Search Forum |
02-20-2013, 05:50 PM | #1 |
Must Have Teh 10's! Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10778 Thanks: 6,334
(Thread Starter) | Not Ranked : 0 score Attention Sonic Tuning Customers!!! So as a growing business we are only as good as our customer base and how people view us. Our number one priority is to the customer and anyone that has ever ordered something from us will tell you they had a great shopping experience. If you also shared this same great experience we would appreciate it if you could write us a small review on Google using the link below so we can show the public who we truly are. We sincerely appreciate all the business you have given us and we will continue to bring only the best products to the Mazda aftermarket!!! - Your Sonic Tuning Team https://plus.google.com/107888982478...gl=US&hl=en-US
The Following 6 Users Say Thank You to superskaterxes For This Useful Post: | breakfstincluded (02-22-2013), Downmented (02-21-2013), Grumpyjap (02-21-2013), Monotonous ONE (02-22-2013), PapaSmurf (02-21-2013), RichieRichness (02-21-2013) |
02-21-2013, 07:00 AM | #2 |
Rep Power: 3780 Thanks: 8,647
Groans: 493
| Not Ranked : 0 score SONIC TUNING IS WINNING
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
02-21-2013, 07:12 AM | #3 |
Rep Power: 0 Thanks: 324
| Not Ranked : 0 score Subbed for will do-ness Sent from my Galaxy Nexus using tapatalkreplace 2
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers | Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
02-21-2013, 07:26 AM | #4 |
Rep Power: 2267 Thanks: 1,484
| Not Ranked : 0 score Review left. Go Sonic Tuning!
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ |
The Following User Says Thank You to Grumpyjap For This Useful Post: | superskaterxes (02-21-2013) |
02-21-2013, 07:41 AM | #5 |
Rep Power: 2313 Thanks: 4,791
Groans: 35
| Not Ranked : 0 score Review sent
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
The Following User Says Thank You to RichieRichness For This Useful Post: | superskaterxes (02-21-2013) |
02-22-2013, 07:36 AM | #6 |
Tripple OG Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 Thanks: 14,643
Groans: 113
| Not Ranked : 0 score done |
02-22-2013, 07:40 AM | #7 |
Rep Power: 0 Thanks: 6,451
| Not Ranked : 0 score I have the HID fog ballast, but when one started flickering out for some unknown reason they were quick to reply to my issue with possibilities, including sending a replacement. I'll leave a review (: Now to find out where that ground is that might be causing my issue...
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
The Following User Says Thank You to breakfstincluded For This Useful Post: | superskaterxes (02-22-2013) |
02-22-2013, 07:50 AM | #8 |
Rep Power: 0 Thanks: 2,434
| Not Ranked : 0 score I have yet to recive the anal beads and lube I ordered.... I no haz google+ on gov comp...ill give a review latter.
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
02-22-2013, 07:55 AM | #9 |
Rep Power: 0 Thanks: 6,842
Groans: 819
| Not Ranked : 0 score Never ordered anything But I'd still suck your cock
02-22-2013, 01:05 PM | #10 |
Rep Power: 0 Thanks: 3,219
Groans: 116
| Not Ranked : 0 score never ordered anything, but i did win a set of HIDs at EECNM. put those in and they work great. simple install. i'll be sure to leave a review.
__________________ 2010 Liquid Silver w/ Tech Package 270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm) Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2 |
The Following User Says Thank You to Onelovesoccer For This Useful Post: | superskaterxes (02-22-2013) |
02-26-2013, 05:52 PM | #11 |
| Not Ranked : 0 score donezo!
03-24-2013, 09:03 PM | #12 |
Approved MSF Vendor Join Date: Jun 2012
Rep Power: 178 Thanks: 128
| Not Ranked : 0 score Thanks everyone for the support!!!
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels |
The Following 2 Users Say Thank You to sonic tuning For This Useful Post: | Downmented (03-25-2013), Onelovesoccer (03-25-2013) |
04-05-2013, 01:17 PM | #13 |
Rep Power: 0 Thanks: 3,717
Groaned at 50 Times in 17 Posts
| Not Ranked : 0 score Done.
__________________ 2012 LSM MS3 Some mods, No list, too much "zapos". |
GB: Sonic Tuning Coilovers!!! | sonic tuning | Sonic Tuning | 142 | 03-03-2014 03:55 AM |
Sonic Tuning Coilovers | superskaterxes | MazdaSpeed 3/6 - Suspension & Brakes | 181 | 07-17-2012 06:08 AM |
New Sonic Tuning ST8s... | NinjaT1985 | 2010 MS3 - Wheels & Tires | 19 | 01-08-2012 10:22 AM |
Attention: Future ISG-S3 Customers | MS3_Noob | Mazdaspeed3/6 General Discussion | 1 | 02-27-2009 01:43 AM |
