VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
Search Forum |
03-01-2016, 06:00 PM | #1 |
Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 Thanks: 3,349
| Not Ranked : 0 score Got it downloaded. This stuff looks awesome! Definitely going to jump ship when it comes time to put my car back on the road. @Steve@VersaTune; I'm looking at the demo log. The fueling says Equivalence Ratio but the unit is Lambda? Is it actually showing fuel in equivalence ratio or is it showing in lambda?
03-03-2016, 08:01 PM | #2 |
Approved MSF Vendor Join Date: Nov 2011
Rep Power: 778 Thanks: 0
ER can be represented as phi or lambda. Mazda uses lambda. phi: >1 = rich, <1 = lean ie. fuel-air ratio lambda: >1 = lean, <1 = rich ie. air-fuel ratio Stoich AFR for gasoline is ~ 14.7. Stoich ER (phi or lambda) for any fuel is 1.00000 | |
The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Mazdazilla6 (03-03-2016) |
03-03-2016, 08:14 PM | #3 |
| Not Ranked : 0 score Ahh, okay. I'm just used to different terminology. I was taught lambda = lambda and ER = 1/lambda. Good to know, thanks!
Demo Software | NCspecV81 | VersaTune | 10 | 03-09-2016 10:16 AM |
Versatuner GB | aviator79 | CX-7 > General Lounge + New Member Welcome | 5 | 03-12-2013 01:10 PM |
EdgeAutosport.com Demo Car | JP@edgeautosport.com | EdgeAutosport.com | 44 | 04-30-2012 12:40 PM |
