| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 853 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score So... back-track a little bit... I made an oil change about a week ago and went to empty the SM catch can and only a few drops came out of it. I didn't think much of it since it's not been that long since my last oil change. Well, today I thought to check the catch can a little closer because it's the only reason I can think of that I would be pushing oil into the intake and smoking... The catch can is frozen SOLID with water that it pulled from the crankcase!!!! I've not been getting any PCV suck at all through it!!! I pulled it all the way out of the car and put the stock PCV/tube back in place and also put the stock TMIC back on until I can get a chance to clean up the air/water core and pipes from all of the oil in them.Today's lesson: Check your catch cans in colder climates!!! If I put the catch can back in place, I will be relocating the PCV valve up higher so that the catch can will be able to be located closer to the engine to make sure it melts if I do it at all.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
| The Following 9 Users Say Thank You to bnoon For This Useful Post: | bioevolve (01-05-2010), chaser27 (01-08-2015), Darksun280 (01-07-2010), Dash08 (01-17-2010), djuosnteisn (01-07-2010), Fobio (01-07-2010), FreeFlyFreak (01-17-2010), TopazM3 (01-17-2010), urville (09-16-2011) |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| Not Ranked : 0 score Wow, that sucks, glad you caught it before it got even worse. |
| The Following User Says NO Thank You to felt For This Un-useful Post: |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Yeah that sucks. I have a catch can but haven't installed it since -20 is like the average temp here in canada right now. I suspected that freezing would be a problem, but I wasn't 100 percent sure. Thanks for posting, now I know for sure. |
(Thread Starter) | Not Ranked : 0 score Yeah, I hope so too. I had high enough crankcase pressure that it pushed oil past the cam position sensor in the valve cover and I had light oil at the filler cap too. The main valve cover seal looks OK though. I think I got lucky with only short in town driving since I started noticing smoke. Hopefully all is well with the harder to replace seals like rear crank seal/etc that I would have to pull the engine to replace. The bottom of the engine is dry too, so that's a good sign. Yeah, we've been getting that here in Iowa, USA as well. Last two mornings have been -1 and -6 F as I've gone into work with -20-30 wind chills. Not a whole lot of fun.
| The Following 2 Users Say Thank You to bnoon For This Useful Post: | FreeFlyFreak (01-17-2010), urville (09-16-2011) |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score its funny you should post this, just yesterday i went to try to drain my saikou michi since its been a couple thousand miles, and it usually fills pretty fast in the winter, and only a couple drops came out... I stuck a small flat head up inside the drain plug to make sure it wasnt plugged but for all i know i could have just been stabbin a block of ice because nothing came out still. I wonder if this is how mine is...
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() Join Date: Aug 2009 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score Wow good to know what temps are you seeing in your area?
__________________ 08' Black Mica MS3 Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight. Sponsored by NATOR VA |
![]() Join Date: Sep 2009 Location: NE PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,832
Groans: 109
| Not Ranked : 0 score damn... i just installed mine, hopefully since it's just installed it'll still work since not much should be in there, warm tonight, 21... been the low teens past few nights
__________________ Mk7 GTI |
| Not Ranked : 0 score i wonder if there is anything we can spray up into the drain valve to melt the shit?? anybody have any ideas?
Groans: 109
| Not Ranked : 0 score ^ hairdryer/heatgun... lol
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score hmmm I only had maybe a 1/2 ounce come out of my can after 2 months installed ... it's -20 to 30 on average here now you have me thinking ... shitty thing is i have no where to work on the car to fight with that damn stock piece to go back to stock. No way am I doing it bare handed in a non-insulated garage |
| Not Ranked : 0 score Pour a little bit of windshield de-icer in the catch can. Not enough to fill it, but to mix some of that water with enough so that it won't freeze. |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
| Not Ranked : 0 score What about the lines? Mine are routed low and not near the engine ... is it likely something can freeze there? That said ... getting washer fluid in the can would be a HUGE bitch too |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score The same thing happened to someone on one of the other forums recently. I can find a link to it if anyone is interested. |
| Not Ranked : 0 score Put a blanket on the catch can. |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | breakfstincluded (06-15-2011), MATT DAMOND (01-06-2010) |
| Not Ranked : 0 score what damage can this do should it freeze? |
| Not Ranked : 0 score Read the posts by garymca: HOW-TO: Installing an Oil Catch Can |
Groans: 109
| Not Ranked : 0 score blanket isn't going to do much if it's cold out, blanket is an insulator and unless something is heating the CC not gunna help, maybe just disconnect the can and bring it inside with you? warm it up, empty... maybe leave the hose unplugged for winter and drain on the road like the old time hahah
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() Thanks: 8
| Not Ranked : 0 score I also have one of the Saikou Michi cans. I drain it every 2500 miles and typically see about 4 oz of fluid. The issue is that I have to have the can open for several minutes to get it to drain properly and it also helps if I wiggle the hoses around. I installed it with the Cobb directions and placed it in front of the passenger tire area. The concern would be that if you do not give it time and wait for it to drain you could probably fill it up and then would freeze in cold weather. Ed |
![]() Join Date: Oct 2008 Location: New Brunswick, Canada
| Not Ranked : 0 score Yeah at my last oil change, I went to drain my new CC... I openned the drain, and nothing. so I unthreaded it.... and stuck a screwdriver up inside.... icey goodness. Sooooo out came the propane torch, and a while later, I had myself an empty catch can... wondering how often i'll have to drain it. |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groans: 166
Groaned at 56 Times in 41 Posts
| Not Ranked : 0 score As long as you dont have a long stretch of horizontal run, you should be fine. I would think the easiest way to add the de-icer would be disconnect the hose from the pcv and dump it in there.
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
With engine heat it's been maybe melting an ounce or so, but the rest would stay totally frozen. I guess the lesson is to pull the plug all the way out and check with a screw driver to make sure you're ice-free and use a heat gun if you need to (My local Harbor Freight has an in-store special for $9.99 for Chicago Electric basic heat gun).
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall | ||
| The Following User Says Thank You to bnoon For This Useful Post: | urville (09-16-2011) |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score i would try emptying that thing weekly in the winter and the best time would be after you have run the engine for a bit to try and heat things up. i know after a week that mine empties quite a bit of water out of it so i wouldn't go much longer then that. |
![]() Join Date: Dec 2009 Location: Dublin, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 443
Groans: 54
| Not Ranked : 0 score Brad, glad to hear it was just the plugs.
__________________ Parting out! http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/ |
![]() | | #24 | ![]() |
![]() Join Date: Sep 2008 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score Tried emptying mine this past weekend (I have option 1 from Matt's GB) and only a little bit trickled out. It had been maybe three or four weeks since I last drained it. Didn't think about the contents freezing. Even in FL, we've been hit with the cold snap. But it gets above freezing during the day, so is that long enough for thigns to melt? Temps have been mid 20's at night and then maybe mid 40's during the day. |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
| Not Ranked : 0 score That's what I figured. I even took it off and shook it vigorously to see if there was anything in it. This was around mid 40's/low 50's temp. |
![]() | | #27 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score I can see a market for catch can warmers! Kinda like a NOS bottle warmer.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'll get to work on it! LOL!
| The Following User Says Thank You to bnoon For This Useful Post: | mr_mazda329 (01-06-2010) |
![]() | | #29 | ![]() |
![]() Join Date: May 2008 Location: Albuquerque NM
| Not Ranked : 0 score It might be the mounting location, I have my occ installed in front of the batt box. I read In a mag that one should mount their occ above the block. With this mountng location I have not seen the cloudy latte look in the fluid coming out of the occ looks like coffee/ black oil out of my occ. |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah yeah, har har har. Used to remove what ever vapor contamination is in the oil. i.e. water/fuel/etc. Also, judging by your location, you probably never would see much moisture in yours.
![]() | | #33 | ![]() |
| Not Ranked : 0 score Curious about this bnoon. I'm not too knowledged about the OCC, but could you elaborate as to when the OCC would see most liquid? I've drained mine three times now and am wondering if it's due to my driving style that there isn't as much gunk in mine as others. I've drained it in 2-4 week increments. Most I have had is 1/4 cup. |
![]() | | #34 | ![]() |
![]() Join Date: Jun 2008 Location: Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 258
| Not Ranked : 0 score mine froze up once already, i have the elite engineering can so all i do is unscrew it and dump it, so i don't really have to worry about the freezing. i am however checking it every week, to make sure it doesn't freeze again.
__________________ [SIGPIC][/SIGPIC] Falken FK-452 | 215-40R18 | Konig Hotswap |35% Tints| Greddy TT| Cobb Sri| Cobb Shifter| Cobb AP| Cobb Springs| Cobb RSB | Cobb Inlet Pipe |TS BOV |Dashhawk| COBB FMIC |CPE MM|CPE DP| STILL TO COME: |Whatever I can get my hands on before she kills me| |
![]() | | #35 | ![]() |
![]() Join Date: Mar 2009 Location: Yuma, AZ
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score Damn sucks to live where you guys do... i bitch and complain about it being cold when its 50 degrees outside... lol. Normal midday temps are about 70-80 during winter lol. We only have 2 seasons here in AZ. |
![]() | | #36 | ![]() |
| Not Ranked : 0 score technically all that water isn't being pulled from the crankcase. a lot of it actually forms in the can itself since the can is probably always cold in the winter and you get the warm engine air flowing through there it forms inside the can. |
| The Following User Says Thank You to slyguy800 For This Useful Post: | SharkDiver (01-11-2010) |
![]() | | #37 | ![]() |
True, true. Run a UOA with and without as above to know what you're truly pulling out of the oil with the CC.
| The Following User Says Thank You to bnoon For This Useful Post: | Hank3 (01-08-2010) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score Thanks for the info! |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score No problem.
![]() | | #40 | ![]() |
| Not Ranked : 0 score Alright.... so a bit of an update. I had a frozen solid catch can, during my last oil change (3000 km ago).... anyhow, I unthawed it with the torch, however I suspected that at some point it may have blocked the vent path from the base of the motor. Anyhow, I had the car in the garage today, to put the normal pcv hose back on for winter.... when I noticed oil coming from between my bellhousing and my block. So I believe my rear main seal must have let some oil by during the possible PCV blockage. This would also explain the intermittent clutch slippage I've been experiencing, under hard acceleration (oil on the clutch). My question.... is it possible that the seal might not be fucked? (Oh, and I was down 1/2 litre of oil) Also... I'm leaning towards my new SPEC clutch being toast..... since it's most likely been oiled...... any chance it could recover from this? My guess is no... but anyone with any experience in this matter, please speak up. Otherwise... I'll be dropping the motor in the spring, and replacing the rear main seal, and the clutch. CATCH CANS and the cold.... don't mix. |
| The Following 2 Users Say Thank You to Thestaplegunkid For This Useful Post: | flyrevs2 (02-07-2010), FreeFlyFreak (01-17-2010) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/catch-can-warning-cold-climates-45845/ | ||||
| Catch Cans in Winter | This thread | Refback | 11-29-2010 07:15 PM | |
| Catch Cans in Winter | This thread | Refback | 02-01-2010 08:44 AM | |
| Big Emergency !!!! - Page 2 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com | This thread | Refback | 01-31-2010 05:37 PM | |
| Big Emergency !!!! - Page 2 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com | This thread | Refback | 01-29-2010 07:01 PM | |
| Catch Cans in Winter - TorontoMazda3 | This thread | Refback | 01-08-2010 08:12 PM | |
| Catch Cans in Winter - TorontoMazda3 | This thread | Refback | 01-07-2010 06:51 PM | |
| catch can... and nothing | etant333 | MazdaSpeed 3 - Engine, Transmission & Driveline | 28 | 09-02-2012 02:12 AM |
| Oil Catch Can | dizzin9 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 01-02-2010 05:27 PM |
| Oil Catch Can Kit | PDXImportRacer | MazdaSpeed 3 - Engine, Transmission & Driveline | 48 | 09-16-2009 09:18 PM |
| Oil Catch Can? | bova | Mazdaspeed3/6 General Discussion | 11 | 12-06-2008 09:04 PM |
