Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
Search Forum |
12-13-2011, 08:47 PM | #1 |
Rep Power: 0 Thanks: 4,297
Groans: 91
(Thread Starter) | Not Ranked : 0 score why do i always lean out in the 55xx rpm range till redline. hey all i have 0 problems with boost, my afr are spot on till like 52-5500 rpm then they star leaning. like if i request 11.8 it goes to like 12.1 which i know some say is safe but i dont like it. i think i am just gonna copy my wgdc to a ots map and redo maf cal? ideas, thanks
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
12-13-2011, 08:50 PM | #2 |
Bob Ross Fanclub Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 Thanks: 4,534
| Not Ranked : 0 score howbout a log? FP?
__________________ |
12-13-2011, 08:57 PM | #3 |
Rep Power: 0 Thanks: 566
| Not Ranked : 0 score take a wot log, take your actual afr and dived that by your target afr. then multiply that times the areas in your maf cal which are going lean, for example, say at 5800 rpm your at 12.1 and targetting 11.8. 12.1/11.8 = 1.025 say you're at 280 g/s, for that part of your maf cal just multiply by 1.025, same goes for rich say 11.4 actual, 11.8 targetted, 11.6/11.8 = .996
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
The Following User Says Thank You to speedms6 For This Useful Post: | skeeter149 (12-13-2011) |
12-13-2011, 09:14 PM | #4 |
Groans: 91
(Thread Starter) | Not Ranked : 0 score sorry log in a sec let me find one... oke log 1.05 is ots afr so we all know they should be in the 10's. and datalog 2 is requesting 11.8. thanks.
12-14-2011, 06:41 AM | #5 |
| Not Ranked : 0 score Update your AP. Your datalog rate is still the old slow one. FP looks ok. Your AFR looks to be between 11.9 and 12.2 across the rev range not just past 5.5K rpm. Overall looks ok to me. If you want to richen up the mixture I would just do it via requested AFR.
The Following User Says Thank You to Tomas For This Useful Post: | skeeter149 (12-14-2011) |
12-20-2011, 03:19 PM | #6 |
Groans: 91
(Thread Starter) | Not Ranked : 0 score ok so i am requesting afr of 11.4 and seeing 11.8-11.9. iswhere else can i change afr besides the o/l c/l transitions in case i missed something?
12-20-2011, 04:31 PM | #7 |
Rep Power: 0 Thanks: 52,496
| Not Ranked : 0 score When in open loop, you want to adjust your af ratio by maf volts, and make sure the issue happens consistently @ the same maf voltage. Take your exhaust reading, divide it by commanded wot afr's to get the multiplier for the maf voltage you are correcting. E.g., you mentioned you wanted to correct 12.2 exhaust readings from 11.8 commanded. 12.2 / 11.8 = 1.03 = multiplier to apply to the maf voltages that you want to correct. I always remember it this way: E/D = erectile disfunction = exhaust / dic(k)tated = correction factor. Sorry, but I bet you remember it now too. LOL |
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: | ArcticSpeed3 (12-20-2011), atvfreek (12-20-2011), Easter Bunny (12-21-2011), skeeter149 (12-20-2011) |
12-20-2011, 04:46 PM | #8 |
Groans: 91
(Thread Starter) | Not Ranked : 0 score thanks fink heres a short log from yesterday, sorry i didnt go higher in rpm. but i was just wondering if you could walk me through the adjustment per the log. i am requesting 11.4 afr at the 1.25 load and 2500 rpm as per abilors guide through the range. edit: ap is updated. also i did just move the coolant lines off my cold pipe so i dont know if the heat affects it but thats why my bats were so high. ok fink lemme pull about 3 more so i can see if it is consistent and try and get a lower rpm as well. then can i email you and see if we come up with the same thing to change?
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" Last edited by skeeter149; 12-20-2011 at 04:59 PM. |
The Following User Says Thank You to skeeter149 For This Useful Post: | rfinkle2 (12-20-2011) |
12-20-2011, 04:56 PM | #9 |
Does your closed loop max load D table reflect the 1.25 load value that you want to target 11.4 afr's with? I see what you mean as far as leaning out some. I'm sure we can get it worked out... just need more info. Last edited by rfinkle2; 12-20-2011 at 05:21 PM. | |
12-20-2011, 05:04 PM | #10 |
Groans: 91
(Thread Starter) | Not Ranked : 0 score 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 1.10 1.10 1.10 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 those are my max load d tables. there from the new ots map. is that a issue? and i had .16 but changed my maf cal. let me go back to the other cause this change did me no good and the other is only 5 different at top. this one maxes at 383 that one is 388 for example and i think i did always see .16 in ol. lemme check my first log with the other maf cal. yep datalog 2 in post 4 has the .16. i think i need to just throw down a new maf cal for safety sake or can the current be saved?
12-20-2011, 05:24 PM | #11 |
Your closed loop max load tables show that you want to enter open loop fueling @ 1, whereas your fueling maps (judging from posts above) are set up for a transition of 1.25. Here is an example of how you might want your fueling tables to look if you are telling the ecu, "my max load I want you to stay in closed loop is up to 1.25". (note targeting 12.0 here, but you get the point) | |
The Following User Says Thank You to rfinkle2 For This Useful Post: | skeeter149 (12-20-2011) |
12-20-2011, 06:21 PM | #12 |
Groans: 91
(Thread Starter) | Not Ranked : 0 score ok fixed my max d table anything else i need to do?
12-21-2011, 06:39 AM | #13 |
| Not Ranked : 0 score Based on the strange ltft reading @ wot, and the leaning out issue, I would start with a fresh maf cal. starting from an ots maf curve. I.e. - no need to start entirely over, but you may want to copy and paste the ots maf curve into your map, drive for about 50 miles or so and give the maf cal another shot. |
The Following User Says Thank You to rfinkle2 For This Useful Post: | skeeter149 (12-21-2011) |
12-21-2011, 12:54 PM | #14 |
Groans: 91
(Thread Starter) | Not Ranked : 0 score sounds like a plan finkle. i will do that this week and then try and throw down a sick woorking maf cal lol finkle is it cool if i have you kinda go over the maf cal i throw down so i can make sure its right. like send you the logs and get your advice before i make the changes? its gonna take me a minute to do the 50 miles but i think i can do it tomorrow.
12-21-2011, 01:08 PM | #15 |
pm' ing you now. | |
How much time from startup till blue temp light turns off? | G26 | Gen2 MS3 General Discussion | 37 | 07-13-2012 07:44 PM |
Wilbur Ross's IAC to delay IPO till early 2012, sources say | Haltech | Automotive News | 0 | 09-09-2011 10:00 PM |
Ford: Monthly sales pace won't return to 13M rate till late summer | Haltech | Automotive News | 0 | 06-29-2011 10:00 PM |
Dealers got lean; many plan to stay lean | Haltech | Automotive News | 0 | 05-30-2010 10:10 PM |
At his store, shop till you (gasp!) drop | Haltech | Automotive News | 0 | 05-17-2010 03:00 PM |
