed3 (10-06-2011) |
08-02-2011, 08:13 AM | #33 |
Groans: 451
| Not Ranked : 0 score LOL WD40? Have you not read anything in here about how to remove it? You need something like PB Blaster to remove this shit.
08-02-2011, 09:25 AM | #34 |
(Thread Starter) | Not Ranked : 0 score yeah i did but here i we dont get pb so i just have wd40 and the car is 4000 miles so i dont think they will be that hard ill be getting them today night after i give them a bit of heat
08-02-2011, 09:28 AM | #35 |
Groans: 669
| Not Ranked : 0 score As posted before, how many miles you have doesn't really affect how tough it will be to remove the 02 sensors. I really suggest you order a couple cans of PB blaster online and wait to use them. WD-40 will not do anything. If you happen to cross thread the 02 sensors you're looking at at least $200 in parts and not being able to use your car until they arrive.
The Following User Says Thank You to adlpb For This Useful Post: | rfinkle2 (08-02-2011) |
08-02-2011, 11:48 AM | #36 |
(Thread Starter) | Not Ranked : 0 score weill the best i could find is this i think this is beter then wd40 and got the anti seize yeeey
08-02-2011, 12:22 PM | #37 |
Rep Power: 0 Thanks: 21
| Not Ranked : 0 score figured this is a good question to post here but I got my dp installed by an exhaust shop and now both codes saying my sensors are bad are coming up. well have been there since I got my dp installed. well my question is that is there a way to test if they are actually bad or just need a defouler since I went catless
__________________ 08 CWP MS3 GT -- CP-E Nano SRI-PG TIP-Turbosmart BPV-Ebay 3" catless DP-Cobb AP-TurboXS FMIC-KMD FP Internals-Medieval RMM-TWM STS-Redline Goods Shift/E-Brake boot and armrest cover-BC Coilovers-Advan SA3R 18x9.5 +22-Federal595 215/35/18 |
08-02-2011, 12:26 PM | #38 |
Groans: 669
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq | |
08-02-2011, 12:27 PM | #39 |
| Not Ranked : 0 score I think you do need a defouler on the bottom 02 sensor of an ebay dp. It was discussed on one of the ebay dp threads.
08-02-2011, 12:43 PM | #40 |
Rep Power: 0 Thanks: 37
| Not Ranked : 0 score ebay downpipe thread? Anyone have a link for that? My ebay DP should be arriving soon and I wanted to see the issues I may run into with installation, sensors, fitments, CEL's, ect...
__________________ 2006 Black Mica Mazdaspeed 6 GT Autotech HPFP internals, M2 3" Catless Downpipe (+ bnoon bolt), 3" Cp-e Catback Exhaust, Corksport exhaust hangers, Forge BPV, Cobb SF SRI, Cobb TIP, Cobb AP: Stage 2 + SF + TIH 93, Denso ITV-22's, BC Coilovers BR Type, Mishimoto OCC To install: CX Racing 29x9x3 intercooler + custom FMIC, TurbineTech rear diff mount, defrost vent pod gauge + other goodies |
need hlp after installing SU BPV | camdensms6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 11-02-2009 02:54 PM |
help on installing MBC | tburton101 | MazdaSpeed 3 - How-To's | 1 | 08-27-2009 02:35 PM |
