Search Forum |
12-16-2015, 09:31 AM | #1 |
Rep Power: 0 Thanks: 45
(Thread Starter) | Not Ranked : 0 score valve cleaning So lately I've been reading about cleaning the valves, and how a little sea foam or similar product (run through the gas tank) won't work. My question is, will something similar to the BG intake system cleaner work, since it's not being run through the normal intake path, you hook it up to a vacuum line leading into the intake and of sorts let the engine idle and suck it in. would this type of cleaning system work on these cars, or is the only way to do the ground walnut shells method? thanks, Ross |
12-16-2015, 09:38 AM | #2 |
Rep Power: 0 Thanks: 593
| Not Ranked : 0 score This has been discussed many many times, but bottom line, walnut blasting is the only way to get it cleaned properly. |
The Following 8 Users Say Thank You to Mattyhawk1 For This Useful Post: | cyclist20 (12-16-2015), kritz (12-17-2015), MD1032 (12-17-2015), Me2speed3 (12-16-2015), mxlplx71 (12-16-2015), robbspeed (12-16-2015), speedfreak44 (12-16-2015), WAMBUSHHHH! (12-16-2015) |
12-16-2015, 09:39 AM | #3 |
(Thread Starter) | Not Ranked : 0 score tried looking but got nowhere with the search box. didn't mean to bring up a dead subject. sorry |
12-16-2015, 09:42 AM | #4 |
Tachyonic Moderator Join Date: Nov 2013 Location: San Antonio, TX
Rep Power: 1969 Thanks: 5,076
| You can use my custom search in my SIG, since then search here is broken. sent from my Nexus 6P
The Following 8 Users Say Thank You to MS3Shadow For This Useful Post: | btstarcher (12-25-2015), cyclist20 (12-16-2015), MD1032 (12-17-2015), Me2speed3 (12-16-2015), prosper0 (12-27-2015), roguemazda (12-16-2015), texasboy21 (12-22-2015), WAMBUSHHHH! (12-16-2015) |
12-16-2015, 09:56 AM | #5 |
Rep Power: 0 Thanks: 1,356
Groans: 50
| Not Ranked : 0 score Walnut works best but you can also use denatured alcohol and a series of pics and brushes. This is per Cobbs instructions.
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. |
12-16-2015, 10:57 AM | #6 |
Rep Power: 0 Thanks: 1,449
| Not Ranked : 0 score either way, bring lube because valve cleaning is such a pain in the ass and the lube will help ease you into it.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
The Following 3 Users Say Thank You to WAMBUSHHHH! For This Useful Post: |
12-16-2015, 02:17 PM | #7 |
Rep Power: 1703 Thanks: 2,468
| Not Ranked : 0 score Aerosol B12...spray...soak..suck out with shop vac....blast with walnut media...suck out with shop vac. Repeat until clean.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned |
12-16-2015, 03:11 PM | #8 |
Rep Power: 0 Thanks: 83
Groaned at 7 Times in 2 Posts
| Not Ranked : 0 score You'll understand why a traditional intake/valve cleaning solution won't do anything once you see the carbon build up for yourself. The shit's rock hard, caked on. Even after soaking in B12 I still needed to blast multiple rounds of walnut shells to get the suckers clean. Mine were at about 69k in the picture. |
12-16-2015, 03:26 PM | #9 |
(Thread Starter) | Not Ranked : 0 score Damn, going to need a ms person nearby with a helpful set of eyes to guide me through this. Not something I'm comfortable trying alone for the first time... This isn't LSD... |
12-16-2015, 04:43 PM | #10 |
Rep Power: 0 Thanks: 462
| Not Ranked : 0 score I used brake cleaner and pick tools. Took a while and yes the shit is like old gum stuck under the desk at school...always got me frustrated when I just wanted a little piece of cum and couldn't get it off...errr I mean gum
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
The Following User Says Thank You to speedfreak44 For This Useful Post: | robbspeed (12-16-2015) |
12-16-2015, 05:10 PM | #11 |
Rep Power: 0 Thanks: 139
| Not Ranked : 0 score I've got to get around to this myself. I've got like 53K on my car now. I don't even want to know what those fuckers look like. Here is the thread you want to read. HOW TO: Clean your valves - easy & cheap
__________________ 2012 Speed3 - Velocity Red Mica Current Mods JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob |
The Following User Says Thank You to ABOSWORTH For This Useful Post: | WAMBUSHHHH! (12-17-2015) |
12-17-2015, 05:37 PM | #12 |
(Thread Starter) | Not Ranked : 0 score @abosworth, thats the one i read, even though his steps are detailed. Still not sure this is something i want to try without an experienced set of eyes watching me. |
12-17-2015, 05:41 PM | #13 |
| Not Ranked : 0 score Oh okay. Sorry about that, then. I hear ya man. I'm sort of hesitant to blast walnuts into my engine as well. Lol
12-17-2015, 06:03 PM | #14 |
Rep Power: 0 Thanks: 812
It worked alright until he decided to be funny and turned the compressor to 140psi, in which B12 shot straight through the towels and up into my eye.
__________________ 2013 Liquid Silver Metallic MS3 GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks TunedbyNishan | |
The Following 2 Users Say Thank You to mize13 For This Useful Post: | 865ms3 (12-17-2015), WAMBUSHHHH! (12-17-2015) |
12-17-2015, 06:07 PM | #15 |
I got trolled one time....yea it's all out...spray the media. There is still splatter of b12 gunk all over a wall in @BigBoostMS3; s old garage with the outline of my body.
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned | |
12-17-2015, 06:15 PM | #16 |
Rep Power: 1125 Thanks: 4,645
Groans: 143
| Not Ranked : 0 score That actually doesn't look too bad to me for 69k. Has anyone ever tried using a sonicator probe in combination with B12? Seems to me like that would work really well. We use sonicators at work to dissolve shit all the time, although I realize that's not something anyone would commonly own at home.
__________________ 2007 Mazdaspeed3 GT |
12-17-2015, 06:26 PM | #17 |
Rep Power: 213 Thanks: 143
| Not Ranked : 0 score Maybe I inhaled too much of its fumes, but I swear the best thing that has worked for me so far (along w/ blasting) was that Zoom Zoom cleaner that is supposedly now discontinued (part #0000-77-A86 ). The only problem is it is pricey compared to denatured alcohol. @theurgy; mentioned in a thread a couple of years ago that he would experiment to see which was more effective -- denatured alcohol, B-12 Chemtool or Zoom Zoom Cleaner -- but I'm not sure if you reported his results.
__________________ 2007 MS3 GT Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks 2006 MS6 GT (ZZB Rebirth) Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts 1990 Miata I like it raw |
12-17-2015, 07:53 PM | #18 |
Rep Power: 0 Thanks: 848
| Not Ranked : 0 score @sporkbomb; The Texans had a valve cleaning party a while back and experimented with the various cleaning options: http://www.mazdaspeedforum.org/forum/foru...ml#post2839402 Admittedly, their results differed from my own (they weren't impressed with the Zoom Zoom cleaner). For me, the only cleaner that seemed to make an obvious impact was the Zoom Zoom cleaner. It softened the carbon into a gummy mess that could be scraped away. I didn't see any results whatsoever from Seafoam or brake cleaner. The second time I cleaned my valves I used nothing but walnut media and that made short work of the process. Word of warning: wear a respirator. Even though I did my lungs weren't happy with me afterwards... |
The Following 3 Users Say Thank You to frothy For This Useful Post: |
12-18-2015, 04:55 PM | #19 |
Rep Power: 0 Thanks: 2
| Not Ranked : 0 score Im at 56K mikes and will do a valve cleaning soon and I'm going with the pure walnut blasting method. Its still not clear to me about rotating the crank or whatever. Do you have to take the front pass. wheel off? What do you turn to rotate the crank? What tool do you use for that? You have to make sure the valve is completely closed before cleaning, but how do you tell if it's closed all the way? If you're going pure walnut, why the need for a respirator? |
12-18-2015, 06:52 PM | #20 |
As far as getting a set of valves to close to clean them, we just just left the car in gear and pushed.
12-19-2015, 03:51 AM | #21 |
| Not Ranked : 0 score @attomica; Yes, remove the front passenger wheel to gain access to the crankshaft bolt. Have the car in neutral and with a ratchet and 21mm socket rotate the crankshaft clockwise until it turns over (you'll be fighting less resistance if you remove the serpentine belt). Two sets of valves should be sealed enough to work on at a time. It should be pretty obvious which ones they are. If you need to, have someone spin the crank by hand while you observe the valves to familiarize yourself with what's going on. The walnut media will get pulverized into fine particles/dust that will hang in the air. You don't want to inhale that crap. EDIT: If you're using the Harbor Freight media blaster, I highly recommend disassembling it and going over it before use. I found that mine kept jamming at times and would blow nothing but air. I had to remove the hopper and drill out some excess plastic from the feed hole. I also found it necessary to drill out the "feed regulator" (shown below) as there were large metal burrs inhibiting the flow. You don't have to remove the "feed regulator" from the gun. Remove the hopper and look into the gun while the regulator is in the "Open" position. It will be apparent if there's excess material clogging things up. Last edited by frothy; 12-19-2015 at 05:41 AM. |
The Following 5 Users Say Thank You to frothy For This Useful Post: | bennyzoom (12-23-2015), Mauro_Penguin (12-19-2015), MD1032 (12-19-2015), mxlplx71 (12-24-2015), tec_41 (12-21-2015) |
12-19-2015, 12:47 PM | #22 |
Rep Power: 0 Thanks: 1,005
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. | |
12-19-2015, 01:25 PM | #23 |
(Thread Starter) | Not Ranked : 0 score If any of the richmond, va people want to get together and do this again... Hit me up, love working on my own cars, just not sure I'm up for tackling this one alone! |
12-23-2015, 01:16 PM | #24 |
| Not Ranked : 0 score | |
The Following User Says Thank You to attomica For This Useful Post: | frothy (12-23-2015) |
12-24-2015, 09:11 PM | #25 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score At how many miles i should expect a power loss from carbon build up and need cleaning? |
12-24-2015, 09:21 PM | #26 |
Rep Power: 0 Thanks: 4,201
Groans: 128
| Not Ranked : 0 score mine were gunked up at 42k
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
12-24-2015, 09:32 PM | #27 |
(Thread Starter) | Not Ranked : 0 score Would gummed up valves potentially give you a p0300? Sent from my LGLS990 using tapatalkreplace |
12-24-2015, 09:36 PM | #28 |
Groans: 128
| Not Ranked : 0 score usually thats from plugs or injector seals
12-24-2015, 11:13 PM | #29 |
Rep Power: 0 Thanks: 1,505
| Not Ranked : 0 score kI'm still a Chemtool B-12 and shotgun bore brush advocate. Works great. I use clean gasoline to verify that the valves are closed before starting. Then soak and scrub. Also use gasoline to flush and suction it out. Change engine oil when done.
12-25-2015, 05:09 AM | #30 |
(Thread Starter) | Not Ranked : 0 score Thanks @mxlplx7, i figured with CoP a real misfire should know exactly what cylinder was missing and a random mis had to be caused by something else. Sent from my LGLS990 using tapatalkreplace |
12-25-2015, 05:12 AM | #31 |
Groans: 143
I have 74k on mine. Never cleaned them. Only noticeable symptom is my idle is quite rough. I'm gonna wait until my beaner blows up my injector seals and then do everything at once. Sent from my A0001 using tapatalkreplace
__________________ 2007 Mazdaspeed3 GT | |
Intake Valve Cleaning using valve overlap and DI injection window shift | Vansquish | MazdaSpeed 3/6 - ECU Computer Tuning | 33 | 05-06-2014 07:00 PM |
valve cleaning soon, what else should i do | dan7225 | Mazdaspeed3/6 General Discussion | 25 | 07-31-2012 04:42 PM |
Valve Cleaning | beachshoer | Gen2 MS3 General Discussion | 16 | 07-08-2012 07:43 PM |
