Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
Search Forum |
09-02-2012, 03:32 PM | #1 |
Rep Power: 5431 Thanks: 2,552
(Thread Starter) | Not Ranked : 0 score Has anyone written tool to diff compare 2 map files in AP? Is there a tool that basically lists the diff (differences) between two map (.ptm) files? It is a little time consuming in ATR to go line for line and table by table to compare maps. It would be an awesome tool if some program read in 2 map files and spit out the differences on a per table basis. Does such a thing exist? |
09-02-2012, 03:36 PM | #2 |
Engineered Tuning Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 12034 Thanks: 6,485
| Not Ranked : 0 score You'd have to decode the .ptm file. I think COBB is not going to be pleased with something like this.
__________________ We Engineer, and that's better than just tuning! www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
09-02-2012, 03:43 PM | #3 |
Rep Power: 5063 Thanks: 11,719
| Not Ranked : 0 score Would be a nice feature, but at the moment you would have to decrypt and/or decompress the map files.
09-02-2012, 03:55 PM | #4 |
Rep Power: 5715 Thanks: 19,677
Groans: 90
| Not Ranked : 0 score Would def be an awesome tool, but like ^ they said, not really doable by someone besides Cobb... I'll post it on the Cobb forum to see what they think though! Sent from my iPhone using lame ass tapatalkreplace
__________________ [SIGPIC][/SIGPIC] |
09-02-2012, 03:59 PM | #5 |
Eatin' Your Tuna Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 Thanks: 1,602
| Actually, there is a tool... its just depends on your aptitude level of actually being able to read code: Beyond Compare - The file compare, folder compare and remote directory compare utility from Scooter Software Ive been using it for years
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite | |
09-02-2012, 04:04 PM | #6 |
Groans: 90
| Not Ranked : 0 score Done! https://forums.cobbtuning.com/forums...282#post667282 Sent from my iPhone using lame ass tapatalkreplace
The Following User Says Thank You to hnda etr For This Useful Post: | dale_gribble (09-02-2012) |
09-02-2012, 04:08 PM | #7 |
| Not Ranked : 0 score ^^ That will not work, try opening up a map, change just one value, save under a different name, the two files are completely different now when you do a hex dump.
09-02-2012, 04:28 PM | #8 |
(Thread Starter) | Not Ranked : 0 score I concur. I would only expect maybe a checksum and maybe a few bytes to change by changing 1 value. I diff'd two files the same way and the dump is completely different. |
09-02-2012, 04:23 PM | #9 |
(Thread Starter) | Not Ranked : 0 score If Cobb provides the diff functionality as a high level feature in ATR then they don't have to worry about someone pursuing the solution deep into their map files. For as long as the AP has been out in the tuner market and among a bunch of techies I am actually pretty shocked that this hasn't been done yet.
Last edited by dale_gribble; 09-02-2012 at 04:23 PM. Reason: MSF Database - Automerged Doublepost | |
10-17-2012, 09:58 PM | #10 |
Rep Power: 0 Thanks: 124
| Not Ranked : 0 score So let say you add a TIP and switch maps to accommodate the pipe. You have to go to each table and change them all again? There is no easy way to save the changes you've already made on a new map without changing what's important?
__________________ 07 MS6 Sport............. JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals * |
10-17-2012, 10:18 PM | #11 |
| Not Ranked : 0 score No, the encoding/encrypting of a map changes every time you tweak the littlest thing. This has nothing to do with how you see a map when you open it in the AccessTuner software.
The Following User Says Thank You to Code Monkey For This Useful Post: | weakdog85 (10-18-2012) |
Rear diff locks while turning after SURE diff mount and brace install | wettoast | MazdaSpeed 6 - Engine, Transmission & Driveline | 47 | 11-04-2018 04:50 PM |
rear diff "stiff diff" brace vs. rear diff front mount | giordanos4 | MazdaSpeed 6 - Engine, Transmission & Driveline | 18 | 03-03-2011 08:38 AM |
