MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
Search Forum |
07-18-2010, 11:39 PM | #1 |
Rep Power: 0 Thanks: 472
(Thread Starter) | Not Ranked : 0 score Not hitting full boost on Hypertech Cobb flash So i did a few 3rd gear logs after i flashed with the hypertech...used the cobb sri flash. Removed 0-60 throttle restriction so i assumed i will be hitting full boost even on 3rd gear. On my first run, i peaked at 18 psi which is what i'm supposed to be hitting with the HT flash but it would gradually decrease and not hold 18 psi. I thought i might have a boost leak so I did a couple more runs with WGDC% to check for leaks. WG duty values should be high to compensate for a leak but values are around 40% so i dont think i have a leak. all clamps are on pretty tight. Is there another way to detect a leak asides from high WGDC values? Why am i not holding 18 psi? stock bpv?
__________________ -John | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | |
07-19-2010, 12:27 AM | #2 |
(Thread Starter) | Not Ranked : 0 score nobody?
07-19-2010, 01:04 AM | #3 |
Rep Power: 371 Thanks: 558
| Not Ranked : 0 score checkout my thread on the HT, I was able to hit 18, then hold 16psi what are your mods ?
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
07-19-2010, 01:39 AM | #4 |
(Thread Starter) | Not Ranked : 0 score i will be happy if i hold 16 psi but i'm losing boost quickly. i'm already at 13 psi by 5500 rpm. just have need to do a boost leak test...but shouldnt wgdc be high if i have a leak? mods are cobb sri/tip, cs test pipe, mazdaspeed cbe
__________________ -John | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | Last edited by JohnMS3; 07-19-2010 at 01:53 AM. |
07-19-2010, 01:56 AM | #5 |
(Thread Starter) | Not Ranked : 0 score here is also my first log when i got my HT. used the cpe flash on this log. boost is still the same. peaks at 18 psi and drops down rather quickly...only at 10 psi by 5300 rpm. .7 kr as well
07-19-2010, 06:17 AM | #6 |
Rep Power: 0 Thanks: 1,102
Groans: 50
| Not Ranked : 0 score Try logging load? Maybe one of you pros can chime in here, but is it possible he's making the load target at 13 psi? |
07-19-2010, 06:27 AM | #7 |
Rep Power: 1818 Thanks: 1,848
Groans: 105
| Not Ranked : 0 score Wg duty cycle would be high if it was the turbo not being able to handle it. Since it is particularly low maybe there is a leak. http://forum.mazda6club.com/mazdaspeed6/219844-how-find-boost-leak.html I just made one of these last week for 15 bucks. Best way to find the leak. Thank djuosnteisn for the write up.
__________________ 2012 WRX HB w/mudflaps yo! |
07-19-2010, 08:18 AM | #8 |
Rep Power: 0 Thanks: 5
Groaned at 7 Times in 1 Post
| Not Ranked : 0 score Honestly man, that stock dv is probably bleeding it off, it's setup to do so on the stock load so I'm sure it's really highlighted right now by the extra boost, if you want it to be quiet and work well, you can't beat Forge - ran there products for years on my Audi's and VW's.
__________________ 02 Saleen Vert - Blown, T-56 Viper Spec, IRS, MM coilovers, IRS, etc.. For Sale need 4 doors, it's why I'm here 92 4Runner - lifted, locked, planned to upgrade but now will be my downpayment for the MS3 |
07-19-2010, 11:25 AM | #9 |
(Thread Starter) | Not Ranked : 0 score i saw that boost leak tester before but i dont have a an air compressor. i want to verify if the bpv is leaking before i invest in one. i might do a couple of runs on stock tune but i dont think its the tune that is causing my low boost pressure. any more ideas?
07-19-2010, 11:36 AM | #10 |
Groans: 105
| Not Ranked : 0 score You must know someone with an air compressor.
07-19-2010, 11:43 AM | #11 |
Rep Power: 0 Thanks: 317
Groans: 42
Groaned at 53 Times in 14 Posts
| Not Ranked : 0 score You can get a small compressor for like 40 bucks. Trust me it's well worth it for investment. You'd be surprised how many things you use it for once you have one lol.
__________________ Sold: 2010 MS3 - I'll miss ya Now: 2013 Mustang GT |
07-19-2010, 11:49 AM | #12 |
(Thread Starter) | Not Ranked : 0 score yeah i do. how about the stock bpv? how can you check if it's bleeding boost?
07-19-2010, 01:05 PM | #13 |
Rep Power: 123 Thanks: 7
| Not Ranked : 0 score Just get a Forge BPV. If you still have the problem its somewhere else. If not, u still have an upgraded part.
__________________ 2006 Mazdaspeed6 GT - SOLD [Magnaflow CBE] 223awhp 242awtq - Mustang Dyno 2008 Mazdaspeed3 Sport - SOLD [Cobb SRI] [Forge BPV] [TWM STS] 14.514@98.67 *Stock* |
07-19-2010, 01:09 PM | #14 |
Police Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 Thanks: 2,737
Groaned at 9 Times in 9 Posts
| I have your solution. Try with a different map. Even if you have the COBB Intake (like I do), set your Hypertech to the CP-E Nano map or the HKS intake map. Those setups will let your turbo hit at least 17 psi in 3rd gear and 18 in 4rd. Check the thread to see dyno results between different maps: Hypertech Intake Maps results
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
07-19-2010, 01:33 PM | #15 |
__________________ -John | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | Last edited by JohnMS3; 07-19-2010 at 04:03 PM. | |
07-19-2010, 04:58 PM | #16 |
(Thread Starter) | Not Ranked : 0 score bump can WGDC values be low if there is a boost leak or should it always be high? just want to know if my inability to hold boost is due to a leak or this can be a result of the HT tune. I didnt do any stock logs and will do one at night.
07-19-2010, 05:04 PM | #17 |
| Not Ranked : 0 score had same problem on 1st HT flash, re-flashed and all was good I suggest you flash back to stock, the re-flash, this fixed my problem There is a flakey issue sometimes with HT, esp. if you are not coming from a stock tune. Other people have had to flash twice to get it working properly, no big deal only takes 5 extra minutes. Annoying but easy fix.... try it and post back results
07-20-2010, 06:41 AM | #18 |
| Try with HKS tune.
07-20-2010, 12:22 PM | #19 |
(Thread Starter) | Not Ranked : 0 score reflashed with stock tuning thenc cobb...hopefully this is just a tuning issue. will post logs later on
07-21-2010, 10:50 PM | #20 |
(Thread Starter) | Not Ranked : 0 score did a few more logs tonight and just want to get some feedback on these logs...i'm not pleased with my hypertech flash at all and boost is not holding at the advertised 18 psi. it's like i have stock tune on except that 1st to 3rd gear boost limits are removed. i flashed three times already and no change. can i have a boost leak without wastegate duty increasing? 1st log is on 3rd and 4th gear. knock on both and had to shift early due to approaching traffic. 3rd gear
07-21-2010, 11:06 PM | #21 |
(Thread Starter) | Not Ranked : 0 score how do you change the dark blue field on these logs to something brighter?
07-22-2010, 03:13 PM | #22 |
Rep Power: 154 Thanks: 61
http://www.mazdaspeedforum.org/forum/foru...sri-tip-61898/
__________________ 2008.5 MS3 GT | Hypertech Flash | Cobb SRI | Cobb TIP | SU Test Pipe | Forge BPV | JBarone SSP w/ bushings | Matt Damond's OCC kit | SU RMM | 20% tint | LED swap | Raptor DDE Halo kit | Rally Armor Mud flaps | Sideskirts | TRS clear lenses | DashHawk with CPE mount 278 whp, 300 wtq | |
07-22-2010, 04:33 PM | #23 |
Rep Power: 414 Thanks: 105
| Not Ranked : 0 score Right click the chart->edit->channels. Or you could change the background.
__________________ |
Hypertech Boost issue? | ANMSPD3 | MazdaSpeed 3/6 - ECU Computer Tuning | 26 | 05-04-2010 08:48 AM |
Not hitting right psi for cobb map stage 1!! | gt5 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 04-21-2010 05:50 PM |
Cobb Accessport flash remove boost limit in 1st and 2nd? | TongMan | MazdaSpeed 3/6 - ECU Computer Tuning | 24 | 11-20-2009 07:21 PM |
Not hitting boost targets, Underboosting | spheed3 | Cobb ATR Support | 17 | 08-09-2009 12:24 PM |
