Search Forum |
11-08-2019, 01:26 PM | #1 |
Rep Power: 0 Thanks: 5
(Thread Starter) | Not Ranked : 0 score Any opinions on this noise? I'm fully mounted by corksport and I definitely hear the gears spinning at idle, when the clutch is engaged. When I disengage it, the noise goes away. I've read that's normal for fully mounted cars. However, this may or may not be linked. When I shut the car down, there's a noise that follows the same pattern. Thusly, I always disengage the clutch before turning the key off. Otherwise, you'll hear this sound. https://youtu.be/V5kkInCvA6c Sent from my Pixel 3 using tapatalkreplace
__________________ '13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats. |
11-08-2019, 01:48 PM | #2 |
Rep Power: 0 Thanks: 139
| Not Ranked : 0 score I always depress the clutch pedal as well when I shut my car off because it sounds like a bag of smashed assholes if I don't. Yours sounds a bit different than mine but I've never tried held my ear up to the engine bay when shutting my car off. I'm always inside the car. My car also makes the funny noise when it's in neutral idling. Everything I've read says these noises are normal on these cars.
__________________ 2012 Speed3 - Velocity Red Mica Current Mods JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob |
The Following User Says Thank You to ABOSWORTH For This Useful Post: | Sonofnothing (11-08-2019) |
Throttle noise/ engine noise | under28world | 2010 MS3 - Engine, Transmission & Driveline | 9 | 05-04-2015 06:25 PM |
bearing noise vs wheel noise? | drag0nfire | Mazdaspeed3/6 General Discussion | 14 | 06-20-2012 07:32 PM |
Need opinions on engine noise | soaringeagle129 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 31 | 10-27-2011 03:47 AM |
Lotus and Harman partner on noise-cancelling, noise-creating tech | Haltech | Automotive News | 0 | 04-16-2009 05:00 PM |
Need opinions on my AFR.... | ONLYA6 | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 10-29-2008 08:23 AM |
