Oil discussion compilation thread For whatever reason, it is difficult to search our forums for 3 letter words such as oil, and UOA (used oil analysis), so it was asked that someone create a thread compiling decent oil information for our cars. Below is a collection of links found on msf (and now other reputable sites) that are oil related. There is also a link to what is thought as the most informative oil website that I know of, "Bob is the Oil Guy .com". http://www.mazdaspeedforum.org/forum/foru...changes-49112/ dealership oil change discussion http://www.mazdaspeedforum.org/forum/foru...s-using-96579/ oil discussion http://www.mazdaspeedforum.org/forum/foru...nalysis-69009/ oil discussion and uoa results http://www.mazdaspeedforum.org/forum/foru...ern-oil-85945/ oil ingredient / component discussion http://www.mazdaspeedforum.org/forum/foru...u-using-59658/ oil discussion http://www.mazdaspeedforum.org/forum/foru...l-ultra-52301/ oil discussion http://www.mazdaspeedforum.org/forum/foru...ind-oil-54694/ oil discussion http://www.mazdaspeedforum.org/forum/foru...d-3-iyo-18303/ oil discussion Response from Pennzoil on Ultra - Bob Is The Oil Guy - pennzoil's explanation of ultra vs. platinum (Bob is the oil guy link) FerrariChat.com - FAQ: Motor Oil Articles by Dr. Ali E. Haas (AEHaas) - thanks to username nindoja, mathematical oil analysis Motor Oil - All Chapters, Inclusive -Copy and Save This - FerrariChat.com - Dr. Haas's credentials (provided by username mzr165) UOA after e85 use: http://www.mazdaspeedforum.org/forum/foru...tml#post985522 |
Thank fucking fuck Rob! |
I know it's not on MSF, but this link has some really great analysis of motor oil. FerrariChat.com - FAQ: Motor Oil Articles by Dr. Ali E. Haas (AEHaas) The guy has basically tested everything out there, and even uses math to prove his points! *gasp* |
Quote:
I'm adding the link you provided to the OP. Great stuff! |
Quote:
Motor Oil - All Chapters, Inclusive -Copy and Save This - FerrariChat.com |
Quote:
The Dr's credentials definitely add credibility to the thread. |
I plan on switching to this my next oil change. Penn Grade 1 High Performance Oil I'm still debating on 10w-40 or 10w-30. Brad Penn "Green Oil" is supposed to be some of the best stuff around. I'll give a further review vs. Pennzoil Platinum in a separate thread you can link here after the switch. |
Quote:
Check out that Zddp in modern oil thread (started by Lex) above. There is a link to a test of oils performed by Forced Performance (white paper Ziggo reminded me of). |
Quote:
I don't know who is copying who, but Dr. Haas and Bob the Oil Guy have exactly the same write up's about oil! It's all very good information, but someone is guilty of plagiarism. Bob the Oil Guy University Motor Oil 101 - Bob is the Oil Guy Dr. Haas, the PHd Surgeon Motor Oil - All Chapters, Inclusive -Copy and Save This - FerrariChat.com |
Um, read the bob link. "by AE Haas" |
Quote:
Great thread Rob, ton of good info. |
