JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
Search Forum |
04-09-2014, 07:21 AM | #1 |
Rep Power: 0 Thanks: 6
(Thread Starter) | Not Ranked : 0 score JBR Stage 2 Rubbing After installing the the stage 2, I realized the TBolt clamps are rubbing against the ECU Wire cover and the battery box with the Tbolts in the position shown on the instructions. Did anyone else have this problem and just change the orientation of the clamps. Mine are positioned just as the picture shows. I'll post up how its rubbing in a few minutes as well. Anybody have the same issue? |
04-09-2014, 07:25 AM | #2 |
6 mods and some Kool-Aid Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28977 Thanks: 20,271
| Not Ranked : 0 score There is a bracket that goes under one of the clamps on the right, bolts to where stock TIP used to be, and that holds it far from the ECU. I do not see it used in this pic. |
The Following 2 Users Say Thank You to Raider For This Useful Post: | King Scumbag (04-09-2014), trancehead (04-09-2014) |
04-09-2014, 07:32 AM | #3 |
(Thread Starter) | Not Ranked : 0 score Really? I don't know where said bracket is. Bracket comes with intake or is already on car? ImageUploadedBytapatalkreplace1397050306.812313.jpg I attached the picture of where it's rubbing. Sent from my iPhone using tapatalkreplace |
04-09-2014, 07:33 AM | #4 |
(Thread Starter) | Not Ranked : 0 score O nvm. I know what you're talking about. The one that you slip under the clamp? Sent from my iPhone using tapatalkreplace |
The Following User Says Thank You to scapone4 For This Useful Post: | Raider (04-09-2014) |
04-09-2014, 07:42 AM | #5 |
| Not Ranked : 0 score |
04-09-2014, 09:55 AM | #6 |
Rep Power: 1402 Thanks: 1,475
| Not Ranked : 0 score @Raider; he definately has that bracket there if you look closely. I am trying to remember if I had the same problem. I may have just rotated the clamps down a little bit. ninja edit. that is not your pic in the OP! Ninja on Ninja edit: Yes check for the clamp @Raider; desribed. Slides under the clamp on the front of the TIP and bolts to the nippl/bolt used for the stock turbo inlet mounting bracket
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG |
The Following User Says Thank You to King Scumbag For This Useful Post: | Raider (04-09-2014) |
04-09-2014, 01:22 PM | #7 |
(Thread Starter) | Not Ranked : 0 score JBR Stage 2 Rubbing Yea that's not my pic in the OP. Second one is. I was just using that showing how I oriented my clamps. I'll just reorient the clamps should be fine. Thanks guys Sent from my iPhone using tapatalkreplace |
04-09-2014, 01:24 PM | #8 |
| Not Ranked : 0 score So, did you use the clip thing already, or no? |
04-09-2014, 02:14 PM | #9 |
(Thread Starter) | Not Ranked : 0 score Yea thats on. |
04-09-2014, 02:19 PM | #10 |
Rep Power: 0 Thanks: 1,205
| Not Ranked : 0 score Rotate the clamps, no biggie. Mine is close but not touching.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
04-13-2014, 10:49 AM | #11 |
(Thread Starter) | Not Ranked : 0 score Simple fix. Thanks guys |
Need help with rubbing | jjfam1 | MazdaSpeed 3/6 - Wheels & Tires | 14 | 02-09-2012 11:02 AM |
tire rubbing | maddocx240 | Mazdaspeed3/6 General Discussion | 21 | 12-06-2011 11:48 AM |
Why am I rubbing? | Smily27 | 2010 MS3 - Wheels & Tires | 17 | 07-13-2011 04:18 PM |
Stock and Rubbing (Help Plz) | KayWhy | MazdaSpeed 3/6 - Wheels & Tires | 7 | 08-30-2009 06:44 AM |
225-45-18s, who else is rubbing? | 4thStroke | MazdaSpeed 3/6 - Wheels & Tires | 14 | 07-07-2008 11:39 PM |
