 Old 07-24-2009, 08:39 PM   #1
Huligan's Avatar
Posts: 142   (View Stats)
Huligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud of
Default Brand name test pipe vs. custom muffle shop test pipe
I went into a muffler shop the other day and asked if they could bend and fab a custom test pipe for me and they said they could for about $60 which I thought was great compared to $180 for a corksport or cpe test pipe..
has anyone had any bad experiences with muffler shop custom stuff?
yes it's modded.
Huligan is offline   Reply With Quote
 Old 07-24-2009, 08:48 PM   #2
dixie789456's Avatar
Posts: 635   (View Stats)
dixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the world
Groaned at 25 Times in 15 Posts
ebay pipe is damn good for 140.00! polished stainless steel and fitment was perfect. nice welds and flanges. even comes with a new gasket, but that wasn't a perfect fit.
dixie789456 is offline   Reply With Quote
 Old 07-24-2009, 08:52 PM   #3
Huligan's Avatar
so the gasket wasnt perfect, but the pipe was? i remember seeing a gasket for like 35 bux somehwere :/
yes it's modded.
 Old 07-24-2009, 09:18 PM   #4
yeah the pipe is much better than expected and the gasket just needed a little bit shaved off of the inside. it was a little to small for the pipe. its just a lead doughnut gasket so it was pretty easy to fix.
 Old 07-24-2009, 09:18 PM   #5
or you could just get another oem gasket?
 Old 10-04-2009, 02:30 AM   #6
Underground's Avatar
Posts: 55   (View Stats)
Underground has a spectacular aura aboutUnderground has a spectacular aura about
ive always wondered this also... theres a custom muffler shop like 2 blocks away that said they could make the whole tbe for $500 installed... thats about the same price i would pay for just the cpe dp alone. I knew someguy that said he had his A4's tbe built there and he said it was WAY better than stock according to his butt dyno... idk if thats true, my guess is all the extra noise made him think he was going faster?
Underground is offline   Reply With Quote
 Old 10-04-2009, 02:47 AM   #7
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
you cant use the 2.5" oem gasket on a 3" test pipe. corksport sells 3" gaskets for $10 though, i would think they fit any 3" pipe
reddeerspeed3 is offline   Reply With Quote
 Old 10-04-2009, 11:09 AM   #8
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
As long as the shop can weld you wont have any problems. If your wanting a full ss pipe then go with the brand name one unless your shop deals with ss and can do ss welds.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 10-05-2009, 07:43 AM   #9
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
A local muffler shop will likely use aluminized mild steel and crush bent piping (not mandrel).
Spend the extra for something SS and mandrel.
 Old 10-05-2009, 07:46 AM   #10
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
yeah a shop can one-off an exhaust for you no problem, the money you pay for a brand name is the name, R+D, materials and build quality.
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
 Old 10-05-2009, 07:52 AM   #11
boardjnky4's Avatar
Posts: 402   (View Stats)
boardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the world
Groaned at 40 Times in 22 Posts
Stainless steel isn't necessary unless you live in a high-rust area...Mandrel is a MUST though
with turbo cars, custom exhausts are much easier. Route the pipes so that there are the least number of bends, and you'll have a good exhaust. With NA cars, the car can suffer from a lack of backpressure, so they exhausts need to be well designed.
boardjnky4 is offline   Reply With Quote
i want to add a cat to my test pipe Munnugles MazdaSpeed 3 - Engine, Transmission & Driveline 31 05-29-2009 04:40 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.31699 seconds with 27 queries
