 Old 04-09-2009, 09:02 PM   #1
TXspeed3's Avatar
Posts: 634   (View Stats)
TXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these partsTXspeed3 is infamous around these parts
Groans: 42
Groaned at 1,202 Times in 580 Posts
Default Best TBE option
Ok i think i have this narrowed down.... Should i go w/ Vibrant TBE, TurboXS TBE, or Cork Sport TBE.... I like the sound of Cork Sprt the best but which has the best power gains.. I've been told Vibrant does.. any clarification?
TXspeed3 is offline   Reply With Quote
The Following User Says NO Thank You to TXspeed3 For This Un-useful Post:
 Old 04-09-2009, 09:51 PM   #2
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
the vibrant would be a good choice with only the corksport or turboxs downpipe, since it only replaces the second cat with a high flow cat. its considered a downpipe-back exhaust system. They are all good choices, but this platform with the tiny-ass turbo needs a little bit of backpressure in order to not overboost. i would put a high-flow cat in there somewhere.
'08 CWP MS3 w/ T3 3071r
 Old 04-10-2009, 07:52 AM   #3
TXspeed3's Avatar
Groans: 42
So does the CORK Sport "complete TBE" not do that? I'm trying to find the easiest way to accomplish all of this with one purchase.. that possible?
 Old 04-10-2009, 08:45 AM   #4
rabble rabble
802MS3's Avatar
Groans: 221
There are 3 components to the MS3's exhaust system: the downpipe, the midpipe, and the cat-back. The stock downpipe and stock midpipe both have cats.
both the corksport and turboxs TBE are catless. this isn't that much of an issue, except that some people experience overboosting, which can shorten the turbo's life. the corksport downpipe is the only one you can purchase separately, I believe the only way to purchase the turboxs dp is the 'stealthback' exhaust which includes the catless midpipe as well. I believe a good choice is just buying the corksport downpipe and combine it with the virbrant downpipe-back exhast. That way you will have 1 high-flow cat and it will help your boost stay consistant with the stock turbo. This obviously isn't needed if you want to go completely catless, and in that case the turboxs or corksport TBE will be fine. just be warned that the turboxs catback is LOUD.
TXspeed3 (04-10-2009)
 Old 04-10-2009, 08:59 AM   #5
wassup61's Avatar
Posts: 1,232   (View Stats)
Get the Corksport. We have sold many of these units, and all of our customers are VERY Satisfied with them, including me.
Jeff at PG
All wagon, No traction
The Following User Says Thank You to wassup61 For This Useful Post:
 Old 04-10-2009, 10:37 AM   #6
TXspeed3's Avatar
Groans: 42
Default Corksport it is
Thanks to both of you, thats exactly what i wanted to hear... I appreciate the advice and I'm going to order the Cork Sport TBE.. Motor mount, Injen intake and not sure on the BPV.. think im safe installing this all at once?
 Old 04-10-2009, 10:54 AM   #7
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
get the stainless works dp, wassup can give you a good price on the unit..for a cbe any unit out there is good, i personally have the cp-e and i love it
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 04-10-2009, 11:40 AM   #8
TXspeed3's Avatar
Groans: 42
Default CPE?
Everyone keeps using that abreviation.. who is that company? and what does that stand for?
 Old 04-10-2009, 11:45 AM   #9
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
custom performance engineering.
if you have the money PM palerider and order their exhaust through him.
IMO the best 2 DP`s are cobb & CPE.
corksport is a different style(divorced wastegate gasses), and is a shorty DP.
2008 STi
Intake
Turboback
AP
 Old 04-10-2009, 02:46 PM   #10
TurboMazda1313's Avatar
Posts: 108   (View Stats)
TurboMazda1313 is a jewel in the roughTurboMazda1313 is a jewel in the roughTurboMazda1313 is a jewel in the rough
Anyone throw a CEL with the CS TBE?
TurboMazda1313 is offline   Reply With Quote
 Old 04-10-2009, 03:37 PM   #11
wassup61's Avatar
Nope
Comes with a spacer for the O2 sensor.
Also the CP-E is a quality unit, but you are almost at the price for a full turboback for just the DP!
Jeff at PG
 Old 04-12-2009, 09:20 PM   #12
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
i have a corksport dp and a vibrant dp back and i love it!
2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot
Future Mods[/B]auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal!
ms3boost is offline   Reply With Quote
 Old 04-12-2009, 10:43 PM   #13
ptperformance's Avatar
Posts: 4,123   (View Stats)
We have a Group Buy going on in our section for a great deal. I have sound clips up on Youtube, here is a link
. This is missing the DP and this is the magnaflow muffler. Let me know what you think, thanks.
 Old 04-13-2009, 12:32 PM   #14
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
Yes people have thrown CELs with and without the extender. But not everybody.
I've had mine for 20000km and I think I only got 1 CEL during the first 200km.
It's a quality piece for a great price.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 04-13-2009, 05:08 PM   #15
cortytx8's Avatar
Posts: 267   (View Stats)
cortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the worldcortytx8 is the leader of the world
How good is the HKS one? Does anyone have experience with one? Can the HKS mate with with any RP/DP out there?
cortytx8 is offline   Reply With Quote
 Old 04-13-2009, 06:02 PM   #16
ms3boost's Avatar
yes it can
 Old 04-14-2009, 11:30 AM   #17
MisterMatt's Avatar
Posts: 45   (View Stats)
MisterMatt has a spectacular aura aboutMisterMatt has a spectacular aura about
i have the hks cbe and the cp-e downpipe on my car
MisterMatt is offline   Reply With Quote
 Old 04-14-2009, 01:09 PM   #18
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
Like Kingpin said above, it's really hit and miss on the cel. But you should have a dashhawk, if not I think it should be on the top of your list of parts. And with the dashhawk you can clear the cel! I got one CEL about 200 miles after the Corksport DP and RP install for "Slow reading O2" (or something like that). Cleared it and 15k miles later no more CELs have come up.
Good choice with the corksport exhaust, I really love the sound as well. I am planning on getting it some day. I'm still on the stock cat-back for now. From my past dealings with Corksport, they are such a good company. I was buying parts from them years ago when I had my Rx7 Turbo II, great guys.
ChrisK is offline   Reply With Quote
 Old 04-14-2009, 10:12 PM   #19
cortytx8's Avatar
is the corksport DP/RP 3 inches?
 Old 04-15-2009, 12:38 PM   #20
wassup61's Avatar
Yes, Corksport DP/RP combo IS 3 inch. It also has a REALLY good sounding exhaust note and is an affordable and quality piece.
Jeff at PG
 Old 04-15-2009, 12:52 PM   #21
Haltech's Personal Bitch
PDXImportRacer's Avatar
Posts: 275   (View Stats)
PDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond repute
TurboXS TBE will make some big power BUT it is LOUD.. REALLY LOUD! A customer came though an got a custom tune and made 317/343 w/ a Cobb FMIC, Cobb SRI, TurboXS DP and CBE. If you look at the TXS stuff it is a little larger and has 0 back pressure. Only consider it if you dont mind a loud exhaust.
PDXImportRacer is offline   Reply With Quote
 Old 04-15-2009, 01:53 PM   #22
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
Thats almost exactly where my car is at. you should decide how you want to deal with the 19psi boost cut before you install everything.
reddeerspeed3 is offline   Reply With Quote
 Old 04-15-2009, 03:41 PM   #23
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
CP-E TBE....maybe a little more money... but mine has been flawless for 2 years and never a fitment or CEL issue.....get the best. Cobb would be my 2nd choice but not available.
Corksport nice, but i have heard issues with early units...By local...CP-E FTW!!!! If i had to do it again this would be a no brainer.
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline   Reply With Quote
 Old 04-15-2009, 08:48 PM   #24
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
no issues with my corksport dp.
know your roll
martyxattack is offline   Reply With Quote
 Old 04-16-2009, 01:19 AM   #25
cortytx8's Avatar
Does anyone know if I need to buy new gaskets for an DP install? is there anything esle special to do to Mate an Aftermarket DP to the stock CBE?
 Old 04-16-2009, 03:46 PM   #26
it depends on how old your car is. you should be able to re-use the stock gasket, but if you have any doubts, get a new gasket ahead of time. you will need an O2 sensor socket and a good variety of 14mm 3/8" drive sockets, extensions, and swivels. i found that a wobble extension worked the best for the bolts on the turbo. i've attached the PDF instructions for the corksport DP to give you an idea of whats involved
The Following User Says Thank You to reddeerspeed3 For This Useful Post:
cortytx8 (04-16-2009)
 Old 04-16-2009, 04:24 PM   #27
ATAZ's Avatar
Posts: 314   (View Stats)
ATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond repute
good info! I think i just made my decish....corkspiddy TBE. Whats with this 19psi over boost, how is that solved?
sorry for the hijack!
ATAZ is offline   Reply With Quote
 Old 04-16-2009, 05:09 PM   #28
cortytx8's Avatar
Thanks man, I guess I'm gonna be picking some tools up. My car is brand new so I will use the stock ones again.
 Old 04-16-2009, 08:06 PM   #29
i had a used dp and still had no problems with the gasket.
know your roll
 Old 04-17-2009, 02:10 AM   #30
Thats how bad the oem parts starve the motor. Boost control, MAP clamp or EMS, etc.
Next Mercedes SLK to offer diesel option Haltech Automotive News 0 11-06-2008 11:40 AM
Mulally: Ford bankruptcy is not an option Haltech Automotive News 1 10-29-2008 02:37 AM
Mulally: Ford bankruptcy is not an option Haltech Automotive News 0 10-28-2008 03:40 PM
Page generated in 0.49362 seconds with 37 queries
