JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
Search Forum |
07-25-2013, 06:19 PM | #1 |
Banned Join Date: Apr 2013 Location: Birmingham, Alabama
Rep Power: 0 Thanks: 277
(Thread Starter) | Not Ranked : 0 score question about v1 3.5 I picked up what a member said was a 3.5 all aluminum w/ black wrinkle finish intake. I am having some issues with fitment and my ets tmic w/ cobb xle bpv. It appears the path the intake wants to take puts the filter right at the bpv leaving no room for it to go on. IS this something that was typical with this intake? Need advice please. |
07-25-2013, 07:01 PM | #2 |
Rep Power: 0 Thanks: 287
| Not Ranked : 0 score Have you tried putting on the stocker to see if it fits? If so, use it while you figure out what boost tube will work. I had to trim my corksport one when I went Fmic, sometimes you can twist the inlet pipe for clearance
__________________ Cobb AP (Stratified Tuned) Corksport Stage 2 intake+recirc tube Streetunit testpipe Autotech internals NGK LTR7Ix-11 Corksport RMM RX-8s--235/40/18 Bridgestone Potenza RE-760 Stoptech brake kit+Motul RBF600 Whiteline RSB+endlinks Dominant Engineering camber arms JBR stage 2 OCC+ EGR delete+intake manifold gasket HKS turbo timer Prosport boost gauge+ventpod Awaiting H&R springs/Koni yelows/ground control bumpstops |
The Following User Says Thank You to jdm_mica For This Useful Post: | gigliotti175 (07-25-2013) |
07-26-2013, 06:17 AM | #3 |
Approved MSF Vendor Join Date: Sep 2009
Rep Power: 7118 Thanks: 7,203
| Not Ranked : 0 score It's a tight fit with the xle. You'll need to shim it out, see the install instructions in the support section of our website. That's one reason we went to all silicone. |
The Following User Says Thank You to JBR For This Useful Post: | Rokusek (07-26-2013) |
07-26-2013, 08:19 AM | #4 |
@jbarone I am curious. I purchased an original 3.5 wp from a member here. Did you guys offer this intake in a black wrinkle finish? I haven't seen any pictures of one but just curious. Last edited by bhamitgeek; 07-26-2013 at 08:23 AM. Reason: MSF Database - Automerged Doublepost | |
07-26-2013, 08:41 AM | #5 |
On the surface it may appear to be better to buy aluminum but, it's not and here's why.... The new 3.5" silicone intakes are a 3.5" ID unlike any aluminum intake with a 3.5" OD. Our intakes move a larger volume of air. Look at how restrictive the design of the aluminum intakes with the MAF screen air straighteners are. The bead roll in the tubing and the bead of sealant used to hold it is narrows down the ID so much you're wasting your money on them. Ours has no reduction in ID from the air straightener. Our silicone intakes do a far superior job at insulating the intake air as compared to aluminum. They do not scratch and stay looking new forever. They fit 10x better and have much smoother radius's then any mandrel bent tube does. These are just a few reasons why they maintain a very high resale value as well. So, if you buy one for stock turbo now, then sell it to buy one for a bigger turbo down the road, the performance is way worth the 20-30 you may loose on selling the first one. This was never any kind of sham to get you guys to buy more intakes from us. We are and always have been performance oriented not $$$ oriented. All the aluminum intakes we make came with black wrinkle powder coat accept a couple. -J | |
07-26-2013, 08:46 AM | #6 |
(Thread Starter) | Not Ranked : 0 score Thank you for the info. |
Nub question | MattJ | Wheels & Tires - WHITE | 1 | 01-15-2012 02:56 PM |
question. | zoomzoom | Mazdaspeed3/6 General Discussion | 4 | 05-03-2011 02:57 PM |
question | zoomzoom | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 01-19-2011 04:44 PM |
CEL question | Speed13 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 12-17-2010 11:58 PM |
