Search Forum |
12-10-2016, 11:03 PM | #1 |
Rep Power: 0 Thanks: 67
(Thread Starter) | Not Ranked : 0 score DD Simple Build Posted around this time last year with suspected ringland failure:Cracked rings? Ended up being a blown turbo, but not too long after I pulled plugs to change them and noticed oil. Long story short after chasing my tail, cracked rings. Building the engine, and figured I'd post in the case that someone has similar parts and was curious how it ends up. List isn’t exhaustive, might forget stuff, but will be adding pictures. Everything is already on the car, except for the engine section. Bolt On’s: Are the basic kind… • Ultimate Racing Catback • Ultimate Racing Test Pipe • JBR Trilogy mount (88d) • JBR 3.5” intake • ETS TMIC • Autotech Fuel Internals • Forge BPV V1 • Dual Damond OCC Suspension: More basics.. • Bilstein b8 • HR Springs • JBR front/rear sway bars • Moog front/rear endlinks • JBR rear camber arms Exterior • Wrapped Satin Black Turbo: • Stock k04 Engine: New stuff.. • Wiseco Forged Piston Set 88mm • Manley H Beam • Oem Head studs • ARP Main Studs • New timing components • Southbend Stage 3 Endurance clutch • ITV22’s • Damond PCV Plate Tune: • Was Freektune - Will continue to be
__________________ __________________ '12 Mazdaspeed 3 - AP V3 /Freektuned/ Autotechs / JBR SRI + TIP/ ETS TMIC / Forge VI BPV / Dual Damond OCC/ Ultimate Racing Test Pipe / Ultimate Racing Catback/ JBR 88RMM / JBR 80TMM / JBR Boost Tubes /JBR Rear Sway Bar/ NGK 1 Step Colder/ Corksport Pads/ TWS Nurburgring 18x8.5 et 45// |
12-11-2016, 06:15 PM | #2 |
Rep Power: 0 Thanks: 37
| Not Ranked : 0 score You should add some Meth to that list so you can push it a little and take advantage of the new rods and pistons :-)
__________________ Max Bolted and Built Stock K04 |
12-11-2016, 07:14 PM | #3 |
(Thread Starter) | Not Ranked : 0 score You think even on the little k04? I'm running about 4 gallons of e85 as of current. Budget after the machining and stuff stopped be from going BT, so little k04 it is for now.
12-12-2016, 06:00 PM | #4 |
| Not Ranked : 0 score I'm still on the little K04. I went from 4.5 gallons of E per tank to 2 gallons of Meth per tank, same or more KR resistance. I also spray the equivalent of a D10, pure Meth. I've modified just about everything I can think of, and push my rods and pistons to the edge. Right now I get 30 psi til 4500 rpm or so, more torque than I can use in the first 3 gears at least, .... I think it's probably more fun than a BT, definitely faster as a DD
12-12-2016, 08:10 PM | #5 |
__________________ __________________ '12 Mazdaspeed 3 - AP V3 /Freektuned/ Autotechs / JBR SRI + TIP/ ETS TMIC / Forge VI BPV / Dual Damond OCC/ Ultimate Racing Test Pipe / Ultimate Racing Catback/ JBR 88RMM / JBR 80TMM / JBR Boost Tubes /JBR Rear Sway Bar/ NGK 1 Step Colder/ Corksport Pads/ TWS Nurburgring 18x8.5 et 45// | |
12-13-2016, 04:30 PM | #6 |
| Not Ranked : 0 score Not sure what you mean by stock short block, I've replaced the pistons and rods (Manley and Wiseco). Vdyno says I'm somewhere a little north of 450 ft-lbs and almost 350 hp. I've load tuned 1st, 2nd and 3rd to try and reduce uncontrollable wheel spin and now 4th will spin unless I have good traction surface. I've been forged for about 20K miles Like I said, lots of fun
12-13-2016, 07:30 PM | #7 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score Nice build. Looking forward to pics... and maybe a video when it's all done? |
Simple 07 TR MS3 | themandillon | Members Rides Gallery | 16 | 02-03-2013 11:02 PM |
simple e85 ? | mczimer | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 05-08-2012 07:46 AM |
Simple AFR question. | DarkPasseng3r | 2010 MS3 - Fuel, Nitrous & Water Injection | 4 | 04-12-2012 06:51 PM |
Simple Build Big Power? | seanmiller09 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 26 | 07-22-2010 01:33 AM |
some simple Q's...maybe | teders | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 11-16-2009 07:41 AM |
