 Old 09-26-2019, 09:14 PM   #1
Crazy8Ballin's Avatar
Posts: 5   (View Stats)
Crazy8Ballin is an unknown quantity at this point
Default Chain rubbing on valve cover?
Hi, I have a 2008 Mazda CX-7 with a 2.3L turbo engine with 143,000 miles. I drained the oil from the oil pan and after looking at the oil found glittery metal shavings. After doing some more poking around the engine and removing the valve cover it seems that the timing chain is rubbing on top of the valve cover causing metal shavings to be distributed throughout the engine. What would cause this to happen? Could I solve this by replacing the valve cover? Any input would be extremely helpful!
Crazy8Ballin is offline   Reply With Quote
 Old 09-27-2019, 12:02 AM   #2
Doing some further research I also realize that chain tension & the VVT can be a contributing factor to cause rubbing on the valve cover but my chain tension seems good...so I am unsure of where to go from here.
 Old 09-27-2019, 08:29 AM   #3
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
You need the timing chain/VVT actuator replaced. That's one of the worst cases I've seen, the chain actually chewed through the ribs of the cover.
Your car is a ticking time bomb. Get it replaced ASAP.
The Following User Says Thank You to ArmanRus For This Useful Post:
cyclist20 (09-27-2019)
 Old 09-27-2019, 11:17 AM   #4
What exactly does a bad VVT actuator do? Does it cause slack in the chain that in turn causes the chain to rub on the valve cover?
 Old 09-27-2019, 08:15 PM   #5
ArmanRus's Avatar
Groans: 42
It stretches the timing chain until your tensioner can't keep tension, hence the gouges you see on the valve cover.
Crazy8Ballin (09-28-2019)
 Old 09-27-2019, 09:31 PM   #6
Posts: 2,826   (View Stats)
Symptoms are classic for VVT actuator failure. Known issue. Mazda issued a bulletin and offered free fix up to a certain number of miles by a certain time deadline. Basically an extended warranty on that issue only. Had mine done then. They replaced the chain as a part of the extended warranty.
Do it or get it done before it jumps time and royally fucks up your engine. When valves are still open at the same time that pistons reach top dead center, they collide and the result is catastrophic.
Page generated in 0.26213 seconds with 23 queries
