Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
Search Forum |
03-22-2013, 02:04 PM | #1 |
rabble rabble Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 Thanks: 9,400
Groans: 221
(Thread Starter) | Not Ranked : 0 score Possible to order just the RSB brackets/bushings? One of my brackets snapped, any chance I can just buy a new pair with some new bushings? or anyone else have a recommended set that I can buy? Searching "brackets" returned nothing.
04-21-2013, 06:52 PM | #2 |
Rep Power: 0 Thanks: 31,116
Groans: 549
| Not Ranked : 0 score Not sure if they're the same size or not, hit hotchkis has some seriously beefy brackets and you can buy then separately.
__________________ it's fun to do bad things |
04-21-2013, 07:46 PM | #3 |
Groans: 221
Cobb wanted $25 for EACH bracket.
__________________ '08 CWP MS3 w/ T3 3071r | |
The Following User Says Thank You to 802MS3 For This Useful Post: | ABolewski (04-28-2013) |
04-21-2013, 07:50 PM | #4 |
Must Have Teh 10's! Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10778 Thanks: 6,334
| Not Ranked : 0 score warranty?
04-24-2013, 04:07 PM | #5 |
Rep Power: 0 Thanks: 9
| Not Ranked : 0 score I don't know if it's true, but I heard the Cobbs were just rebranded Hotchkis bars. I had the first version of Hotchkis bars and brackets that came out, and a bracket broke. Got some new brackets in, and they're made of a different metal I think, and a different design. Noticably tougher, they must of known about the issue. I had to contact sales directly and they weren't exactly cheap but it is what it is. |
GI: Corksport Shifter Linkage Bushings (Not Base Bushings) >>> | Alpha | Mazdaspeed3/6 General Discussion | 134 | 03-09-2013 08:17 PM |
intercooler mounting brackets? | ms3driver213 | 2010 MS3 - Turbo Induction | 32 | 05-18-2012 10:02 AM |
GI: Corksport Shifter Linkage Bushings (Not Base Bushings) >>> | Alpha | CorkSport | 0 | 01-19-2012 11:33 AM |
TMIC all three brackets broke off | evo2ms3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 02-08-2010 09:11 AM |
