  • 1 Post By MattJackson86
  • 1 Post By speedms6
 Old 08-22-2012, 11:05 PM   #1
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Default Bad Sound from Engine Bay
So on a cold start up in the morning yesterday I heard what sounded like really bad knock as the car was warming up (after running for 2-3 mins). Happened probably 6 times about 1/2 second apart and then stopped. Nothing to really hear afterwards. No CEL of any kind, no KR readings, nothing. Drove to work no issues and honestly is driving like nothing is wrong.
Today I heard another bang 1-2x when coming out of driveway at work, also when stopping in the garage at home. Now there is a pretty consistent rotational scratching/whine is present in engine bay. It may stop and then come back worse for a second, it may just get fainter. It may get worse and turn into that knock sound for a couple times. But its there and noticeable. Spent some time trying to pin point it and its somewhere around intake manifold -> exhaust manifold -> turbo area. It is definitely rotational and sounds like metal scratching/whining.
Car has 90,500 miles, driven hard. On the second K04 turbo for last 50,000 as first one had leaky seals. Hoping its just the turbo that has finally crapped out, out of balance, etc. Dont think its the engine itself only cos it drives great, no CEL, etc.
Thoughts? I am probably going to drop it off at Mazda tomorrow for a look over, it just came out of there 4,000 ago for a timing chain, VVT, replacement.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline   Reply With Quote
 Old 08-23-2012, 12:28 AM   #2
jfspeed6's Avatar
Posts: 1,508   (View Stats)
jfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the world
I would say your VVT needs to be looked at. The sound you are hearing is most likely the timing chain hitting the valve cover. a dealership around my way was putting the VVT on th wrong way. One of my friends cars sounded like that after he got his swapped out by them.
2006 Titanium Gray Mazdaspeed6 GT
2002 Mercedes Benz CLK 430 Cabriolet
jfspeed6 is offline   Reply With Quote
 Old 08-23-2012, 12:38 AM   #3
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
Check your tensioner pulleys for loose/wobbly pulleys when they go bad it sounds like vvt issues.
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following User Says Thank You to Captain KR For This Useful Post:
Jfishe (08-23-2012)
 Old 08-23-2012, 08:54 AM   #4
I looked at my pulleys as they seem fine, but I will take a closer look. As for the vvt, I did check the chain and its tight. The sound is quite different than when I had the vvt issues before. Again I will take a closer look.
I'm going to also try taking the inlet off and see if the turbo shaft is wobbly. That's what I suspect so far.
Thanks.
The Following User Says Thank You to MattJackson86 For This Useful Post:
rfinkle2 (08-23-2012)
 Old 08-23-2012, 10:16 AM   #5
Just got back from Mazda. Its a bad AC compressor. The pulley is wobbling around. They quoted $1400 + tax. Going to call around some other places.
 Old 08-23-2012, 10:25 AM   #6
Shadow's Avatar
Posts: 430   (View Stats)
Shadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the world
Ac compressor can be done anywhere, including home if you hate the environment. I would def take it to a local shop should be like 800 bucks installed.
Sent from my ADR6400L using Tapatalk 2
2012 Black Mica MS3 w tech
Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else
Shadow is offline   Reply With Quote
 Old 08-23-2012, 10:27 AM   #7
Good to hear (although expensive).
Good luck Matt.
MattJackson86 (08-23-2012)
 Old 08-23-2012, 11:44 AM   #8
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
subbing here as i have a "chirping" noise or squeeking upon cold starts that goes away when the engine warms on my MS6. is this VVT? or something else.
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
 Old 08-23-2012, 12:17 PM   #9
Jfishe's Avatar
Posts: 611   (View Stats)
Jfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the worldJfishe is the leader of the world
Sucks it was the AC compressor. Had what seems to be the same problem recently...thought it was VVT and had it replaced under the extended warranty but didn't fix the problem. Turns out it was the pulley tensioner and my friend and I replaced it. Cost $65 from advanced auto.
Hope you get it fixed up.
2008 True Red Mazdaspeed3 GT | Cp-e RMM 75A | Cobb SRI | CorkSport TIP | JBR Stage 2 SSP | Nator'd DP | Ebay Test pipe | CX Racing FMIC | Autotech Internals | Richtuned | NGK Iridium IX
Awaiting Install: H&R Lowering Springs | KONI Sport Shocks
Jfishe is offline   Reply With Quote
 Old 08-23-2012, 12:24 PM   #10
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
i got an ac compressor for like 150 bucks off Car-Part.com--Used Auto Parts Market, swapped it out myself and took it to a shop to recharge. total cost was under 250 bucks for everything.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
 Old 08-23-2012, 12:49 PM   #11
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
high pressure relief valve(hprv) at the end of your fuel rail, search on here there is a thread about it, had the same problem, got a new one, went away
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
The Following 2 Users Say Thank You to speedms6 For This Useful Post:
rfinkle2 (08-24-2012), Speeden6 (08-23-2012)
 Old 08-23-2012, 03:14 PM   #12
Going to TriPoint today to have them give it a once over to confirm if its the compressor or not. Parts alone seem to be about $850 (compressor, clutch, "receiver dry can", etc), then $300 for labor from them. Trying to see if I can get the parts cheaper or not. For $300 labor its not worth me doing it personally, even if I get someone to do the evac and refill.
 Old 08-23-2012, 07:21 PM   #13
Shadow's Avatar
If you lived closer I'd do it at work and cut you a deal. :/
The Following User Says Thank You to Shadow For This Useful Post:
 Old 08-23-2012, 08:20 PM   #14
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
$850 is about right, if its the bolt that holds the clutch on, you can get a new one at lowes for $2... my a/c clutch completely fell out and got pinned between the compressor and frame and I drove that bitch 300 miles home like that and I just bought a new bolt and its been fine for the last 40k miles and that clutch material was all fubared.
2006 Mazdaspeed 6
 Old 08-23-2012, 09:49 PM   #15
Got it on jack stands and under tray removed. Going to see if I can see the issue as is happens tomorrow morning. Tripoint also mentioned my idler pulley was iffy as it too was wobbling slightly. I did confirm that myself.
 Old 08-24-2012, 12:10 PM   #16
So got under the car today and started it up. AC off, and the noise started.
Let me know your thoughts. I dont see the AC pulley wobble much before, maybe a bit more during the noise. Its got a slight wobble and so does my idler. I dont know if thats normal but TriPoint said idler for sure not.
 Old 08-24-2012, 12:47 PM   #17
Uberfly's Avatar
Posts: 773   (View Stats)
Uberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the world
holy shit! that sounds horrible. I hope you're able to figure it out.
2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV
Uberfly is offline   Reply With Quote
The Following User Says Thank You to Uberfly For This Useful Post:
MattJackson86 (08-24-2012)
 Old 08-24-2012, 12:56 PM   #18
mikeblackspeed3's Avatar
Posts: 27   (View Stats)
mikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond reputemikeblackspeed3 has a reputation beyond repute
I recently had this noise and was able to fix it by replacing just the pulley on the compressor; the bearing was bad. Does your noise only occur with the a/c off? If so, scour the internet for a used compressor with the pulley and clutch attached and swap that pulley! Easy job, no need to evacuate and recharge the system, and you'll have a spare compressor if you need it. Only cost me $150, and a set of snap ring pliers. Good luck to you!
In other words, if the noise goes away when the compressor clutch engages, you only need the pulley. Unfortunately, they aren't sold as a separate unit, hence the need to find a used compressor.
-I don't speed, I just get to the speed limit quickly!
07 black mica Speed 3. Mazdaspeed intake, Mazdaspeed cat-back with Magnaflow muffler, Corksport test pipe, Hypertech, SU mounts, CS rear insert, TWM short shifter w/bushings, Pioneer DVD, Polk Audio speakers, Orion amps and sub, generic boost gauge. Exterior: Removed side moldings, blacked out side markers/rear reflectors/front logo, 15% tint, painted calipers.
mikeblackspeed3 is offline   Reply With Quote
The Following User Says Thank You to mikeblackspeed3 For This Useful Post:
 Old 08-24-2012, 12:57 PM   #19
Yes it is a pretty horid sound :-(
I have only found the noise with ac off yes.
 Old 08-30-2012, 02:49 PM   #20
So got a whole new ac compressor, pulley, clutch, receiver can installed yesterday. Started up the car this morning and same exact noise
Took it back to Tripoint and they heard it and diagnosed the issue with a stethoscope. They said its the AC compressor again and must have received a bad unit. They are overnighting a new one and should be installed tomorrow. Hopefully this time it works.
 Old 08-30-2012, 02:55 PM   #21
btstarcher's Avatar
Posts: 4,852   (View Stats)
I had this noise and let it go; a few months later I was replacing my compressor.
SnailTune in progress
MattJackson86 (08-30-2012)
 Old 08-30-2012, 05:58 PM   #22
So maybe it was just a faulty compressor, just seems odd to have same issue 2x.
Any thoughts on if it could be a water pump issue? Trying to think why it mainly occurs early morning when warming up and only when the AC is off.
 Old 08-30-2012, 08:49 PM   #23
btstarcher's Avatar
Might not line up properly; mine went bad because when my engine was replaced they mounted the compressor slightly crooked. Over time the bearings wore out. Lots of shaft play, you could reach down and move the pully.
Chain-like / bearing sound from engine 3starmagnum 2010 MS3 - Troubleshoot/Diagnostics 12 05-28-2012 12:44 PM
Video: Bentley teases sound of new V8 engine Haltech Automotive News 0 12-06-2011 10:20 AM
Report: Hyundai Sonata Hybrid delay due to modifications of virtual engine sound Haltech Automotive News 0 02-24-2011 09:40 AM
Does my engine sound okay? Qtip MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-05-2010 08:16 PM
Unusual Engine Sound mordxp MazdaSpeed 3 - Engine, Transmission & Driveline 22 03-15-2010 06:53 PM
Page generated in 0.43449 seconds with 32 queries
