MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
Search Forum |
12-14-2010, 05:24 PM | #81 |
The Kamikaze King! Join Date: Jun 2008
Rep Power: 1829 Thanks: 6,794
Groans: 754
| Not Ranked : 0 score
My guess is not. Edit>Configure options>Display>Standard units... If you want to see PSI
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
12-14-2010, 05:25 PM | #82 |
Trail of Fail Join Date: Jan 2010 Location: rock city AR
Rep Power: 9906 Thanks: 10,493
| Not Ranked : 0 score not or hes targeting over 100PSI...either or...
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
12-14-2010, 05:33 PM | #83 |
Rep Power: 582 Thanks: 127
Thanks
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah | |
12-17-2010, 10:59 AM | #84 |
Groans: 754
| Not Ranked : 0 score I moved all the off topic steering angle stuff into its own thread: http://www.mazdaspeedforum.org/forum/foru...eed-3-a-67458/
The Following User Says Thank You to FreeFlyFreak For This Useful Post: | djuosnteisn (12-17-2010) |
12-27-2010, 04:26 PM | #85 |
| Not Ranked : 0 score Ok, I am just getting around to actually trying the boost based logic and notice something quite different in the Boost Dynamics table vs the Load Dynamics. LD has way more fine grained resolution than BD tables...what gives? I can adjust load error into the 100ths by 100ths but BD error is in 2PSI increments. how would you ever need 7 to 9PSI of over boost or under boost error control? The reason I ask is because I am trying to fine tune BD table values to match up to my GT28 spool charastics and the res is so low. I must be missing something...plese give me a clue
12-28-2010, 03:25 PM | #86 |
| Not Ranked : 0 score I have been load tuning...well for over a year now and each tune took me...like 20 map revisions to get load/boost dialed in. Switched to boost tuning a day or so ago and by rev 5 I have the tune completed with regard to boost targets. The car isn't as "twitchy" as it was with load tuning and it is actually tamer in the lower gears than with load tuning. Boost comes on much smoother than if you load target. Load targeting is of course more difficult as you need to scale load up to match the spool characteristics of the turbo or occiliation is a bigger issue. Targeting boost is much easier. After I got my WGDC tables re-calibrated, there was no need to even touch the Boost Dynamics tables. I will now move on to the Boost Comp tables to see if I can limit boost per gear. Suffice to say boost tuning is 100x better so far.
The Following 8 Users Say Thank You to Dano For This Useful Post: | acidbbg (01-10-2011), djuosnteisn (12-29-2010), DSIT995 (12-28-2010), FORZDA 1 (12-28-2010), FreeFlyFreak (12-28-2010), manelscout4life (12-28-2010), rfinkle2 (03-19-2011), speed23 (12-28-2010) |
12-28-2010, 03:42 PM | #87 |
Rep Power: 0 Thanks: 1,870
| Not Ranked : 0 score Very nice, did u start with the maps christan posted as a base or did u start from scratch?
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
12-28-2010, 03:46 PM | #88 |
| Not Ranked : 0 score my maps are so far off from any OTS that I felt I should keep them and just throw the boost toggle on. only other modifications I made before I started was to copy/paste Christians WGDC IAT comp table in, set my Boost Targets to a Conservative level 18PSI, and set my WGDC table values to 25 for a start. Then I logged and monitored actual DC and adjusted accordingly...seriousley, 5 map revisions with some of them being boost target increases, and the map is done!
The Following 6 Users Say Thank You to Dano For This Useful Post: | Christian. (12-28-2010), cld12pk2go (12-28-2010), djuosnteisn (12-29-2010), FORZDA 1 (12-28-2010), speed23 (12-28-2010), Speed3eak (12-28-2010) |
12-28-2010, 11:52 PM | #89 |
Rep Power: 0 Thanks: 11
Boost Dynamics Code: 0.09 0.04 0.02 0.01 0.00 0.00 -0.01 -0.10 -0.15 -0.30 -0.70 Boost Dynamics Code: 0.04 0.02 0.01 0.01 0.00 0.00 -0.00 -0.01 -0.02 -0.04 -0.09 WG Duty - IAT Comp. Code: 0.80 0.90 0.96 1.00 1.00 0.98 0.95 0.92 Boost Targets Code: -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 -14.50 0.23 -2.81 -5.85 -8.89 -11.93 -11.76 -11.78 -11.76 -11.77 -11.83 -11.83 -11.94 -12.14 -12.38 -12.72 0.23 -2.17 -4.57 -6.97 -9.36 -9.02 -9.05 -9.02 -9.03 -9.16 -9.15 -9.38 -9.78 -10.25 -10.94 0.23 -1.52 -3.28 -4.82 -6.82 -6.43 -6.28 -6.07 -4.95 -5.06 -5.10 -5.35 -5.75 -6.21 -6.80 0.23 -0.88 -2.00 -2.67 -4.28 -3.85 -3.51 -3.13 -0.86 -0.96 -1.06 -1.33 -1.72 -2.17 -2.66 0.23 -0.24 -0.71 -0.52 -1.75 -1.26 -0.74 -0.18 3.22 3.14 2.99 2.70 2.31 1.87 1.48 0.23 0.40 0.58 1.62 0.79 1.32 2.03 2.77 7.30 7.25 7.03 6.72 6.33 5.92 5.62 0.23 1.05 1.87 3.77 3.33 3.91 4.80 5.71 11.38 11.35 11.08 10.75 10.36 9.96 9.76 0.23 1.69 3.15 5.92 5.87 6.49 7.57 8.66 15.47 15.45 15.12 14.77 14.39 14.00 13.90 0.25 2.34 4.44 8.07 8.40 9.08 10.34 11.60 19.55 19.55 19.17 18.80 18.42 18.04 18.04 0.26 2.99 5.73 10.22 10.94 11.66 13.11 14.55 19.55 19.55 19.17 18.80 18.42 18.04 18.04 0.28 3.65 7.02 10.22 10.94 11.66 13.11 14.55 19.55 19.55 19.17 18.80 18.42 18.04 18.04 0.29 4.08 7.86 10.22 10.94 11.66 13.11 14.55 19.55 19.55 19.17 18.80 18.42 18.04 18.04 0.29 4.50 8.70 10.22 10.94 11.66 13.11 14.55 19.55 19.55 19.17 18.80 18.42 18.04 18.04 1.54 5.43 9.33 10.22 10.94 11.66 13.11 14.55 19.55 19.55 19.17 18.80 18.42 18.04 18.04 WG Duty Cycles Code: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 50.00 50.00 50.00 50.00 4.17 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 50.00 50.00 50.00 50.00 8.33 0.00 0.00 0.00 0.00 0.00 6.86 7.14 7.57 7.71 5.57 50.00 50.00 50.00 50.00 12.50 0.00 0.00 0.00 0.00 0.00 13.71 14.29 15.14 15.43 11.14 50.00 50.00 50.00 50.00 16.67 0.00 0.00 0.00 0.00 0.00 20.57 21.43 22.71 23.14 16.71 50.00 50.00 50.00 50.00 20.83 0.00 0.00 0.00 0.00 0.00 27.43 28.57 30.29 30.86 22.29 50.00 50.00 50.00 50.00 25.00 0.00 0.00 1.25 4.75 6.50 34.29 35.71 37.86 38.57 27.86 50.00 50.00 50.00 50.00 29.17 0.00 0.00 2.50 9.50 13.00 41.14 42.86 45.43 46.29 33.43 50.00 50.00 50.00 50.00 33.33 0.00 0.00 3.75 14.25 19.50 48.00 50.00 53.00 54.00 39.00 50.00 50.00 50.00 50.00 37.50 0.00 0.00 5.00 19.00 26.00 48.00 50.00 53.00 54.00 39.00 50.00 50.00 50.00 50.00 41.67 0.00 0.00 5.00 19.00 26.00 48.00 50.00 53.00 54.00 39.00 50.00 50.00 50.00 50.00 45.83 0.00 0.00 5.00 19.00 26.00 48.00 50.00 53.00 54.00 39.00 50.00 50.00 50.00 50.00 50.00 0.00 0.00 5.00 19.00 26.00 48.00 50.00 53.00 54.00 39.00 50.00 50.00 50.00 50.00 50.00 0.00 0.00 5.00 19.00 26.00 48.00 50.00 53.00 54.00 39.00 My laptop is currently down...once I am back online, I will start helping out. Christian. Last edited by Christian.; 12-30-2010 at 06:04 PM. | |
The Following 7 Users Say Thank You to Christian. For This Useful Post: | AJ713 (12-31-2010), Dano (12-29-2010), djuosnteisn (12-29-2010), DSIT995 (12-29-2010), FORZDA 1 (12-29-2010), manelscout4life (12-29-2010), speed23 (12-29-2010) |
12-29-2010, 07:19 AM | #90 |
| Not Ranked : 0 score Dano, u mind posting up ur map, just wanna take a peek....
12-29-2010, 09:53 AM | #91 |
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 12-29-2010 at 10:34 AM. |
The Following 3 Users Say Thank You to Dano For This Useful Post: |
12-29-2010, 10:43 AM | #92 |
I mean 0 times any number still = 0 so Boost Dynamics can't even add DC in those areas right? Thanks for posting up your suggested table values. I have posted up mine in my thread along with logs. I haven't fine tuned anything yet but for 5 map revisions it is looking good. BTW...I am not sure I'll even need to mess around with Boost Comp tables per gear...I think I might have a better way to limit boost per gear but need to do some testing. GL with the new laptop!
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
The Following User Says Thank You to Dano For This Useful Post: | Speed3eak (12-29-2010) |
12-29-2010, 11:36 AM | #93 |
Christian. | ||
12-29-2010, 11:38 AM | #94 |
Must Have Teh 10's! Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10778 Thanks: 6,334
| Not Ranked : 0 score the best part about spring pressure is that you only need as many map revs as it takes to cal your maf. on straight spring pressure im seeing loads as high as 3.0 when only targeting 2.5ish so im always going to be in the very last row of the table for the entire pull which makes it even easier. i just set choose a spring and, well, thats it haha christian, are you guys working on getting the load axis scaling to work? last i talked to trey he said it was 90% done but he needed to do a fair amount of real world testing because the way he needed to manipulate the ecu to make this work could lead to bricking it alot easier if he diddent test it over and over. it makes it really sucky when your seeing such high loads and you have only 1 line of resolution to try and dial out knock and whatnot.
The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | cld12pk2go (12-30-2010), FreeFlyFreak (12-29-2010) |
12-29-2010, 11:52 AM | #95 |
I would like to see load scaling, but it does not limit anything IMO...you just don't have a lot of resolution from 2.0 load and up. Honestly...how much do people transition load there to a point where they need to modify ignition advance anyway. This is coming, but it is not a show stopper IMO. Christian. | |
The Following 5 Users Say Thank You to Christian. For This Useful Post: | AJ713 (12-31-2010), Dano (12-29-2010), djuosnteisn (01-03-2011), FORZDA 1 (12-29-2010), rfinkle2 (03-28-2011) |
12-29-2010, 12:33 PM | #96 |
The Following User Says Thank You to Jarods7920 For This Useful Post: | FreeFlyFreak (12-29-2010) |
12-31-2010, 03:00 PM | #97 |
| Not Ranked : 0 score Christian thanks for editing your post with all the code to include BD for 3 port EBC configuration....it looks like to me that you found that the 3port reacts much faster and thus the BD table shouldn't have to intervene with as much correction. Is this correct? and were those 3port tunes you mentioned OEM turbos, Big Turbos or a mix?
01-03-2011, 01:21 PM | #98 |
Rep Power: 0 Thanks: 28
| Not Ranked : 0 score Ok so I guess I'm just retarded...but I've read through this thread like 3 times and can't find where I update ATR to give me the boost tuning option. Someone was talking about an automatic update...which I did for my AP...but not sure who this is connected with ATR (along with the IGN table update) *EDIT* I assume I have a older version of ATR...just went on cobbs site and sent in for a link for the ATR beta
__________________ Last edited by AFcadet; 01-03-2011 at 01:47 PM. |
01-03-2011, 01:51 PM | #99 |
Groans: 754
EDIT>Advanced Parameters>Toggles>Use Boost Based Dynamics
01-03-2011, 04:52 PM | #100 |
And what was christian talking about using "autoupdate" to update the IGN tables? Is this a new feature in ATR as well? Just "update" and it will automatically apply the new IGN tables to the selected map?
__________________ | |
01-03-2011, 05:13 PM | #101 |
Groans: 754
No need to resubmit for a new download. Therefore when they add new tables, or features, you can just "update" ATR and get them. Those extra ignition tables were added after the new ATR came out, therefore people who got early editions needed to auto update to get them.
01-06-2011, 07:55 PM | #102 |
Rep Power: 0 Thanks: 146
| Not Ranked : 0 score do we uncheck the load boost control when we select the boost control?
__________________ 2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs) |
01-06-2011, 10:11 PM | #103 |
| Not Ranked : 0 score absolutely... use ABS Load shouldn't be checked by default anyway.
01-07-2011, 12:09 AM | #104 |
| Not Ranked : 0 score Alright sweet just wanted to double check
01-09-2011, 02:17 PM | #105 |
| Not Ranked : 0 score anyone have ideas of how to properly tune with this? After experimenting with it...I'm finding you tune for boost with the WGDC table...not really the boost table...which is kind of wierd... I was getting 17 psi when I was calling for 19.5 at 5500...I bumped up the WGDC and got a massive nasty spike to 21 psi. I am reducing the wgdc a little and seeing what that does...but its just wierd...the ecu just doesnt seem to do a good job of controling boost...rather it just references the WGDC table and leaves it at that.
01-09-2011, 04:02 PM | #106 |
| Not Ranked : 0 score You can take a look at my thread that covers my process. I am just about finished and used some suggestions from Christian. http://www.mazdaspeedforum.org/forum/foru...39/index2.html
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 01-11-2011 at 10:57 PM. |
01-11-2011, 10:49 PM | #107 |
| Not Ranked : 0 score Can you post a link...i must be blind...cant find the ATR section...
01-11-2011, 10:58 PM | #108 |
| Not Ranked : 0 score link added to my earlier post.
01-12-2011, 09:22 PM | #109 |
| Not Ranked : 0 score <3 you
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/initial-details-into-how-boost-based-tuning-66400/ | ||||
Posted By | For | Type | Date | |
Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | This thread | Pingback | 04-12-2011 06:14 PM |
Volkswagen releases initial pics, details on all-new Caddy | Haltech | Automotive News | 0 | 07-22-2010 04:50 PM |
Initial Impressions of Grimmspeed Boost Solenoid | tbot | MazdaSpeed 3/6 - ECU Computer Tuning | 44 | 04-14-2010 04:45 PM |
Please educate me on a few details of how the turbo on this car works... | Smokehouse | MazdaSpeed 3 - Engine, Transmission & Driveline | 28 | 01-02-2009 04:05 PM |
