JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
Search Forum |
06-14-2016, 04:20 PM | #1 |
Rep Power: 0 Thanks: 1,205
(Thread Starter) | Not Ranked : 0 score JBR Coilovers? That's exciting. I bet those will be some awesome coilovers. @JBR; how's it goin? Suspension Part Three: The Pertinents | JBR Blog edit They're on sale now! W00t! http://www.jamesbaroneracing.com/sho...roducts_id=960
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines Last edited by [R]usty; 06-17-2016 at 02:28 PM. |
The Following User Says Thank You to [R]usty For This Useful Post: | JBR (06-16-2016) |
06-14-2016, 05:15 PM | #2 |
Approved MSF Vendor Join Date: Sep 2009
Rep Power: 7118 Thanks: 7,203
More info in the next couple of days. | |
06-14-2016, 05:22 PM | #3 |
Rep Power: 3369 Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Please refrain from using the word "dampening" in promotional marketing material. Its use runs rampant in the rebranded coilover market, and I stop reading as soon as I see it. I can't be the only performance purist who is annoyed by this.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp |
The Following 9 Users Say Thank You to Neverlift For This Useful Post: | Crarrs (06-14-2016), Design (06-15-2016), g00s3y (06-14-2016), JMEngineer (06-28-2016), Mauro_Penguin (06-17-2016), Mazdazilla6 (06-26-2016), Nliiitend1 (06-15-2016), RalliartRsX (07-06-2016), WetzMS3 (06-15-2016) |
06-14-2016, 06:35 PM | #4 |
| Not Ranked : 0 score What word do you prefer? We prefer compression. |
06-14-2016, 08:18 PM | #5 |
Rep Power: 0 Thanks: 789
__________________ 2009 MS3 GT - JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs - CP-e S2 RMM - KW V2 - SPC RUCAs | |
The Following 6 Users Say Thank You to jtday For This Useful Post: | KiwiFlavor (06-15-2016), Mazdazilla6 (06-26-2016), Neverlift (06-15-2016), Nliiitend1 (06-15-2016), Thor Hammer (06-30-2016), Voltwings (06-15-2016) |
06-15-2016, 10:39 AM | #6 |
Groans: 1,143
But yes, the word is damping. Compression only refers to one action the damper is handling.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp | |
The Following 3 Users Say Thank You to Neverlift For This Useful Post: |
06-15-2016, 02:33 PM | #7 |
| Not Ranked : 0 score Here's a little teaser.... |
The Following 5 Users Say Thank You to JBR For This Useful Post: | Finchee (06-15-2016), KiwiFlavor (06-16-2016), Liquidsilver (06-15-2016), thems3driver (06-16-2016), [R]usty (06-15-2016) |
06-15-2016, 02:48 PM | #8 |
(Thread Starter) | Not Ranked : 0 score @JBR; Nice! Would those camber plates fit other coilovers and be sold separately? Also, any plans on rear end links?
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
06-15-2016, 06:27 PM | #9 |
Rep Power: 4020 Thanks: 10,876
| Not Ranked : 0 score Hopefully that's not an actual picture of the MS3 camber plate... I'm thinking that one is for 2014+ Mazda 3/6/CX-5 maybe?
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post: | KiwiFlavor (06-16-2016), macdiesel (06-18-2016) |
06-15-2016, 07:05 PM | #10 |
| Not Ranked : 0 score Good eye. |
The Following 2 Users Say Thank You to JBR For This Useful Post: | macdiesel (06-18-2016), Nliiitend1 (06-16-2016) |
06-16-2016, 05:31 AM | #11 |
Rep Power: 0 Thanks: 48
| Not Ranked : 0 score interested how much longer? i am in need new stuff before end of july..
__________________ [SIGPIC][/SIGPIC]corksport catback, Cpe catted Downpipe, versa tuning custom tune, jbr rear swaybar, jbr 3 inch intake, corksport internals jbr suspension, awr front endlinks Last edited by subydoored; 06-16-2016 at 05:31 AM. Reason: MSF Database - Automerged Doublepost |
06-16-2016, 06:34 AM | #12 |
Rep Power: 878 Thanks: 5,570
| Not Ranked : 0 score Will these be re-buildable? Any options for re-valving?
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
06-16-2016, 10:43 AM | #13 |
Rep Power: 1125 Thanks: 4,645
Groans: 143
| Not Ranked : 0 score This. Also will we be able to order custom spring rates?
__________________ 2007 Mazdaspeed3 GT |
06-16-2016, 11:03 AM | #14 |
| Not Ranked : 0 score They are fully re-buildable. There will be no options at this time for re-valving or custom spring rates. Maybe in the future though. |
06-16-2016, 11:28 AM | #15 |
Rep Power: 0 Thanks: 12
| Not Ranked : 0 score @JBR; What about 2 options? Street and for another option something more track aggressive? Sounds like a best of both worlds. Custom valving might be too much right off the start trying to bring a new producte to market for you guys. But having a Street/ Light Track options would be great possibly for more sales And less pressure for custom stuff? |
06-16-2016, 11:46 AM | #16 |
Rep Power: 0 Thanks: 253
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score Dammit and I just installed swift springs...can only hope the camber plates don't require cutting out the strut tower opening. Me no likey to cut the car. Btw it's looking good.
__________________ Current Installed: Autotech Internals | Cobb AP v3 | JBR SSB | JBR RMM 80A Duro | Pioneer HU - Alpine speakers - Alpine sub (cause fuck BOSE) | Goodyear F1 Asymmetric | CS Intake + TiP | Forge BPV v2.0 | Swift Springs Spec R | Redline MTL 80 Future Installs: CS Race Pipe | CP-E TMIC | WMI Rice Maker Mods (not power mods): Daily Driven, Mazdaspeed Decals, Cobb x2, JBR Decal, Stratified Tuned Decal, RVinyl yellow fog overlays, Plastidip rear valance, G2 caliper pnt, 35W Kensun slim HID, CS LEDs Fogs | Footwell blue LEDs | Dual ported box | Foglight Covers dipped | Red Vinyl Wrapped Tail Lights |
06-16-2016, 11:47 AM | #17 |
We've incorporated a very wide range of compression, rebound and height adjustment in to these making them perfect for both the street and the track. | |
06-16-2016, 06:06 PM | #18 |
Rep Power: 0 Thanks: 1,568
| Not Ranked : 0 score Will the camber plates be available separately?
__________________ Scott Mazda Dragon Camp - Event Coordinator // PTE 5858 // FREEKbuilt & tuned \\ M-1 Meth\\ www.TorqueSteerStickers.com |
06-17-2016, 12:42 PM | #19 |
| Not Ranked : 0 score So when will these be up for sale?
__________________ [SIGPIC][/SIGPIC]corksport catback, Cpe catted Downpipe, versa tuning custom tune, jbr rear swaybar, jbr 3 inch intake, corksport internals jbr suspension, awr front endlinks |
06-17-2016, 12:50 PM | #20 |
| Not Ranked : 0 score Yes in the near future. in about 45 seconds..... Last edited by JBR; 06-17-2016 at 12:50 PM. Reason: MSF Database - Automerged Doublepost |
The Following 5 Users Say Thank You to JBR For This Useful Post: | BigBoostMS3 (06-20-2016), Code Monkey (06-17-2016), Hush (06-17-2016), mxlplx71 (06-17-2016), [R]usty (06-17-2016) |
06-17-2016, 12:56 PM | #21 |
| Not Ranked : 0 score oh can i bee first to buy
06-17-2016, 01:00 PM | #22 |
| Not Ranked : 0 score |
06-17-2016, 01:04 PM | #23 |
| Not Ranked : 0 score ordered special prize for being the first?
__________________ [SIGPIC][/SIGPIC]corksport catback, Cpe catted Downpipe, versa tuning custom tune, jbr rear swaybar, jbr 3 inch intake, corksport internals jbr suspension, awr front endlinks Last edited by subydoored; 06-17-2016 at 01:04 PM. Reason: MSF Database - Automerged Doublepost |
The Following User Says Thank You to subydoored For This Useful Post: | JBR (06-17-2016) |
06-17-2016, 01:13 PM | #24 |
Groans: 1,143
Interested to see how aggressive the rebound is.
06-17-2016, 01:19 PM | #25 |
Groans: 143
| Not Ranked : 0 score Yeah I was going to ask the same thing. There's a lot of crappy dampers out there where the knob doesn't really have a linear relationship with the force. Sent from my A0001 using tapatalkreplace
06-17-2016, 01:36 PM | #26 |
| Not Ranked : 0 score There is a shot of the shock dyno on our Facebook page from several weeks ago. I will post it here later this afternoon. |
The Following User Says Thank You to JBR For This Useful Post: | Neverlift (06-17-2016) |
06-17-2016, 02:21 PM | #27 |
(Thread Starter) | Not Ranked : 0 score Damn Jamie nice work! If I didn't already have KW V3 I would be all over these. That price is damn good considering they're both compression and rebound adjustable.
06-17-2016, 02:32 PM | #28 |
Your V3s are considerably more fine-tunable.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
06-17-2016, 02:41 PM | #29 |
(Thread Starter) | Not Ranked : 0 score Didn't realize that thanks for clarifying.
06-17-2016, 03:38 PM | #30 |
We chose to go with a single adjustment for both to keep the price point where we felt it needed to be. | |
The Following 2 Users Say Thank You to JBR For This Useful Post: | Neverlift (06-18-2016), Nliiitend1 (06-18-2016) |
06-18-2016, 10:08 AM | #31 |
Groans: 1,143
It sounds like you have identified a supplier with the means to offer a double adjustable should the market call for a track specific damper, but targeted a much larger market to get your feet in the water. I look forward to seeing the feedback once these reach the hands of MSF members.
The Following User Says Thank You to Neverlift For This Useful Post: | JBR (06-21-2016) |
06-21-2016, 12:02 PM | #32 |
Shock Dyno's are now on our website. | |
The Following User Says Thank You to JBR For This Useful Post: | [R]usty (06-21-2016) |
06-26-2016, 02:08 PM | #33 |
| Not Ranked : 0 score Anyone have these installed yet and Reviews on them? |
06-27-2016, 03:55 PM | #34 |
(Thread Starter) | Not Ranked : 0 score Bump what he said ^
06-27-2016, 06:19 PM | #35 |
Rep Power: 0 Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Wish you had a 12k+ rear spring rate option, my BC's had same 8k and 5k and the rear would sag slightly on each powershift which I dislike a ton on FWD. I'd be interested if you offered custom rates in the future. GLWS James
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
06-28-2016, 06:07 PM | #36 |
| Not Ranked : 0 score alright i got mine installed.. only problem i ran into on install was the rear shock bushings. the didnt fit i had to grind off about 1 mm on each 1 to get them to go in. as for ride quality is slightly stiffer than stock. i did drive all threw boston the worst roads on the planet while ubering in my ms3 and got 5* rating for the night so the backseat riders didnt notice a change. i would like to say i forgot to buy adjustable front end link so no fsb atm.
06-28-2016, 06:11 PM | #37 |
Groans: 30
| Not Ranked : 0 score Take pics of the bushings you had to hack up so JBR can fix it and other people won't have to modify a $1200 product
The Following User Says Thank You to impossible For This Useful Post: | KiwiFlavor (06-28-2016) |
06-28-2016, 06:17 PM | #38 |
| Not Ranked : 0 score they are metal bushing and cant do this anytime soon. it could be just my car.
06-28-2016, 08:13 PM | #39 |
| Not Ranked : 0 score A 12k rear spring rate would be ridiculous. The ride would be unbearable. |
06-28-2016, 08:14 PM | #40 |
Groans: 30
| Not Ranked : 0 score Suggesting for the drag race guys who don't wanna run cheap ass bags in the rear springs to keep ass sag down.
The Following User Says Thank You to impossible For This Useful Post: | Mmmspeed (07-11-2016) |
KW vs AMR Coilovers | kuraijay | 2010 MS3 - Suspension & Brakes | 22 | 12-30-2015 05:52 PM |
BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers | Doberman | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 07-28-2012 08:35 AM |
Anyone on BC coilovers? | bbjoy | MazdaSpeed 3/6 - Suspension & Brakes | 15 | 12-18-2010 12:44 AM |
