Search Forum |
02-05-2013, 02:01 PM | #1 |
Approved MSF Vendor Join Date: Jun 2012
Rep Power: 178 Thanks: 128
(Thread Starter) | Not Ranked : 0 score GB V2: Sonic Tuning Coilovers!!! Thats right folks. We did so well in the first GB we are going to do it all again!!! This time we are going to skip the minimum requirement and just offer you guys the same great prices right from the beginning!!!! Features: • Full length adjustment system on lower mount • Separate ride hight and pre-load adjustments • 6061 T6 Aluminum alloy construction: lower mount, top mount, spring seat and locks • 12 level adjustable damper - adjustable dampers allow fine-tuning of the suspension stiffness to best suit the driving condition. • SCM440 hardened piston rod: special high strength grade material with extra hardening process effectively improves the chances again deformation, fracture and leakage. • Special formulated oil - stable and durable high quality oil seal can minimize any suspension failures or oil leaking to increase durability. • Inner polished seamless steel tube - quality high strength tubes ensure the strength of the struts (cylinders). The micro finished inner surface ensures a precise and smooth action, which can reduce the chances of fluid leakage and prolongs struts endurance. • Mono tube design ensures quick response and comfort. suspension fluid is separated from high-pressure gas in order to reduce damper failure. • Advanced formulated rubber parts: effectively increase the endurance and help eliminate abnormal noises. • Forged aluminum alloy top mount: increases the strength and effectively reduces the weight to provide sensitive driving feedback. • Sae9254 spring: high strength material formed spring effectively minimizes deformation. MS3 spring rates are 7k/5k MS6 spring rates are 12k/5k S1 Version: No adjustable top hats S3 Version: Camber adjustable top hats (MS3 only) and pillow ball mount. MS6 Kit: MS3 Gen1 Kit: MS3 Gen2 Kit: Here are some review threads from the BMW forums on our coilovers for that platform. You will see that even the pickiest of car enthusiasts have great things to say about the quality of the coilover itself and the adjustability it provides. Sonic Tuning S1 Coilovers (Impressions) - BMW 3-Series (E90 E92) Forum - E90Post.com Sonic Tuning Coilovers installed - BMW 3-Series (E90 E92) Forum - E90Post.com Sonic Tuning Coilover Review - BMW 3-Series (E90 E92) Forum - E90Post.com There are a few members so far who has been impressed with these and have only good things to say!!! GB Details: This GB starts today and will run for 45 days or until we run out!!! CURRENT INVENTORY AS OF March,24th 2013 We will start pre-ordering process in April for the Third Group Buy. MS6: S3 | Sold Out | Next Shipment May Gen1 MS3: S3 | Sold Out | Next Shipment May Gen2 MS3: S1 | Sold Out | Next Shipment May Gen2 MS3: S3 | Sold Out | Next Shipment May GB pricing will be as follows: $999 for the S3 Sets sold so far: 1. MS3 Gen1 | S3 2. MS3 Gen1 | S3 3. MS6 | S3 4. MS3 Gen1 | S3 5. MS6 | S3 6. MS3 Gen1 | S3 7. MS3 Gen1 | S3 8. MS3 Gen2 | S3 7. MS3 Gen1 | S3 8. MS3 Gen1 | S3 9. MS3 Gen2 | S3 10. MS6 | S3 11. MS3 Gen1 | S3 12. MS6 | S3 13. MS6 | S3 14. MS3 Gen2 | S3 15. MS3 Gen2 | S3 16. MS3 Gen2 | S3 17. MS3 Gen2 | S1 To order these just give us a call 240.766.8388 or you can email us at sales@sonictuning.com All coilover includes 1 year warranty against wear/tear (ie if you blow a shock) and a LIFETIME warranty against manufacturing defects (such as a broken coil, snapped bolt/bracket, ect). We pride ourselves on customer service and always making sure the customer stays happy no matter what. A quick Google search will show you just how happy ANY customer has been while doing business with us. We will do everything in our power to make sure your purchase goes as smoothly as possible. To order a set you can send us a PM or give us a call directly and we will be happy to help you. Here's just a small review from a few MSF members who have already purchased them: My Sonic Tuning S3 Coilover experiance....
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels Last edited by sonic tuning; 03-24-2013 at 08:57 PM. | |||||
The Following 9 Users Say Thank You to sonic tuning For This Useful Post: | amggilly305 (02-07-2013), CWP_MS3 (02-05-2013), h.h.sk1nny (02-07-2013), Jh8909 (02-05-2013), miamispeed3 (03-03-2013), Onelovesoccer (04-06-2013), PapaSmurf (02-08-2013), smillers (02-07-2013), Toymachinespeed (02-06-2013) |
02-05-2013, 02:09 PM | #2 |
Rep Power: 2506 Thanks: 2,527
| Not Ranked : 0 score Big fan of anything with your name on it. Good luck.
__________________ Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
The Following User Says Thank You to Domino81 For This Useful Post: | superskaterxes (02-05-2013) |
02-05-2013, 02:29 PM | #3 |
Rep Power: 0 Thanks: 29,434
Groans: 40
| Not Ranked : 0 score So you're saying I have 45 days to save a G...I can do that!!!
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
The Following User Says Thank You to tbot For This Useful Post: | superskaterxes (02-05-2013) |
02-05-2013, 02:52 PM | #4 |
Rep Power: 0 Thanks: 917
| Not Ranked : 0 score Possibly sign me up, if the coil overs I'm looking for sell, then I'll pick these up. Sent using my EVO LTE on tappy
__________________ [SIGPIC][/SIGPIC] 2008.5 CWP Speed3 GT - SOLD / 1991 Ford Mustang LX 5.0 SSP 331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes |
The Following User Says Thank You to MS3MYK For This Useful Post: | superskaterxes (02-05-2013) |
02-05-2013, 05:30 PM | #5 |
Must Have Teh 10's! Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10778 Thanks: 6,334
| Not Ranked : 0 score picts added!!!!!!! im going to detail some of the picts tomorrow with the extra features that Sonic Tuning brings to the table that really separates them from your average coilover.
The Following User Says Thank You to superskaterxes For This Useful Post: | rfinkle2 (02-05-2013) |
02-05-2013, 05:33 PM | #6 |
Rep Power: 0 Thanks: 52,496
| Not Ranked : 0 score Can the height of the rear of these be adjusted without removing the spring from the perch? |
02-05-2013, 05:38 PM | #7 |
| Not Ranked : 0 score yes but we dont recommend that. its so easy to just remove the one bolt from the LCA and drop the spring to ensure that both sides are identical.
The Following User Says Thank You to superskaterxes For This Useful Post: | rfinkle2 (02-09-2013) |
02-05-2013, 05:41 PM | #8 |
Do you have to use a hole saw to cut bits in the engine bay? i.e. for the camber adjustability on the s3? | |
02-05-2013, 05:55 PM | #9 |
Before: During: After: BOOM!
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
The Following 6 Users Say Thank You to superskaterxes For This Useful Post: | amggilly305 (02-07-2013), Boost_creep (02-12-2013), breakfasteatre (02-05-2013), Dmurray06 (02-05-2013), rfinkle2 (02-05-2013), Wings_Fan_1986 (02-13-2013) |
02-05-2013, 10:50 PM | #10 |
Groans: 40
| Not Ranked : 0 score GB V2: Sonic Tuning Coilovers!!! Just realized I have a strut tower brace...I think these will work with that...have to double check...if not looks like I'll be selling that then haha.
02-06-2013, 05:39 AM | #11 |
i also have a STB on my 6 and they fit just fine.
02-06-2013, 07:38 PM | #12 |
Rep Power: 0 Thanks: 612
Groaned at 25 Times in 10 Posts
| Not Ranked : 0 score i didnt know this kit came with end links. The ones in the pic are for the front?
__________________ If your not first your last. 03 Speed Protege.. SOLD 10 Speed3 BT and getting my DRANK on!!! |
02-06-2013, 07:55 PM | #13 |
| Not Ranked : 0 score yes but only for the 3's not the 6
The Following User Says Thank You to superskaterxes For This Useful Post: | sonic tuning (02-07-2013) |
02-06-2013, 08:45 PM | #14 |
Rep Power: 0 Thanks: 324
| Not Ranked : 0 score I wasn't really planning on ordering coils but these are very appealing. I wasn't thinking I wanted anything adjustable but by the time I pay for bilsteins Cobb springs and some moog end links I'm well over a grand. Any downsides to these? I doubt I'll lower the car more than 1.2 inches. It will probably stay that way too. Sent from my Galaxy Nexus using tapatalkreplace 2
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers | Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
The Following 2 Users Say Thank You to thatsmrgimp2u For This Useful Post: | NOreasonY (03-04-2013), superskaterxes (02-07-2013) |
02-06-2013, 09:11 PM | #15 |
| Not Ranked : 0 score I can't find anything wrong with them. Nothing but good reviews. Not worrying about bump stops and strut mounts... This is so much easier and i can get them from one order. I'll be sending payment very early March for gen 1 s3's. I'm very new with suspension setups. Is it hard to dial in an even drop with these? How exactly is the rear dampening adjusted? Sent from my Galaxy Nexus using tapatalkreplace 2
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers | Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ Last edited by thatsmrgimp2u; 02-06-2013 at 10:30 PM. |
The Following User Says Thank You to thatsmrgimp2u For This Useful Post: | sonic tuning (02-07-2013) |
02-06-2013, 10:30 PM | #16 |
Rep Power: 0 Thanks: 1,042
| Not Ranked : 0 score PM'ed!!!! The wife just gave me her credit card!!!! Guess that is what happens when you make them a baby
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME |
The Following 6 Users Say Thank You to h.h.sk1nny For This Useful Post: | amggilly305 (02-07-2013), Boosted Beluga (02-11-2013), Jh8909 (02-07-2013), sonic tuning (02-07-2013), superskaterxes (02-07-2013), xI Leveler Ix (03-27-2013) |
02-07-2013, 08:21 AM | #17 |
the rear dampening adjustment is on the shock itself. you should be able to reach up into the fender well to adjust it.
The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | sonic tuning (02-07-2013), thatsmrgimp2u (02-07-2013) |
02-07-2013, 09:16 AM | #18 |
Rep Power: 0 Thanks: 24
| Not Ranked : 0 score Thanks Anthony for the quick customer service. I ordered my set yesterday. |
The Following 2 Users Say Thank You to Fast_Dude For This Useful Post: | sonic tuning (02-07-2013), superskaterxes (02-07-2013) |
02-07-2013, 10:36 AM | #19 |
Both of your set is going out today!
__________________ Sonic Tuning 18938 Bonanza Way Gaithersburg, MD 20879 Proudly Serving the NATOR DC Community! www.sonictuning.com We are an authorized COBB Dealer and carry HUNDREDS of other brands for your MAZDASPEED We also make our own Coilovers for the MS3/6 along with HID kits and Wheels | ||
02-07-2013, 10:53 AM | #20 |
Rep Power: 0 Thanks: 49
| Not Ranked : 0 score How much lower would a Gen 2 be with this set of coilovers at maximum height? Thanks. |
02-07-2013, 11:11 AM | #21 |
| Not Ranked : 0 score |
The Following 2 Users Say Thank You to Fast_Dude For This Useful Post: | h.h.sk1nny (02-07-2013), superskaterxes (02-07-2013) |
02-07-2013, 11:19 AM | #22 |
Rep Power: 0 Thanks: 1,777
Groans: 47
Groaned at 21 Times in 9 Posts
| Not Ranked : 0 score Subbed for interest after getting raped by valentine's day next week
__________________ 2010 Black Mica Mazdaspeed3 MODS in chronological order of installtion AEM CAI, JBR SSP Stage 2, JBR Heavy Shift Knob, JBR 80 Duro Billet Rear Motor Mount, CP-E NVISCID Turbo Inlet Pipe. & COBB AP Debating on Rear Sway Bars, Springs, or internals next... |
The Following User Says Thank You to WAHBAM For This Useful Post: | superskaterxes (02-07-2013) |
02-07-2013, 06:39 PM | #23 |
Rep Power: 0 Thanks: 603
| Not Ranked : 0 score I wish I had more money!!!!!! I need to save up!!!!!
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP RPM: Sport Springs, Shark Fin, LED side markers CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount |
02-07-2013, 07:40 PM | #24 |
Rep Power: 0 Thanks: 305
| Not Ranked : 0 score I thought you brought over more than 5 sets for the ms6. I may need to shift around some funds to get these before they sell out for 6 months again. I really want BT and built engine though, decisions...
__________________ 2006 Black Mica MS6 - Sold 10/15 |
The Following User Says Thank You to shadesofgray19 For This Useful Post: | superskaterxes (02-07-2013) |
02-07-2013, 08:05 PM | #25 |
Rep Power: 0 Thanks: 233
| Not Ranked : 0 score My knowledge of coilovers is non-existent. Please forgive is these questions are stupid as a result. 1. What kind of drop if any are we looking at in the MS6 on the highest setting? 2. I am not too concerned about install difficulty but I see some posts about drilling the strut tower and would like to not have to hack things up. 3. I understand the height adjustments can be made relatively easily after taking off the wheels. How easy is it to adjust the dampening settings in; front and back? 4. In the case of a blown shock after the warranty period what is the avenue or option to get these rebuilt as they are clearly a very limited production item? Thanks
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
The Following User Says Thank You to Karmat For This Useful Post: | rfinkle2 (02-09-2013) |
02-07-2013, 08:06 PM | #26 |
| Not Ranked : 0 score correct, we bought 6 sets =D
The Following User Says Thank You to superskaterxes For This Useful Post: | shadesofgray19 (02-07-2013) |
02-07-2013, 08:07 PM | #27 |
rabble rabble Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 Thanks: 9,400
Groans: 221
| Not Ranked : 0 score fauk. I was all ready to drop the money on corksport coilovers and now this. those things look sexy.
The Following User Says Thank You to 802MS3 For This Useful Post: | superskaterxes (02-07-2013) |
02-07-2013, 10:57 PM | #28 |
Rep Power: 0 Thanks: 1,074
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score omg they so pretty brah! somebody convince me to buy these! got the chesse just gunshy about which suspension setup to get
__________________ 2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's to be installed : 3 Port EBCS HTP 3" intake/ MAF/ TIH Autotech internals Corksport Pmm Test pipe SBC Rear Camber Arms |
02-08-2013, 05:59 AM | #29 |
dont forget these come with a LIFETIME warranty on non-wear items and a 1 year warranty on everything else. When i used to have BC coils, it took me 4 months to get a replacement shock (2 of those months was spent just trying to get in contact with them because they never answer the phone or return any emails). Sonic Tuning has a 2-3 week turn around time on warranty replacement parts which you wont find anywhere else. these also come with adjustable endlinks!!!!!
02-08-2013, 06:33 AM | #30 |
Rep Power: 0 Thanks: 6,375
| Not Ranked : 0 score waiting on my bonus to hit my bank account and then ill be contacting you guys for a set. Cant beat the price.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
The Following 2 Users Say Thank You to PapaSmurf For This Useful Post: | mghtymouse380 (02-09-2013), superskaterxes (02-08-2013) |
02-08-2013, 08:18 AM | #31 |
Rep Power: 0 Thanks: 34,434
| Not Ranked : 0 score What's the height range for the Gen 1? How close to stock height can they get/what's the min drop? Taxes will be back soon, and a set of S3s is pretty tempting. Sent from my DROID RAZR using Forum Runner
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial |
02-08-2013, 08:31 AM | #32 |
Rep Power: 0 Thanks: 2,491
Groans: 405
Groaned at 19 Times in 16 Posts
| Not Ranked : 0 score If I can recover from my clutch install, I definitely want a set of these as I want to start AutoX this spring/summer. |
The Following User Says Thank You to cbspd3flip For This Useful Post: | superskaterxes (02-08-2013) |
02-08-2013, 08:47 AM | #33 |
| Not Ranked : 0 score let me get back to you on the height thing. AFAIK they can be raised back to stock height but let me verify that for sure.
The Following User Says Thank You to superskaterxes For This Useful Post: | magicka (02-08-2013) |
02-08-2013, 11:37 AM | #34 |
Rep Power: 4020 Thanks: 10,876
I realize you're selling a product here, but I don't think you're looking to mislead anyone.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
The Following User Says Thank You to Nliiitend1 For This Useful Post: | rfinkle2 (02-09-2013) |
02-08-2013, 12:02 PM | #35 |
but KW is an american company so i would hope they could respond that fast. Sonic tuning does not stock any replacement parts here in the USA and all of the engineering (yes i said engineering because actual engineers with tons of time attack experience designed these rather then copying some china made shit) is done in japan. So for a company like sonic tuning to commit to getting you a replacement part this quickly from overseas within this kind of time frame should speak wonders about their customer service. It typically takes 6 weeks by boat to get things shipped here from japan so all of your warranty items are sent via express mail on a plane to make sure they get here in plenty of time so the customer doesent have to wait.
02-08-2013, 12:20 PM | #36 |
Rep Power: 1135 Thanks: 977
| Not Ranked : 0 score Does the rear spring adjustment sleeve go on the top of the bottom of the spring on the MS3?
__________________ Fueled by the haters. |
02-08-2013, 12:24 PM | #37 |
| Not Ranked : 0 score it goes on the top. you actually unbolt the rear subframe bolt and then put the bolt THROUGH the perch and then bolt the whole assembly back up. This way it holds that mofo in there nice and tight!
The Following User Says Thank You to superskaterxes For This Useful Post: | Celestspeed3 (02-08-2013) |
02-08-2013, 12:42 PM | #38 |
| Not Ranked : 0 score Is the diameter of the perch 2.5"? Does anyone have any photos of them installed on the car? Reason being I want to install a set of universal race springs on the car. I have the bottom sorted out I just need the top.
02-08-2013, 01:13 PM | #39 |
heres the best pict i have of the rears
02-08-2013, 01:16 PM | #40 |
| Not Ranked : 0 score Thanks very much.
The Following User Says Thank You to Celestspeed3 For This Useful Post: | 002hex (04-24-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f596/gb-v2-sonic-tuning-coilovers-137331/ | ||||
Posted By | For | Type | Date | |
GB V2: Sonic Tuning Coilovers!!! - Mazdaspeed Forums | This thread | Refback | 01-17-2014 10:27 AM | |
If interested. Coil overs GB available at MSF - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-05-2013 08:58 PM |
GB: Sonic Tuning Coilovers!!! | sonic tuning | Sonic Tuning | 142 | 03-03-2014 03:55 AM |
Anyone in Wilmington, DE area with Sonic Tuning Coilovers? | MPSpd3 | MazdaSpeed 3/6 - Suspension & Brakes | 5 | 11-05-2012 06:51 PM |
Sonic Tuning Coilovers | superskaterxes | MazdaSpeed 3/6 - Suspension & Brakes | 181 | 07-17-2012 06:08 AM |
Sonic Tuning ST8s | MS3inDC | Wheels & Tires - BLACK | 7 | 09-07-2011 09:50 AM |
