 Old 11-30-2014, 02:58 PM   #1
robacks's Avatar
Posts: 21   (View Stats)
robacks will become famous soon enoughrobacks will become famous soon enough
Default Click click click from driveline
2008 stock with 90k miles.
When I start to move the car I hear a click and then let off the gas I hear a click. I have done circles to test the axels and they'll not click when I coast. I have held the brake pedal to test if it's the rear brakes, still makes noise. I hear that there is a tsb on the front axel nuts is this true, getting tired of the click click. Anyone else have this issue, and how was it solved?
I can't get the car to make the noise past 3rd gear.
robacks is offline   Reply With Quote
 Old 11-30-2014, 08:05 PM   #2
Turbo_Steve's Avatar
Posts: 944   (View Stats)
So it only clicks once when you accelerate or decelerate? Or clicks repeatedly?
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 11-30-2014, 08:46 PM   #3
Mattyhawk1's Avatar
Posts: 739   (View Stats)
I had the clicking on accel / develop about a year and a half ago. Came from my driver side front, definitely the cv. Could be the bearing, but seemed more like half shaft. If you rock the throttle on/off while driving straight, and get the click, yours is like mine.
I have done multiple autox events since then, expecting I would very soon be towed home with a broken half shaft, but instead of it getting worse, it is no longer clicking and it still hasn't blown. It does have a bit weird feel accelerating in a turn, so it still is waiting to bite.
So what have we learned? I might have the same issue you have, my car is out to get me and I'm an idiot who is lazy and waits for catastrophic failures on non-safety essential parts to save money.
 Old 11-30-2014, 09:56 PM   #4
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
It's the drivers axle , shit clicks eventually it's not the cv joint ... Get a louder exhaust and don't sweat it
1cms1 (11-30-2014)
 Old 12-01-2014, 12:03 PM   #5
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Funny you say this, I recent switched to a slightly quieter exhaust (to get rid of drone) and just noticed the clicking.
On Order:
Coming Soon:
DIY Projects:
 Old 12-01-2014, 04:44 PM   #6
robacks's Avatar
I can make it click by hitting the gas or letting off the gas. Up hills and down hills. I had the same issue starting on my old speed as well but not as bad. Only clicks a few times then stops. If I drive in second gear at a constant speed no clicks, hit the gas or let off 2 or 3 clicks.
 Old 12-01-2014, 05:45 PM   #7
brandon3212's Avatar
Posts: 425   (View Stats)
It's normal, my speed has done it since I bought it. Gets 1000X louder with 88D motor mounts, nothing to worry about.
07 Speed 3
 Old 12-02-2014, 10:06 AM   #8
radbrad's Avatar
Posts: 538   (View Stats)
I got the clicks on both front axles. To fix my issues, I bought the new axle nut and I put Mollydinium (SP?) grease on the axle splines that go into the hub. Instant fix.
07Speed3
 Old 01-14-2015, 01:57 PM   #9
robacks's Avatar
Tried to tighten the axle nuts, still clicks a little. I guess I will buy some new nuts and pull off the wheel and grease the spindle and re-install
click on start up.. wut it iz? tddvrrn MazdaSpeed 3/6 - Car Audio & Electronics 3 01-06-2012 07:20 AM
Click Click in reverse ufboostedgator Mazdaspeed3/6 General Discussion 4 12-13-2011 08:13 AM
Does your axle click yet??? rodrigo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 12-08-2010 07:35 PM
How to make my tranny "click-click" perfect? BolvangaR MazdaSpeed 3 - Engine, Transmission & Driveline 55 04-13-2010 08:48 PM
click, click, click laocas01 MazdaSpeed 6 - Engine, Transmission & Driveline 21 04-20-2009 01:32 AM
Page generated in 0.29204 seconds with 26 queries
