 Old 01-08-2011, 06:16 PM   #1
gamma500's Avatar
Posts: 38   (View Stats)
gamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to behold
Default 08 MS3 Serpentine belt question??
Are there 2 different belts for an 08 MS3 ? Noticed RockAuto has 2 belts differentiated by a VIN cutoff. I ordered another belt (Dayco) without any VIN distinction and try as I could (belt kept warm inside) I couldn't get it fot with the tensioner at full "OFF".
Appreciate anyone with some feedback or firsthand experience with the drive belts.
gamma500 is offline   Reply With Quote
 Old 01-09-2011, 05:16 AM   #2
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
there is only one belt that drives the acc.
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 01-09-2011, 05:31 AM   #3
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
might have changed the tensioner or idler in 07-08.5 or at the 09. yep. on autozone it gives 2 parts number one for 07-08. and one for 09. so i assume it has to do with the 08.5 or the 09.
 Old 01-09-2011, 05:51 AM   #4
gamma500's Avatar
Yeah, that's what I thought...hopefully RockAuto will help me out.
 Old 01-09-2011, 06:00 AM   #5
skeeter149's Avatar
Groans: 91
i hope so man and good luck. i took my 08.5 oem off and find that it can be a little tricky to get on there. took it off 3 times and reinstalled same one. 2 times it fought one time it went on with slack. and the 2 times i mean we fought to get it on and it almost took a finger when it "slipped" on. but alas good luck, what is your dayco part number so i can see which car it goes to on vatozone?
 Old 01-09-2011, 06:41 AM   #6
gamma500's Avatar
DAYCO # 5060910. My OEM belt went back on easily but there was no way the new belt would fit despite my prestretching it and warming it up. My 08's build date is 10-7. Thanks for the help. I got a small pebble stuck in the tensioner pully which chewed up the outer rib on one side so thought would be a good thing to replace even though only 21K miles old.
 Old 01-09-2011, 06:49 AM   #7
gamma500's Avatar
Autozone has 2 belts on their website, both 91 inches long....I don't know..maybe it is just a bitch and a half to get on like you found out.
 Old 01-09-2011, 02:58 PM   #8
easy's Avatar
Groans: 27
the way i did it was to put the belts around all the pulleys and tensions except the water pump pulley since its unribbed and will slip on easier. Push the tensioner in the direction of the arrow and slip the belt on the water pump pulley. An extra set of hands will make things so much easier.
08 MS3
 Old 01-09-2011, 06:49 PM   #9
gamma500's Avatar
Agree...couldn't con my wife into helping me..she knows I yell!!
The Following User Says Thank You to gamma500 For This Useful Post:
easy (01-09-2011)
Drive Belt Diagram spnkr21 MazdaSpeed 3 - Engine, Transmission & Driveline 7 09-23-2013 03:39 PM
serpintine belt issues anyone? Sirwill798 2010 MS3 - Troubleshoot/Diagnostics 9 06-03-2010 10:41 PM
Timing Belt: The Engine One Tourbillon by Chopard L.U.C. Haltech Automotive News 0 03-24-2010 06:10 AM
belt diagram ms3-87 MazdaSpeed 3 - Engine, Transmission & Driveline 4 05-16-2009 07:38 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Page generated in 0.29355 seconds with 22 queries
